    I updated fibaroapiHC3.lua to v.105 with support for the new QA file format.
    If you use the hc3_emulator.deploy=true feature to deploy the real QA you are working on to the HC3, there is some new benefits.
    Default is that the code will be included in the QA file "main" if you deploy on the HC3.
    In your code you can include other files with
    If you run in ZBS this will be just a
    which means that you can set breakpoints in the included file and debug as usual.
    However, if you run with the deploy option, it will remove the "hc3_emulator.FILE("myFile.lua","myLib")" code from the 'main' and create a new file for the QA with name "myLib" and insert the code of "myFile.lua" in that file. This way you can create and deploy multi file QAs easily from the ZBS version.
    (if you use the fibaroapiHC3plugin there is a ZBS menu option to deploy: Project->Deploy QuickApp)
    Ex.
    We have set deploy=true so when we run this in ZBS this will deploy the QA to the HC3 and create 3 files for the QA.
    'main' with the code above, but all 'hc3_emulator.FILE(...)' removed
    'myLib1' with the code of MyLib1.lua
    'myLib2' with the code of MyLib2.lua
    The files will be included in the order they are included in the source.
    I advise to include them in the beginning to mimic the behaviour it will have on the HC3 ('main' runs last)
    One more trick. File that are included are stripped of the code before
    That is eleven '-' followed by " Code -" and to the end of the line.
    This means that in the source code example above the header stuff to include the fibaroapiHC3.lua etc is normally included in the 'main' - but it doesn't hurt because it's wrapped in "if dofile ..."
    However, if we include the "code marker" we can get rid of that annoying code in the deployed QA .
    Ex.
    which makes the QA a bit cleaner.
    @jgab
    in fibaroapiHC3  you have this code:
    I think it should not work because of new structure of fibaro QA ("mainFunction = struct.initialProperties.mainFunction") ...
    5 minutes ago, petrkl12 said:
    @jgab
    I think that code is gone since v 0.105 (it's already v 0.110 now)
    local function createQuickApp(args) looks different now.
    EventTypes report.
        QuickAppFilesChangedEvent = function() end,
        ZwaveDeviceParametersChangedEvent = function() end,
        ZwaveNodeAddedEvent = function() end,
        RefreshRequiredEvent = function() end,
    1 minute ago, rangee said:
    EventTypes report.
    Thanks.(and even code I could just paste in :-) )
    Actually I don't know what to do with this.
    There is a routine in the emulator that looks at all incoming events and convert relevant events to sourceTriggers. If there is an event that I haven't coded for I log this warning.
    So a {type='DevicePropertyUpdatedEvent, data={id=ID, property=PROP, newValue=V, oldValue=OV}
    is internally re-posted as a {type='device', id=ID, property=PROP, value=V, old=OV} to mimic a sourceTrigger.
    It's only Scenes that cares about sourceTriggers so for QAs that is mostly ignored.
    QAs normally fetches all (raw) events with /refreshStates
    So, in the beginning I started to logg all events that I hadn't seen before to understand if they could generate a sourceTriggers. However, I don't think that is the case anymore. There seems to be a multitude of different internal events posted these days that are of limited interest to the average QA developer.
    So, I will probably turn off these warnings and make it an option to turn them on.
    Btw, I have a "QA_Toolbox" framework where I have a generic /refreshStates loop that do generate more types of triggers - like when device are added/removed and modified as these events are sometimes useful. However, the emulator should stay true to the way the HC3 behaves and only generate relevant sourceTriggers.
    I had v106 from yeasterday.
    Thanks P.
    New version v0.120.
    Hopefully this version is usable in Visual Studio (Windows) thanks to debugging effort from @10der
    Besides being an emulator for the HC3, fibaroapiHC3.lua is also becoming kind of a utility belt of nice to have functions.
    Now there is a set of functions that can help in backing up and restoring Scenes and QAs.
    They should be seen as functions to help you "roll your own" backup scripts.
    will backup all scenes and QAs to directory /tmp
    The default naming convention is <ID><QA name>.fqa for QAs and <ID><Scene name>.json for Scenes.
    White spaces in names are replaced with underscores.
    However, people like to organise their backups in various ways so the backup function takes a 'namer' function that can decide name and where to place the file.
    The function is passed the resource table (struct) and name as arguments and should return <name of file> or <directory>, <name of file>. No file extension. QAs will always be saved under .fqa and Scenes under .json
    Ex.
    if we return "test" for a QA with dir == "/tmp" the file will be saved as "/tmp/test.fqa"
    if we return "QA","test" for a QA with dir == "/tmp" the file will be saved as "/tmp/QA/test.fqa"
    In the case above, our namer will save a QA as
    /tmp/QA/<ID><name of QA><last modified date>.fqa
    Ex. "/tmp/QA/1284_T100_Tue_Jul_28_21_32_09_2020.fqa"
    and a Scene as
    /tmp/Scene/<ID><name of QA><last modified date>.json
    Ex. "/tmp/Scene/19_KeyTestupdated_Wed_Jul_29_08_24_34_2020.json"
    That is a convenient format as it will only save modified version (rather, overwrite resources with the same modified date)
    There are also a set of functions for uploading and replacing HC3 QAs/Scenes from backedup files.
    Disclaimer. I have tested the functions and try to verify each step as not to do anything bad. However, even if so, it's easy to accidentally loose scenes and QAs using these functions in unindented ways.
    The 'replace' version are quite nice as it keeps the ids.
    W dniu 23.07.2020 o 22:30, jgab napisał:
    So they share the global environment and not locals, and that is expected.
    Yes it seems like 'main' (that can't be removed) is run last. The rest of the files seems to be loaded in order, top to bottom.
    If I have 3 files:
    File 'main':  print("A1") function QuickApp:onInit() self:debug("A1") end
    File 'test1': print("B1")
    File 'test2': print("C1")
    I get the log:
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: B1
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: C1
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: A1
    Which looks like they load all the files twice(!) - be aware to not have commands that execute directly in your files - like the prints in my example...
    However, it's only when we save the QA - if it restarts due to a crash it only loads the files once.
    Can't reproduce that, maybe you saved it gain (after save quickapp start again that way maybe you see it 2x
    /monthly_2020_07/obraz.png.eb6f7d3fb363e0981c0c6eb24605a462.png">
    W dniu 23.07.2020 o 20:48, rangee napisał:
    I think this is preparation of QA encryption.
    It is more for hint and attribute panel but encryption is on our roadmap too
    /monthly_2020_07/2020-07-29_11h31_51.png.7ddd2ead63875cce0e8740e79834d5ab.png">
    Looks nice ?
    Bug(??) report... v0.121
    When you set hc3_emulator.deploy=true and make QA...
    If QA is already exist then  files or something updated.
    It's good but when QA has viewLayout then it disappears.
    To remain viewLayout, just add 1 line at 1367
    Line 1367,
        for _,i in ipairs(list) do items[#items+1]=mkRow(i) end
        if #items == 0 then  return nil end -- >>ADD THIS
    Then.. viewLayout will not disppear.
    Line 1367,
    Do you have a hc3_emulator.UI defined ?
    The idea is that whatever is in the emulator should replace what's on the HC3.
    If the emulator code says no UI then the it should be removed on the deployed HC3 version.
    Otherwise isn't it a risk that you end up with UI elements in the existing QA that is not handled by the code that is deployed?
    Always have the complete definition of the UI in hc3_emulator.UI, and don't update the UI on the HC3 manually - that's the only way to keep things in sync.
    I share some QA with fqa files to users in my country.
    Normaly, they(users who using my QA) dont need to edit LUA code but someone want to edit some lua tables like your ER Rule.
    Problem is that. When edit code in fibaro editor, UI broken up. ( {{label='label1', text='-'},{button='btn1', text="-"}} )
    So they need to edit code via emulator.(with ZBS)
    As I do not provide UI,  user run emulator like this...
    This is why I suggested that.
    OK, then how about give options to update UI or not like apiHTTPS. ( e.g. replaceUI=true or false)
    Always thank you  jgab :)
    hi. is there any reason you did not add fibaro.clearTimeout ?
    I just add 1 line.
    function fibaro.clearTimeout(func) return clearTimeout(func) end
    No, when I did it it didn't exist and then I forgot about it when they added it. Always use clearTimeout...
    I will add in next release.
      function net.TCPSocket(opts)
        local self = { opts = opts }
    to
        local self = { opts = opts or {} }
    to
    Thanks, will fix.
    When you make ui row with function mkRow(elms,weight)
    In what way will it look/behave different? Just asking because I can see that it's unnecessary to wrap a single element in a components struct but I don't notice a difference.
    Um... I can't remember exactly because I edited this couple of month ago...
    If don't do that, it makes problem with slider.
    And without edit, code results different with original viewLayout...
    If there are multi element in row,  there's no problem.
    it looks like this
    { "components": [ { "components": [ { "name": "button2_1",
    If there are one element in row,  there are some differces.
    it looks like this without change
    { "components": [ { "components": [ { "name": "button1",
    it looks like this with change and this is original code when you make ui at fibaro editor.
    Edited by rangee
