    3 minutes ago, rangee said:
    Um... I can't remember exactly because I edited this couple of month ago...
    If don't do that, it makes problem with slider.
    And without edit, code results different with original viewLayout...
    If there are multi element in row,  there's no problem.
    it looks like this
    { "components": [ { "components": [ { "name": "button2_1",
    If there are one element in row,  there are some differces.
    it looks like this without change
    { "components": [ { "components": [ { "name": "button1",
    it looks like this with change and this is original code when you make ui at fibaro editor.
    Ok, I will fix it in next release (any hour now :-) ). I'm also making some more changes to the UI creation code so let me know if you spot some more issues/incompatibilities.
    Pushed v0.130.
    Updated handling of UI elements.Fix from @rangee also.
    Now we can declare UIlements in the UI=.. header like in this example.
    At least laying out labels and buttons/sliders on the same row is useful.
    Note also that slider takes extra arguments
    will make the slider return values 0-50 and move the value in steps of 5.
    4 minutes ago, jgab said:
    Pushed v0.130.
    Note that.. when we declare slider or button with label on the same row,
    eg)  {slider, label}  or {button, label}
    When edit script via hc3 editor, UI will broken up.
    Yes, the alternative layouts is not supported by the UI editor.
    • 3 weeks later...
    I'm trying to use the SDK - but the QA is not being generated in HC3 - I'm using MAC - could this be an issue ?
    I'm developing everything on a Macbook Pro so that's not the issue.
    It's a nice screen shot but it doesn't show what happens when you run.
    (ZBS stops at the first line (the little green triangle to the left on line 1) and you need to press > or F5 to start running the code. I hope it's nothing as simple as that :-) )
    Your settings from the screen shot shows that it's set to create a proxy on the HC3 (proxy=true). It does not happen? You would get a error message at least.
    Then when you are ready with the QA and want to deploy the real QA on the HC3 you can either set deploy=true and run once, or install the ZBS plugin to get a menu option to deploy the QA (Project -> Deploy QuickApp)
    I'm trying to set it up - I followed the Guide and the youtube video :-)
    Every second time  run F5 I am getting
    Program starting as '"/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/lua.app/Contents/MacOS/lua" -e "io.stdout:setvbuf('no')" "/var/folders/ky/rhpk780x1cn7cpwp9mh59hb4bv22t8/T/.tTnaoj"'.
    Program 'lua' started in '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/myprograms' (pid: 46281).
    Debugging session started in '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/myprograms/'.
    Program completed in 2.08 seconds (pid: 46281).
    cannot open fibaro: No such file or directory
    stack traceback:
        [C]: in function 'dofile'
        firstTry.lua:24: in main chunk
    Debugging session completed (traced 0 instructions).
    Ah, I saw that you do dofile("fibaro")
    That won't work. Put
      in your working directory
    (btw, maybe not optimal to run in the ZBS Contents directory)
    Keep the name
     also and do
    dofile("fibaroapiHC3.lua")
    Install the plugin also - you get tooltips and completions for fibaro commands.
    your creds you can provide in credentials.lua
    Edited by 10der
    Keep the name
     also and do
    I already put
    And the plugin here
    /monthly_2020_11/image.png.52c96e92213b814ad60285462601dffd.png" />
     in my working directory
    52 minutes ago, ChristianSogaard said:
    I already put
    And the plugin here
    Yes,
    credentials.lua in same directory as fibaroapiHC3.lua and your working files
    and in ZBS set working directory to ../myprograms/
    You still have issues?
    3 hours ago, jgab said:
    Yes,
    Yes - i have issues .
    In myprograms is have fibaroapiHC3.lua and credentials.lua
    and in packages I have fibaroapiHC3plug.lua
    The QA is not being created when running (F5) - should be 961
    Same screenshot as before
    Program starting as '"/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/lua.app/Contents/MacOS/lua" -e "io.stdout:setvbuf('no')" "/var/folders/ky/rhpk780x1cn7cpwp9mh59hb4bv22t8/T/.ZedPlR"'.
    Program 'lua' started in '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/myprograms' (pid: 52385).
    Program completed in 5.21 seconds (pid: 52385).
    Can you PM me the QA code you have? Something is strange...
    Hi
    On This post there is an example/quick app to send a sms using Nexmo/Vonage API.
    Is possible to instead of sent a sms to make a phone call using this service?
    Thank you
    Hi there,
    any plans to enable the SDK to run over https?
    If the answer is 'no' I do understand - just asking.
    Cheers,
    jayrock
    9 minutes ago, jayrock said:
    Hi there,
    Cheers,
    jayrock
    If you set hc3_emulator.apiHTTPS=true it will make https calls to the HC3 api
    No support for user provided certificates. If someone wants to hack it feel free to do it.
    40 minutes ago, joaoartur said:
    Hi
    Thank you
    Probably, but you need to adapt the API calls to do what you want.
    I guess it uses the same api_key and secret for calls.
    Thanks, got it. Maybe you want to add the property to post #1.
