    1 hour ago, jgab said:
    This is cool.
    In ZBS user or system preferences, set:
    Then run something like
    It will download QuickApp with deviceId 47, unpack it in directory /fqas and stop the debugger when it enter the QA's :onInit and open the file in a new ZBS buffer....  and then it's just to step through and debug...
    ...and breakOnLoad=true makes the debugger stop on the first line of files loaded and open them in a ZBS buffer.
    Edited by petrkl12
    @jgab
    After testing of new fibaroapiHC3C it's still better to use and simple for debug older fibaroapiHC3.
    I usually use this syntax - it works for me :)
    if dofile then
      if not hc3_emulator then
        hc3_emulator={id=xxx,quickApp=true,poll=1500}
        dofile("fibaroapiHC3.lua")
    Edited by petrkl12
    3 minutes ago, petrkl12 said:
    @jgab
    if dofile then
    Ok, unfortunately it will not be updated to keep up with fw releases.
    Understand.
    For example now I can't change/install any QAs in my HC3 (thanks to Fibaro that all QAs are twice in memory).
    With old setup I can do some development - in new one it doesn't work  ...
    Edited by petrkl12
    1 minute ago, petrkl12 said:
    Understand.
    For example now I can't change/install any QAs in my HC3 (thanks to Fiabro that all QAs are twice in memory).
    Yes, that is unfortunate - but connecting to existing QA was always a bit strange and your use-case seems to be easiest to solve by just copying over the properties from the real QA when you start up the emulated QA?
    I'm spending a lot of effort to make the emulator more compliant, both for QAs and Scenes, and it's impossible to keep up with two diverging sources. However, I do value feedback from users and I'm willing to spend time implementing features requested. I know the new emulator with 50% rewritten code will have issues and it will take a couple of rounds before it is on par with the old. The potential for the future is much bigger though.
    However, for your problem with viewLayout I suggested copying the properties from the real QA at startup instead of spending a lot of code for something that is an exception to how people normally use the emulator.
    What else doesn't work that we can fix?
    So I tried to run your Hue QA (fqa version) and it throws an error "[string "HueTools"]:25: attempt to perform arithmetic on a nil value "
    If you PM me an unobfuscated version of you fqa I will debug it and make sure the emulator can run it. (now it's really difficult and ZBS even freeze when I try to open some file ?)
    I can't create new QA for you because my HC3 is dead for any QA changes :(
    I will send you all source codes and you will have to replace them in QA
    Thanks!
    So, 5 days of intensive debugging after @petrkl12 sent me his QA :-)
    However, fibaroapiHC3C.lua is in better shape. Thanks.
    @petrkl12 I can get the Hue QA to run now. All the wrinkles is not ironed out but it runs.
    If you set
    It will load the viewLayout and quickVars from QuickApp ID 523 at startup.
    If you provide your own quickVars
    it (foo in this case) will override or be added to the variables from the resource declaration
    If you provide
    it will override the viewLayout from the resource.
    I can run the Hue QA with hc3_emulator.proxy = true
    If not it is possible to open http://127.0.0.1:6872/web/ to get a simulated web GUI of the QA (only when the emulator runs)
    @jgab
    I'm going to try it :) thanks
    @jgab
    QA Hue works - basic run OK
    What is not working:
    - Buttons: Restart and Start
    - web gui - I'm not sure what should be visible here ...
    My setup:
    Hi @jgab
    I got a new device (
    Adding this rule
    fails with
    any idea ?
    /monthly_2021_03/image.png.cc411816c56697126fe82790a3fdc95b.png" />
    15 hours ago, petrkl12 said:
    @jgab
    My setup:
    Ooops, a bug I introduced before pushing the file. Fixed in .172
    I wonder if you have a bug in Menu.lua.
    You do
    but the file content (fc) is not json.encoded, so my emulator throws an json.exception.
    Another tip.
    make your setTimeout and json patches conditionally in Tools.lua because the setTimeout and json part of the emulator gives better error messages (easier to pinpoint problem)
    Something like
    16 minutes ago, ChristianSogaard said:
    Hi @jgab
    Adding this rule
    fails with
    any idea ?
    I think this is an EventRunner issue and should be in that thread instead of the SDK forum.
    However, your rule has no visible problem. The rule parsers (tokeniser) complains because it can't identify the "words" in the rule. Because there seems to be no problem the best guess is that some "invisible" characters have managed to get into the text which trips up the parser.
    Rewrite the rule from scratch (don't copy&paste the old).
    16 hours ago, petrkl12 said:
    @jgab
    plugin.restart() is not implemented yet but I'm working on it.
    You do
    It should be OK :) - content is of course not encoded but I have inside of HueMain all sources for other .fqa's and these are json encoded (technically there is one big comment and inside this comment there is encoded source code of fqa). You can see in my HueMain.fqa
    Edited by petrkl12
    confirmed that worked - thank you
    v 0.174 has a couple of interesting features.
    hc3.timersWarn=true will log a message if a setTimeout timer is scheduled and fire late (and how late it is fired).
    Because we have a cooperative scheduler (also on the HC3), timers may be fired late due to other stuff going on.
    If it happens now and then it's usually not a problem, but if it is recurring it can be good to understand why and redesign the code not to block for too long intervals.
    hc3.timersExtra=true will annotate the timer with the source code line from where it was scheduled (setTimeout)
    This way we now not only if the timer was late but where in the code the late timer was scheduled.
    Also when your function crashes due some error in your code you
    This code
    It starts a timer in 2s, but then do a sleep for 4s that will delay the timer.
    The last timer crashes because it calls an undefined function A()
    Debug output.
    First we can print out timers. We will get identity, when it should expire, and the file and line it was scheduled from.
    We get a warning that the first timer is ~2s late when it finally runs.
    We get an error message when our last timer crashes. We get the line the timer was defined on and the line of the offending code.
    If we run in ZBS, late timers will be logged in red color, and ok timers in green
    I will add a check for strange characters in the code...
    This code
    Debug output.
    First we can print out timers. The printed representation of the timer contains useful information.
    We will get address of the function, when it should expire, and the file and line it was scheduled from (where setTimeout was called from).
