@jgab
in newest version there is error:
    3 minutes ago, petrkl12 said:
    @jgab
    How does the header look like?
    ...and it happens to me too -but not every run! Very interesting!
    Fixed in v0.175 - not very interesting just a stupid cache bug in my code,
    Error is not there but QA hue is not starting -
    Another bug squashed, v 0.177
    You can turn on your 'GlobalLogs'  to see how far it gets.
    You can also add some debug flags to see what's going on
    hmm it still doesn't work ... In your enviroment QA Hue is working?
    Yes it runs very well. Both from the Lua files you provided me and directly by downloading the fqa from the HC3
    Where does it stop if you turn on your GlobalLogs and
    it never stoped :)
    26 minutes ago, petrkl12 said:
    it never stoped :)
    The log is a bit noisy.
    If you do
        hc3_emulator.debug = {http=true, api=true, timersSched=false, trigger=false}
    and run.
    For me it takes 10s for the first startup sequence (you do a wait for 10s).
    Then it takes another 25s until it goes into a loop polling,sensors groups, and lights.
    I can see in you logs that the last of interest that happened is
    When I run that log is the one before:
    after that it goes into a loop polling,sensors groups, and lights.
    That last HueSwitchStandard download runs some 3s after the HueLightSensorStandard download for me.
    Unfortunately you cut it 2s afterwards.
    Btw. The QA that sends the TICK event you should get rid of - I know I used it in the past but it's not necessary anymore when poling for triggers,
    If you do
    and run.
    new log
    this is from your ER4 - how to stop it? I thought that I have latest version ...
    13 minutes ago, petrkl12 said:
    new log
    This is my log. After it downloads SwitchStandard it goes into a loop polling the hub. (and logs httpRequest...)
    If you set GlobalLogs=true in your QA do you see if the download of the SwitchStandard succeeds
    Yes, later version (if you enable online patching) don't send TICKS
    I know where is problem:
      local ll=self:getVariable("Logs")
    it returrns ="" but I have in local variables value "Yes" from hc3_emulator.resources = {UI = 523, quickVars = 523}
    Edited by petrkl12
    Just pushed v.181 to GitHub of
    It tries to be backward compatible with the old model of invoking the emulator - but it also supports loading several QAs and run them in parallell.
    It's starting to come together. I just run
    • GEA 7.20
    • Sonos Zone Player 1.3.8
    • EventRunner4 v0.5fix46
    • HueMain.fqa 2.55
    At the same time...and they run quickly - faster then the HC3. On the other hand I have a MacBook Pro ;-)
    They are all pretty demanding QAs so that was the reason to try them out all at once.
    Some unpacked, and some directly from the .fqa. There is the possibility to injects arguments like quickVars or name or id  before launching QAs.
    There is also some decent support for Scenes and conditions.
    @jgab
    Thanks for new SDK version
    Hue Main is starting up to 100% and than it should start to compare values from Hue bridges but there is only a lot of timers.
    Can be problem that settimeout is working differently than in fibaro?
    I really try to mimic the HC3 timer behaviour so lets see if its something else.
    Are you running the latest v.182?
    You can set emulator.debug = { timersWarn = 0.750 } to make it only warn if timers are later then 700ms. Default now is .500s
    You seem to have a similar repeating behaviour. Ex.
    They are all happening during the same second 12:38:36, and they are all ~700ms late - however that's not a big worry in itself. (the one on line 252 seems to start the sequence)
    The setTimeout called at QA_Hue_F_HueInfo.lua,line:1066 is responsible for 6 of the timers each second. Are they polling the Hue hub or other QAs?
    Does it scale or will you poll more stuff each second for more lights or hubs?
    I would also set a breakpoint in 1066 inside the scheduled function and see if it does what's expected with the result.
    It works now,
    newest version helped
    thanks
    How to stop these timers debug info at all?
    [33mWARN [0m|: Late timer:0.129s [32m<Timer:0182 fun:01693430 exp:16:57:53:408>[0m
    Edited by petrkl12
    hc3_emulator.debug.timersWarn = false.
    You can change it at runtime with
    if _debugFlags then _debigFlags.timersWarn = true end
