Did you get the mqtt library installed OK ?
Or you mean you are using IF's to not execute any mqtt statements offline ?
Our posts overlapped sorry - what OS are you running ZeroBrane on ?
Edited by xAPPO
@jgab Jan
another issue
/monthly_2020_07/image.png.7cdf3af5b1153c02b1b80f996b0562a3.png" />
no. I am chuck norris
    20 minutes ago, 10der said:
    @jgab Jan
    another issue
    I can't see any ":" in the code - this piece of code has compiled for months - must be some evil char that have sneaked into your source.
    42 minutes ago, 10der said:
    You need to change the way you include the emulator
    ...otherwise you get an infinite loop.
    Jan. thank you.
    fixed.
    so. luamqtt doesn't work in VSCode.
    attached lib works. but I re-wrote (cuz uncompatibile) your code :(
    12 minutes ago, 10der said:
    Jan. thank you.
    fixed.
    Why doesn't it work? Is it some lib? like luasocket?
    ok. trying to debug.
    btw: simple lib what i attached worls like a charm
    Ok, I will have look at the library and see if I can use it instead.
    and btw #2 :)
    @jgab fixed luamqtt installation fro VSCode
    now i have this blad.
    [19.07.2020] [23:13:14] |ERROR|: MQTT error:failed to open network connection: socket.connect failed: host or service not provided, or not known
    UPD
    mqtt://192.168.1.10:1883
    self.client = mqtt.Client.connect("192.168.1.10", {clientId = "HC3"})
    [19.07.2020] [23:20:07] |[34;1mSDBG |: MQTT connect:{"rc":0,"type":2,"sp":false}
    [19.07.2020] [23:20:12] [DEBUG]: connected: {"returnCode":0,"sessionPresent":false}
    [19.07.2020] [23:20:17] |[34;1mSDBG |: MQTT close:{"close_reason":"connection closed by broker","connack":{"type":2,"rc":0,"sp":false},"coro":thread:
    Edited by 10der
    UPD2: all OK!
    just clientID already was busy by own app.
    so, RTFM for windows VSCode users
    1) download luamqtt-master.zip
    2) unpack to mqtt folder from zip mqtt folder (sorry for tautology)
    3) create mqtt.lua file
    /monthly_2020_07/image.png.a7f6477629f5e625f00971cdb156b34b.png" />
    with context
    happy debugging!
    After F/W upgrade to 5.040.37..
    mainFunction  now invisible.
    Yes. Can't edit via api.post()
    click in the main file left .. this version supports multifile QAs. Once clicked you should see content and be able to save, so the selection stays in saved QA.
    Yes, the quickApp's code management have become more sophisticated. I need to update the way I deal with it in the emulator. The good news is that I believe what we got is much better....
    I think this is preparation of QA encryption.
    To encrypt the code, it need to be invisible via any way.
    QA editor  consists of main file and additional files(eg. test1)
    QA loads   test1, test2 and finally  main file.
    main file loaded at last.
    test1, test2, main   these 3 files are cooperative but works independently.
    I mean...
    test1's local var, fun   cannot call at  test2, main.
    test1's   function Quickapp:method is callable at main.
    I mean...
    So they share the global environment and not locals, and that is expected.
    Yes it seems like 'main' (that can't be removed) is run last. The rest of the files seems to be loaded in order, top to bottom.
    If I have 3 files:
    File 'main':  print("A1") function QuickApp:onInit() self:debug("A1") end
    File 'test1': print("B1")
    File 'test2': print("C1")
    I get the log:
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: B1
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: C1
    [23.07.2020] [22:23:32] [DEBUG] [QUICKAPP1333]: A1
    Which looks like they load all the files twice(!) - be aware to not have commands that execute directly in your files - like the prints in my example...
    However, it's only when we save the QA - if it restarts due to a crash it only loads the files once.
