Configuration:
- RGBW led strip connected to RGBW 2 controller +  monostable (GIRA) wall switch
- HC3
- Fibaro iOS mobile app
System by default use "white" colour through mixing only RGB channel from RGBW led strip and white (W) chanell is not use (turned off) .
If you want to use white colour from your RGBW led strip you have to define white colour ( #000000) by yourself  in fibaro web application.
All is fine if you are use such a configuration and use only wall switch.
When you changed led colour (i.e. yellow, magenta, blue, green or whatever) through mobile application you will not be able turn on/off led light with your wall switch. It doesn't work any reaction from led strip
To "fix" this issue you have to login to web application and choose once again earlier defined white colour ( #000000).
Have you ever meet such a problem/bug ?
Thank you
Edited by mariokil
Update
    Anyone ? ;)
    Up
