  • 9
List of Zigbee devices - users for users
K.Drozynski
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
  • 2
Aqara Motion Sensor P1
Hc3 detects device in debug window, but in the end no device is added
please consider more options:
- possible to add/pair
-- works/doesn't work
-- (if it works) what value/function are available ?
No need to do the same job twice. A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
It is important to link to the exact same device as the one you have tested because there are many lookalikes...
Edited by petergebruers
  • Like 5
  • Thanks 2
IKEA LED1649C5
Works as expected, includes as "com.fibaro.multilevelSwitch"
 This one works as expected! SONOFF SNZB-02 Temperature and Humidity Sensor
 This one works. Shows temperature and humidity but no air pressure AQARA WSDCGQ11LM
 This one doesn't work. MiJia door window contact sensor MCCGQ01LM
 This one doesn't work either. MiJia human body movement sensor RTCGQ01LM
 This one doesn't work. MiJia wireless switch WXKG01LM
 Doesn't work. TuYa TS0601_temperature_humidity_sensor
ECO-DIM.07
TUYA TT001ZAV20 ZC-W1-1
Works as expected, includes as "com.fibaro.humiditySensor" and "com.fibaro.temperatureSensor", with proper battery level.
EDIT: Battery level was working in previous alpha firmware, after reinlusion is not anymore there, sorry for confusion.
Philips HUE 929001953101
Does not work as expected:
- before 5.102.23 it was color controller with warm white, now includes as com.fibaro.FGRGBW442CC, without warm white.
- toggle not working
- when switching via BT, status and color not updated, need to refresh zigbee (attached "Zigbee refresh" QuickApp)
Paul Neuhaus  100.075.74
- when switching via zigbee FB, status and color not updated, need to refresh zigbee (attached "Zigbee refresh" QuickApp)
- device seems to getting offline for no reason (zigbee status refresh QuickApp does "wake it up" again),
  however one can set color and mode even if device is being displayed as offline.
Merrytek (TUYA) MSA035-Z1
Does not include, device class is not supported.
Since 5.120 supported, see
Btw, that QA does show LQI for refreshed zigbee device, and of course other values like color_mode etc, if they exists.
Edited by tinman
LED1842 G3 IKEA TRADFRI LED bulb E27 WW clear 250 lumen, dimmable
Works as expected, is a com.fibaro.multilevelSwitch
Note: currently not possible to set power_on_behavior. EDIT: to be more precise: HC# supports power_on_behavior, the device supports power_on_behavior, but there is no GUI to set this lamp property.
LED1732G11 IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, white spectrum, opal white
Does NOT work as expected, gets configured as com.fibaro.multilevelSwitch which does not offer a slider to control warm/cool white
Level control on this device does work.
LED1650R IKEA TRADFRI LED bulb GU10 400 lumen, dimmable
Works as expected, is a "com.fibaro.multilevelSwitch"
Xiaomi/Aqara TVOC sensor:
In HC3 TVOC values are missing. Only temperature and humidity is shown.
Attention: This device keeps "dying" in my system in office and at home. Maybe not recommended atm. @K.Drozynski, this device is battery VOC sensor, that is missing in Z-Wave portfolio. Please, can you guys look into it. Issues HC3-759 and HC3-733 in Fibaro feedback portal.
Xiaomi/Aqara light intensity sensr
Works. Shows illuminace.
Xiaomi/Aqara door/window sensor
Works. Shows temperature and state of magnetic contact.
Xiaomi/Aqara motion sensor
Works. Shows motion, temperature, illuminesence, battery Voltage.
Blind time (the time it shows motion occured) is about 1 minute.
Immax NEO 07088L
It work. Shows as Fibaro com.fibaro.multilevelSwitch.
Little tedious to make reset sequence right.
Ledvance Smart+ Gardenpole
It works. Shows as multicolor controller. Tuneable white does not work as Fibaro does not supports it, yet.
IKEA LED1623G12
Unable to add, despite light being updated via my Tradfri to latest firmware and factory reseted. Adding and removing works completely fine in my Tradfri gateway.
IKEA LED1546G12 (I think its this one)
You are able to add and control it without getting feedback (on, off, setValue works). Works bi-directional few minutes after reboot, then it got stuck at 50% (I used it in hallway night scene to set to 50%). Issue HC3-760 in Fibaro feedback portal.
Tunable white control does not work. @petergebruers, interesting is, there is property Color in API, atleast with mine. Mine showed 370, but it looks like to me it as first 3 digits of white temperature in kelvin.
Zigbee only HUE lights.
You are able to add them and control them fine. If they gut stuck or you need to make HC factory restore only possibility to reset was via HUE gateway, if backup to restore is not possible.
Edited by jakub.jezek
21 minutes ago, jakub.jezek said:
IKEA LED1623G12
I just added one. May I suggest you have a faulty on or maybe it is dying? We are talking about a very "heavy" light, I mean it weighs a lot, more than any other bulb? I have had several of them and 3 already died...
  • One started blinking when on full power, then died. I took it out the lamp holder which has quite good thermal properties and I nearly scorched my hand. This one is in the bin.
  • One started blinking, when it was OFF! This one isn't in the bin yet, but see video below why I probably won't be able to fix it.
  • Third one is dead. It seems to have failed while it was off
I think the rubbery material + sandwich construction causes long term problems...
Maybe, as I was able to add it only via Tradfri remote. I do not feel any hotspots compared to HUE, so I think It could be antenna problem.
tried to install with Aqara gw the latest firmware?
LED1836G9 IKEA TRADFRI LED bulb E26/E27 806 lumen, dimmable, warm white
E1745 IKEA TRADFRI motion sensor
Does NOT work as expected: joins OK but then status stays "never breached"
Adds as "com.fibaro.motionSensor"
Nope. Do not have Aqara gateway.
HG06106C Lidl Livarno Lux E27 bulb RGB
The HG06106C is actually a RGB + CCT devices, as verified by the LIDL - TUYA app and confirmed by its brighness in "white" mode.
Does not work as expected, only shows RGB controls
Adds as "com.fibaro.FGRGBW442CC"
This is a TuYa rebranded device, it may have partial support for ZigBee standards, but mainly uses TuYa protocol layer on top for full control.
HG06104A Lidl Livarno Lux smart LED light strip 2.5m
Same issue as previous one: this is a RGB+CCT strip and cannot be controlled by type "com.fibaro.FGRGBW442CC"
HG06337 Lidl Silvercrest smart plug (EU, CH, FR, BS, DK)
There is definitely nothing "smart" about this plug, it does "on" or "off"... works... One of the ugliest, bulkiest and dumbest device I have ever seen.
Smart temperature and humidity meter with display
Works perfectly!
Edited by Poom
Nous A1Z
You are able to add but not schowing in list.
ZNLDP12LM Xiaomi Aqara smart LED bulb
Does NOT work as expected, this is a "tunable white" but recognized as a dimmable bulb, type "com.fibaro.multilevelSwitch"
SP 120 Innr Smart Plug
Works as expected: exposes a relay, a A meter and a V meter plus W and Wh
Opinion: this devices is no longer in production, its successor SP 220 no longer measures anything. The SP 120 has the potential to SPAM your Zigbee network with frequent updates.
E1702 Ikea TRADFRI control outlet
Works as expected. It is a dumb relay. Also runner up in the contest "ugliest dumbest plug" - only beaten by the LIDL Wall Plug I have mentioned before. But the Ikea isn't actually bad if you use the remote switch (which you have to because the plug itself has no button)... Wall Plugs should have a remote switch because the plug will be used in an inconvenient place...
Aqara Temperature and Humidity
Works as expected, adds a humidity sensor and a temperature sensor.
Aqara Switch T1 with neutral
Works as expected, adds a switch
Aqara Switch T1 without neutral
HG06338 Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS)
Works as expected, adds 3 relay switches.
Opinion: this device is an abomination. Pros: it has got a nice cable and plug. Cons: everything else...
Has anyone tried woox R7060 zigbee water irrigation timer? I’m interest on buying a couple as it works on AA battery since I don’t have wall sockets next to the balconies water taps where I have my flower pots.
/monthly_2022_04/3081C254-FB7B-4829-9A9A-613303A328F4.jpeg.c97965b48ce10df5b5b43ba6a95da244.jpeg" />
