  • 12
List of Zigbee devices - users for users
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
HG06338 Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS)
Works as expected, adds 3 relay switches.
Opinion: this device is an abomination. Pros: it has got a nice cable and plug. Cons: everything else...
Has anyone tried woox R7060 zigbee water irrigation timer? I’m interest on buying a couple as it works on AA battery since I don’t have wall sockets next to the balconies water taps where I have my flower pots.
/monthly_2022_04/3081C254-FB7B-4829-9A9A-613303A328F4.jpeg.c97965b48ce10df5b5b43ba6a95da244.jpeg" />
On 4/14/2022 at 12:46 AM, tinman said:
ECO-DIM.07
Works as expected, includes as "com.fibaro.multilevelSwitch"
TUYA TT001ZAV20 ZC-W1-1
Works as expected, includes as "com.fibaro.humiditySensor" and "com.fibaro.temperatureSensor", with proper battery level.
Philips HUE 929001953101
Does not work as expected:
- before 5.102.23 it was color controller with warm white, now includes as com.fibaro.FGRGBW442CC, without warm white.
- toggle not working
- when switching via BT, status and color not updated, need to refresh zigbee (attached "Zigbee refresh" QuickApp)
Paul Neuhaus  100.075.74
- when switching via zigbee FB, status and color not updated, need to refresh zigbee (attached "Zigbee refresh" QuickApp)
- device seems to getting offline for no reason (zigbee status refresh QuickApp does "wake it up" again),
  however one can set color and mode even if device is being displayed as offline.
Merrytek (TUYA) MSA035-Z1
Does not include, device class is not supported.
Btw, that QA does show LQI for refreshed zigbee device, and of course other values like color_mode etc, if they exists.
ieeeAddr stands for? And where can I find it?
2 hours ago, max_fok said:
ieeeAddr
Every ZigBee device has a unique identifier. It is like a MAC address on an ethernet controller.
You most likely don't need it and it is rarely printed on the device. But once you have joined the device it is listed on the "general" page on the HC3 web page, when you are looking at the devices page. It is after the aptly named label: "IEEE address:"
I use this identifier's last 4 digits to mark my devices, so if I have eg 10 door sensors in a box, I can easily know which one is which if I reset them.
Aqara roller shade companion E1
It is possible to pair but it cannot be used.
this is the dev unique identification, you can find it under device general properties, e.g.:
/monthly_2022_04/image.png.d9b30194c1c9f4e89fb08ae90d5f4c51.png" />
Thank you very much!
 SONOFF BASICZBR3. works as expected
  SONOFF SNZB-03. works as expected
 SONOFF SNZB-04. works as expected
LEDVANCE Smart+ Candle E14 tunable white
On/off and dimming works, but tunable colour temperature (2700-6500K) is not yet supported.
Edited by marcwau
IKEA E1524 Tradfri Remote:
Not working as expected, it is added into the system, but there are no controls (Yet as I understand from @petergebruers).
Batterylevel is not reported back to the HC3, also not if I remove the battery for a few seconds and put it back in.
IKEA ICPSHC24-10EU-IL-1 LED Driver:
Working as expected, can be dimmed, but is instantaneous.
IKEA ICPSHC24-30EU-IL-1 LED Driver:
The LED Drivers don't report back status to the HC3 if they are turned on by the remote.
Edited by SDeath
I have the IKEA E1810 TRADFRI Remote.
Does not work.
Exactly the same limitations as you describe. In the block scene, I can only select 'Battery level' as trigger.
And battery level stays at 0%.
IKEA E1743 TRADFRI ON/OFF switch
Not working, is added but does not work and battery stays at 0%.
IKEA LED1925G6 TRADFRI LED bulb E14 470 lumen, opal, dimmable, white spectrum, color spectrum
Works basic, can turn on/off, dim and change some colors. Doesn't report back to HC3 when operated with the ON/OFF switch.
It doesn't work. Cannot add to HC3
Aqara Roller Shade Driver E1
but with this no. AM023GLW01 / RSD-M01
Adds to hc3, but as generic device. Cannot be controlled.
  SONOFF SNZB-03. does not work as expected - it worked and stopped (reset does not change the situation)
- działa ale brak wskaźnika baterii
 - działa
SONOFF ZBMINI-L - Zigbee smart switch (no neutral)
Working.
OSRAM AC0251100NJ - Smart+ switch mini
 - działa
Hi. Can anyone confirm SONOFF SNZB-03 to be working with HC3?
Blitzwolf BW-SHP13 works as expected
It works for me but doesn’t show battery
Edited by max_fok
I confirm SONOFF SNZB-03 and SONOFF SNZB-04 work for me in hc3, but battery level is not reported.
