  • 12
List of Zigbee devices - users for users
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
18 minut temu, lukaszbobola napisał:
I confirm SONOFF SNZB-03 and SONOFF SNZB-04 work for me in hc3, but battery level is not reported.
Gentlemen, the sensor worked for 1 day on the first connection and it hung in the "move" position and it was like that for more than 20 hours. After disconnecting it, it could not be reattached to HC3. after many attempts it worked and it works properly for the 3rd day. I don't trust the SONOFF SNZB-03.
@K.Drozynski, is it an idea to add a table to the topic start with the devices that the FIBARO developers are working with?
I think this is good for the helping community to see some progress. ;)
Yes exactly, do not trust and do not use in critical systems. It is ok to switch on the light in the room as it is cheap, but for alarm system I would use something more robust like Fibaro motion sensor.
On 4/17/2022 at 8:41 PM, max_fok said:
Has anyone tried woox R7060 zigbee water irrigation timer? I’m interest on buying a couple as it works on AA battery since I don’t have wall sockets next to the balconies water taps where I have my flower pots.
✔️ Woox R7060 (Irrigation valve)
Works fine with HC3
But internal build of the device is very cheap. You have to be very careful installing batteries and opening/closing the box to not damage or break anything.
Edited by Albert
4ch ZigBee switch module połączył się od razu z centralka i działał bez problemu dopóki nie zgubił zasięgu, po jednym dniu odzyskał zasięg i parę dni później to samo, w linii prostej 8 m przez 3 ściany. Słabizna chyba nie będę w to się pakował.
Jeszcze jedno jak gubi zasięg to zapala światło, czyli styki normalnie zamknięte.
Aqara single key wireless wall switch (2016 model)
Only a Parent device is added, you're not able to use the switch.
Aqara single key wireless wall switch (2018 model)
Aqara D1 double key wireless wall switch
Aqara T1 wireless mini switch
MiJia light intensity sensor
Works (illuminance in lux)
Osram Smart+ Plug Outdoor works great
Blitzwolf BW-SHP15 works great
Tuya IG019 works good. Can be controlled, shows voltage and current.
Lidl HG08164
Silvercrest smart button
Does not work :-(
After this ZigBee page shows "ZigBee devices: 2" but there is nothing in the device list.
✔️ Lidl Livarno RGB Spot, HG07834A, GU10
Works fine (can ON/OFF, set Brightness[0-100], set Color [RGB space], choose one of predefined colors)
/monthly_2022_06/image.png.ad5d2720debe2a191207df946aa35cdb.png" />
✔️ Lidl Motion Sensor, SilverCrest SMSZ 1 B2, HG07310
Works fine, signals motion. Breaching state is kept for 60sec after last motion. Reports battery state.
Lidl Livarno RGB Gardenspot , HG08633
Does not work, pairing process does not ends, stays at
Edited by Albert
Finally a decent outdoor sensor: Hue Motion Sensor:
Tradfri LED2003G10
Adds but no tempreture control only cool light. Bit annoying.
Tradfri LED1925G6
Works as advertised.
Styrbar Remote
Added but can't do anything with it.
Aqara Single Switch Module T1 (No neutral) works as expected. (needed to refresh the page so to see in the device list)*
Sonoff Zigbee Smart Plug S26R2ZB (de plug) works as expected.
Tuya co2 sensor
Don't work. Console say: Device added to network and silence
Saswell irrigation controller is not compatible to Fibaro Hc3. It connects but silence right after. Be careful some stores  claim that is compatible to Hc3 but it’s not.
I removed the link of the store claimed that irrigation controller was compatible to HC3 as the “gentlemen” had the sensitivity to remove the HC3 compatibility logo of the device’s link.
probaby there are multiple firmware editions out on market (mine doesn’t work) I ll get a Tuya hub in order to get it to work, hopefully integrate it to home assistant and I ll check if there is a firmware update that maybe compatible to HC3.
anyway I wouldn’t recommend buying that.
Edited by max_fok
On 5/15/2022 at 11:45 AM, jonname84 said:
SONOFF ZBMINI-L - Zigbee smart switch (no neutral)
Working.
OSRAM AC0251100NJ - Smart+ switch mini
Not working, is added but does not work and battery stays at 0%.
Hi jonname84,
How is your longer experience with SONOFF ZBMINI-L?
Only on / off function or does it also report power consumption or other?
TuYa MIR-HE200-TY
Wired Sensors -  Tuya WiFi/ZigBee Human Presence Detector MMwave
I came across these wired sensors "Human Presence Motion Sensors" using mmWave, can anyone confirm they are compatible with the HC3? They have a model with a fall down stairs function which is particularly interesting!
Here is a link to a review of the device:
1 hour ago, Black Jaguar said:
TuYa MIR-HE200-TY
that sensor exposes lot of unsupported things, afaik you will get only motion sensor (based on occupancy information) and light sensor (based on illuminance information).
I have "similar" HP MS, LifeBeing Merrytek MSA035-Z1,
which works sice 5.113.60, but only these two values mentioned above, no presence, no breath etc. (which are displayed in TUYA app btw.).
Merrytek seems to be not listed on Zigbee2mqtt, it will however detected on HC3 as JAVIS JS-MC-SENSOR-ZB,
Additionally such sensors needs some calibration, means one must set some options, which is not yet supported on HC3.
On 8/26/2022 at 11:58 AM, Peter said:
Hi jonname84,
Hi, sorry for the delay. Only on/off function is avayable and the range of the signal is quite poor compared to Z-Wave.
Edited by jonname84
