  • 12
List of Zigbee devices - users for users
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
Saswell Zigbee Electrovalve model SAS980SWT-7-Z01(EU) is detected but not configured. Anyone has been able to solve it?
W dniu 6.05.2022 o 16:33, pnutp0wer napisał:
Aqara Roller Shade Driver E1
but with this no. AM023GLW01 / RSD-M01
Adds to hc3, but as generic device. Cannot be controlled.
Someone managed to add and control the Aqara RSD-M01 drive? How to control this drive via zigbee?
Guest Alkaramazov
On 6/26/2022 at 6:43 AM, max_fok said:
Aqara Single Switch Module T1 (No neutral) works as expected. (needed to refresh the page so to see in the device list)*
Sonoff Zigbee Smart Plug S26R2ZB (de plug) works as expected.
There something wrong in you information : you wrote "(No neutral)" , but you linked the one "With Neutral".
So my feedback about Aqara single switch module T1 (with neutral)
Switch function is working, temperature of the device is working
Power and energy does not work as expected : some child devices are created, but the value returned is always 0
Fibaro doesn't support power or energy monitoring on Zigbee devices.... yet? Hopefully in the near future they will add this ability.
Tuya soil moisture monitor QT-07S  - not working
Added to the HC3 but showing only parent component.
W dniu 15.04.2022 o 13:58, pnutp0wer napisał:
Aqara Switch T1 with neutral
Works as expected, adds a switch
Aqara Switch T1 without neutral
Anyone knows if there's any option to change the physical switch type for these devices? By default it's set as a rocker (bistable) while I need a rebound one (monostable). I've read in the Aqara faq documentation, that "After it is connected with the external switch, you need to set it on the app. The default connection is the rocker switch.". No settings in Fibaro though. Is there a way to get there to the settings? I've checked the Fibaro api swagger but there's nothing fancy there for zigbee...
Seems new firmware for HC3 has been just released (5.142.83 (beta)), some more zigbee devices and capabilities should start working. I've just tested ‎Aqara WSDCGQ11LM and the pressure sensor is alive! You need to remove the device and add it from scratch to achieve this, though. I think they've also added support to vibration sensors and some more.
Yes, I can confirm this. Great news!
@m.roszak
Could you explain to me, why in the changelog the brands for the  new Zigbee devices are not named.
We have added support for generic clusters responsible for specific functionality. Naming some won't change much because there are a lot of devices of the same implementation but with different brands/names but most of them use Tuya "handling" anyway.
Also some of the devices implement some things the "hard way" - not using clusters prepared by Zigbee Alliance.
By adding support for one specific device this means support for several devices at the same time.
Additionally, some of the devices may work differently even if the name is the same (different product revision) -  that is why we try to avoid giving exact names.
I will try to learn if we can prepare a list of devices that SHOULD work correctly and then publish it - but without any guarantee.
Thanks, clear explanation and it sounds plausible. I learned something today :)
OK, the pressure Interface reports values, but the Swagger API shows them as
"type": "com.fibaro.multilevelSensor", "baseType": "com.fibaro.sensor",
can you please change the type to something like pressureSensor for easy identification in QAs?
Some good news with new HC3 beta 5.142.83 ?
Zigbee:
Added support for smoke, pressure, gas, volatile organic compounds, vibration, and presence sensors.
Added support for device role settings.
Added support for device's temperature sensors.
Only a madman will trust ZigBee on Fibaro. Especially sensor readings. I used zigbee temperature sensors, it was crazy.
Well, I'm using a few Aqara-branded and what they show is actually inline with what genuine Fibaro sensors report. What's disturbing is rather that there's no way to easily implement temperature offset/correction for zigbee stuff while for z-wave it's always there in the parameters.
I'm in a big need of being able to set parameters for zigbee devices - as mentioned in one of my previous posts I need to change a switch type to monostable and it's not feasible at all.
Zigbee:
It seems to me that the new version works much better with Zigbee. But let's not jinx it.
sonoff zbminil2  extren ZIGBEE -  nie działa !
Edited by sebo
Is there zigbee support of Leroy Merlin Zigbee devices (Lexman Enki) ?
Specifically RGB LED Panels such as Inspire Gdansk (Bluetooth and zigbee)
Aqara Temperature & Humidity Sensor T1    TH-S02D
Not working :(
Edited by MacinZ
