  • 10
List of Zigbee devices - users for users
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
Smart Soil Sensor doesn't work.
Unknown device.
Problem with HEIMAN HS1CG-E Combustible gas sensor:
The device can be added to HC3 and it is detected as "Gas detector", but it the gateway does not see any of the possible triggers, other than "Unavailable". I was expecting to see low battery and gas detected.
Thank you team for looking into it!
Edited by MarcinWarp
Aqara Vibration sensor is now working
Exposes Temperature and Vibration sensors and battery status. I have tested the vibration sensor as a trigger in block scene and it works as expected. Cool down on the vibration sensor is about 60 seconds
W dniu 26.03.2024 o 12:28, sebo napisał:
ZBMINIL2
ZBMINIL2 - nie działa
SNZB-06P
SNZB-06P - działa !
SNZB-06P NIE DZIAŁA. W systemie pokazuje się TYLKO jako zwykły czujnik ruchu. Brak funkcji czujnik obecności c zy radar
Dear All, I purchased this zigbee blinds drive, i can connect it, but it says "Not Configured" .... I tried removing it and adding it again several times, but no luck. in the instructions, it says it works with Tuya.
anybody has a way to make it work please?
On 7/11/2024 at 8:02 AM, RobertL said:
Heiman Smart Fall Detector - ZigBee.
Perhaps this could be a good aid for the well-grown age group and especially if it can eventually be supported by HC3  :-)
Hello, did you test it in HC3?
Where did you buy it?
Thank you.
Have not bought and tested this.
Purchases can possibly be made here:
/monthly_2024_11/image.png.f5ee31d4f13c0c59d7145c107551341c.png" />
Aqara Wireless Mini Switch T1 is not correctly recognized by HC3 v5.170.13
Please support it.
Edited by naboo
I have an HC3 hub.
/monthly_2024_11/pntz54-4-800-800-tinified.webp.58e7cb3695e7c9e400d4530b9b453ef7.webp" />
It does not work.
10A/16A Tuya WiFi Zigbee Mini DIY Breaker Mini inteligentny moduł włącznika światła przekaźnik 1/2/3/4 Gang 2-drożne sterowanie dla Alexa Google Home
Zigbee 10A 4gang
It works as expected – even the power consumption is displayed.
It works.
Loginovo ZG-101ZL
It does not work.
Temperature and humidity sensor with clock
It works.
Wall switch 2/Gang  Without neutral wire
It works.
recognizes correctly and allows you to control it
MOES ZigBee RF Smart Curtain Switch
It does not work.
Soil tester temperature and humidity meter
It does not work.
Zigbee 3.0 Intelligent Pir Motion Sensor
It works.
16A Tuya Zigbee 3.0 Mini Smart DIY Switch 1 Way Control Smart Home Relay Automation Breaker
It works.
Sensor for windows, doors
It works.
Human presence motion sensor with luminance detection
It does not work.
It does not work.
It works.
scene switch
It does not work.
20A smart plug
It does not work.
Edited by Leo24
Maybe it's stupid question, but I am struggling with adding door sensor to HC3. I have Aqara door sensor MCCGQ11LM, do I need to have Aqara hub to pair it e.g. Aqara Hub E1?
@XiaoTu
In a comment from April 14, 2022 here, someone already tried this device and told it was working :) So no, it should be possible to bind them.
