  • 9
List of Zigbee devices - users for users
K.Drozynski
Dear users,
We know that you are eager to share your thoughts regarding all Zigbee devices that you have. With so many Zigbee devices available on the market it would extremely difficult to prepare a complete list of supported Zigbee devices which would  include useful remarks.
For this reason we would like to encourage you to share your thoughts with other community members - let's make this a list of tested Zigbee devices created by users for users.
As correctly pointed out by @petergebruers (kudos to you) "A nice list for Zigbee2MQTT already exists, complete with picture, reset procedure(s) and quirks:
So we can add one of those 2149 devices to our HC3, test its behaviour and report back with a link to the EXACT same device.
It is important to link to the exact same devices as the one you tested because there are many lookalikes..."
Regards
  • Like 7
Aqara Temperature and Humidity Sensor   WSDCGQ11LM
Working :)
TuYa ZS06 doesn't work - once paired, appears as "Not configured" 😞
Ikea E1812 Tradfri button doesn't work, appears as "Not configured" and reports battery 0%
Hello, Xiaomi Mi Temperature and Humidity Monitor 2 after converting from bluetooth to zigbee, actually works perfectly well on Fibaro HC3.
Got one after I found the tutorial for converting, that actually is just a flashing.
Im not sure about the signal range it has after the converting but the temperature sensor is really cheap.
So far got it in the refrigerator and works smoothly 😂
if you are interested instruction you ll find here:
some one managed to add switch and get the consumption to work on Sunricher SR-ZG9101SAC-HP-SWITCH-B ?
Managed to add it but shows no consumption.
On 7/20/2023 at 12:22 PM, silvinnio said:
Tuya soil moisture monitor QT-07S  - not working
Added to the HC3 but showing only parent component.
 Qt-07S now show Temperature, but not the moisture :(
Smart ZigBee LED Gu10 Gledopto RGB CCT PRO MiBoxer GL-S-006P
Works nicely..
Only thing that needs to be mentioned, that the bulb changing statuses are not reported back to Fibaro when action is called on the bulb from other source / like its own remote controller.
On 6/28/2022 at 1:01 PM, hibiny said:
Tuya co2 sensor
Don't work. Console say: Device added to network and silence
Hello, any news since latest firmware 5.150.15 ?
Thanks.
Philips Hue White Ambiance E27 1100.
1055 lumen at 4000K, 806 lumen @2700K.
Can't match exactly to an mqtt bulb.
Works fine.
Paul
Philips Hue White Ambiance E14 470
470 Lumen @ 4000K
320 lument at 2700K
Works as expected.
Paul
Zigbee 2 channel switch K4 (white)
Shows up as "Not configured"
Is there any workaround to get this working?
On 10/18/2023 at 6:29 PM, PSi said:
OK, the pressure Interface reports values, but the Swagger API shows them as
"type": "com.fibaro.multilevelSensor", "baseType": "com.fibaro.sensor",
can you please change the type to something like pressureSensor for easy identification in QAs?
property "role" defines it as "pressureSensor" - so you can use it :)
Philips Hue outdoor motion sensor
Connects fine directly to the HC3 and provides motion, temperature and light level.
No option to change the settings though - so can't set (eg) sensitivity.
Paul
Yes, I can see this property. I want to query all Pressure Devices from the API but this supports only "type" as parameter and not "role":
api.get('/devices?isTypeOf=com.fibaro.pressureSensor')
api.get('/devices?/api/devices?property=[deviceRole,PressureSensor]') :)
thanks, that worked. but this query is not documented in the Swagger
actually it is, the deviceRole(s) are in swagger, as part of property, all you ahve to do is to combine property filter and value^^
Edited by tinman
Ikea Parasoll
dosent work, gets added. But wont update status when triggered.
/monthly_2024_01/image.png.5ed6e76f2f2140fa3475cad4f84f595e.png" />
Ikea Vallhorn pir sensor.
The Pir function Works!! :D  the switches on the backside dosent seem to do any diffrense on the blind time or the lux readings. the blind time is about 20sec. no repport on battery either.
The lux actually Report! Maybe slow on newly added devices? Tested it now again and it is reporting 123 lux when held under a spotlight 1m below.
Edited by Brors94
Aeotec Range Extender Zi:
Recognized as parent only - unconfigured:
/monthly_2024_01/image.png.ad184b7399b22d3216da3f1440545744.png" />
... but looks like it works.
I have connected one Xiaomi LYWSD03MMC (
) device flashed custom firmware changing blutooth to zigbee (
Without Extender I can't connect it to HC3 - too far. With added Aeotec Extender in the same room - Xiaomi termometer has been recognized by HC3 and works fine.
Intelligent 4-way power strip tint Smart Power Strip from MÜLLER-LICHT,
Item number 404017
It doesn't work, it adds to the control panel, shows the power consumption menu, the on/off switch, but nothing can be done.
