    16 hours ago, Christb said:
    hi @jgab, just for your information new unknown events comming from the energy pannel (pricing parameters):
    Unknown event type:     {"createdMillis":1714161600078,"data":{"newTariff":"CREUSES","oldTariff":"PLEINES"},"type":"ActiveTariffChangedEvent","created":1714161600}
    Unknown event type:     {"createdMillis":1714168800107,"data":{"newTariff":"UNUSED","oldTariff":"CREUSES"},"type":"ActiveTariffChangedEvent","created":1714168800}
    Unknown event type:     {"createdMillis":1714190400190,"data":{"newTariff":"PLEINES","oldTariff":"UNUSED"},"type":"ActiveTariffChangedEvent","created":1714190400}
    Thanks,added the event to fibemu.
    @jgab
    interesting issue - I was using this source code for exporting fqa but in vscode emu there is problem I think with json because InitialProperties is exporting as { } but fibaro expect [ ]
    On 4/29/2024 at 7:21 PM, petrkl12 said:
    @jgab
    Yes, the encoder don't know if the empty table should be [] or {}
    Do
    It marks the value as being an array for future encoding...
    This will probably work in HC3 QAs too as they have the same encoder and json.util.*
    Dear @jgab do you confirm that now the json.util.InitArray(tableName) is now implemented in fibemu?☺️
    I have also a new issue with the code below in a QA which gives a "null" answer when, in a scene, the same code gives a table events for the period:
    allEventHistoryLastWeek = api.get("/events/history?from=" .. fromTime .. "&to=" ..ttoTime.."&eventType=DevicePropertyUpdatedEvent&objectType=device&numberOfRecords=100000")
    print("line 60 _ ",json.encode(allEventHistoryLastWeek))
    in the DEBUG CONSOLE, I get :
    [17.05.2024] [11:00:58] [DEBUG ] [QUICKAPP5000]: ------- QA - version v 0.1 , Limitation of Events History Id: 5000 --------
    [17.05.2024] [11:00:58] [DEBUG ] [QUICKAPP5000]: Query the HC3 history fromTime 10-05 00:00:00 toTime 17-05 23:59:59
    [17.05.2024] [11:00:58] [DEBUG ] [QUICKAPP5000]: line 60 _ null
    [17.05.2024] [11:00:58] [DEBUG ] [QUICKAPP5000]: allEventHistoryLastWeek is not a table
    Is it because this API request is not implemented in fibemu or do I have made a format error for QA implementation?
    Yes, event history is not implemented in emulator, add "hc3" at the end of the api.get to get it from the hc3 direct. (like in the export example in the previous post)
    my VSC Fibaro emulator stopped working with the following info:
    It was working fine hour ago. All I did unusual was deleting browser cache...
    config.json contains proper address, login and password.
    I cannot bring it to life again.
    Can anyone help?
    Can anyone help?
    Can you add this to __init__.py around line 84 in .vscode and see if it solves your problem?
    It forces hostname to "" before calling socket.gethostbyname()
    If it is the problem I can add a workaround for it in the code...
    The problem you may have is that socket.gethostname returns nothing as it doesn't manage to resolve your hostname.
    Did you change connection from wifi to ethernet? or lost connection?
    It's usually good to have the entry
    in /etc/hosts - do you have that?
    Edit:
    The problem you have is that the dns resolvent don't report your pc name. So, something strange with your dns.
    Setting hostname to "" will report back the ip 0.0.0.0, which makes it kind of work but you can't make calls back from the HC3 to the emulator.
    I pushed a new version of __init__.py that logs your hostname and IP at startup. Try to configure your Mac so that you get a hostname back and the local IP address..
    Dear Jan,
    thank you for answer. I've pulled new __init__.py - unfortunately, no help...
    The hostname gives the following:
    /etc/hosts:
    IP and DNS addresses cames from DHCP server, but absolutely nothing has changed there.
    Prior the problem appears, I've also changed the iCloud password, but I think it has nothing to do with the problem...
    Everything other works on the computer.
    Does it prompt you the solution?
    Edited by Łukasz997
    6 minutes ago, Łukasz997 said:
    Dear Jan,
    /etc/hosts:
    I pushed a new __init__.py that does a little bit better job trying to log- what does it report when the emu starts up?
    Googling it there seems to be a couple of solutions for macOS.
    1. If you have VPNs enabled there seems to be an issue - solution see 3.
    2. Enabling file sharing or some other network service in macOS will assign it an internal DNS entry. -- try that
    3. Adding
    to your /etc/hosts
    3. Adding
    to your /etc/hosts
    It is working again OK and I hope it remains working.
    I only pulled new __init__, nothing more.
    Thank you very much for help.
    A remark I would like to share is: how thin is the thread all this is hanging on...
    What IP address does it log in the vscode console when the editor starts up? 0.0.0.0 ?
    When you start the lua code the address is:
    When editor (at VSC launch?) start - I don't know where to find it. Terminal shows nothing new at start.
    Ok, you get Host ip 127.0.0.1
    Are you connected to a local network and have a local ip address? like 192.168.x.x ?
    It would be better if it could get that address.
    If you are connected, try starting file sharing on your Mac - then I think you will get an address...
    You can do
    to see what ip addresses you have assigned
    Yes, I always have the local ip address: 192.168.2.125
    It was the same when VSC emu does not work - I've checked it.
    It's obtained from DHCP - which is Mikrotik firewall/router in my home. On Mikrotik it's set to be static for comp MAC address.
    On the way to mac there's a router (completely stupid) and a mesh (not stupid), but acting as a access point only.
    VPN - present, but not in use with local connections, only remote.
    So it is still something else, not IP. But it still works again :)
    For api.get,api.post,api.put, and api.delete we can add "hc3" as an extra last argument to pass the request to the hc3 instead of the emulator taking care of it.
    It is useful for api calls that the emulator hasn't implemented.
    However, it can be a bit annoying to condition the code with "if fibaro.fibemu then ..."
    So, now we can declare the APIs that should pass through to the HC3 with
    --%%passThrough=<api pattern>
    We can declare as many as we will (but one declaration per pattern)
    The pattern should be a valid lua string.match pattern
    Ex.
    This will pass alarm try arm to the hc3.
    Ex. api.get("/alarms/v1/partitions/777/?actions/tryArm
    We can also put them in config.json
    and they will be merged with patterns declared in the QA file
    Dear @jgab, just to confirm my understanding, instead of :
    allEventHistoryLastWeek,erreur = api.get("/events/history?from=" .. fromTime .. "&to=" .. toTime.."&eventType=DevicePropertyUpdatedEvent&objectType=device&numberOfRecords=100000","hc3")
    I need to add in initial declaration:
    -%%passThrough=/events/history?from=[%d]&to=[%e]&eventType=DevicePropertyUpdatedEvent&objectType=[%f]&numberOfRecords=[%g]
    and then in the code:
    api.get("/events/history?from=" .. fromTime .. "&to=" .. toTime.."&eventType=DevicePropertyUpdatedEvent&objectType=device&numberOfRecords=100000")
    OK?
    Yes, it’s enough to do
    --%%passThrough=/events/history
    and it will match all events/history commands
    With the suffix ,"hc3" in the code below I got the table of the 1657 events:
    DEBUG CONSOLE:
    [19.05.2024] [15:36:17] [DEBUG ] [QUICKAPP5000]:Query HC3 history from: 19/05/24 00:00:00 to 19/05/24 23:59:59
    [19.05.2024] [15:36:17] [DEBUG ] [QUICKAPP5000]: line 146 _ erreur: 200
    [19.05.2024] [15:36:17] [DEBUG ] [QUICKAPP5000]: Number of all events for this period: 1657
    When I add the --%%passThrough=/events/history and suppress the ,"hc3"  at the end I have an error:
    allEventHistoryLastWeek,erreur = api.get("/events/history?from=" .. fromTime .. "&to=" .. toTime.."&eventType=DevicePropertyUpdatedEvent&objectType=device&numberOfRecords=100000")
    DEBUG CONSOLE:
    [19.05.2024] [15:29:14] [DEBUG ] [QUICKAPP5000]: line 146 _ erreur: 500
    [19.05.2024] [15:29:14] [DEBUG ] [QUICKAPP5000]: allEventHistoryLastWeek is not a table
    Just to inform - file sharing gives no change, still 127.0.0.1
    But emulator is working OK.
    I have forgotten to update fibemu first, now all working 😐
