There is still an issue with the HC3 connection, I have now tis type of error after few minutes:
Platform is win32
Web server port 5004 status 10061
Loading
Loaded
Waiting for debugger to attach...
Debugger attached
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: Fibemu v0.41
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: Web UI :
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: old Web UI :
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: API Doc:
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: API EP :
[07.02.2024] [09:42:19] [SYS   ] [boot   ]: QA emulator started
[07.02.2024] [09:42:19] [SYS   ] [install]: QA 'examples\QA_UI.lua'
[07.02.2024] [09:42:19] [SYS   ] [resource]: refresh 'devices'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5000
[07.02.2024] [09:42:22] [SYS   ] [QUICKAPP5000]: Running 'main'
[07.02.2024] [09:42:22] [DEBUG ] [QUICKAPP5000]: Started 5000
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:5000 prop:'quickAppVariables' val:[{"name":"test","value":"HELLO"}]
[07.02.2024] [09:42:22] [SYS   ] [resource]: refresh 'globalVariables'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:354 prop:'value' val:18.3
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/binarySwitch.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5001
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/binarySensor.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5002
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/multilevelSwitch.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5003
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/multilevelSensor.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5004
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/temperatureSensor.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5005
[07.02.2024] [09:42:22] [SYS   ] [install]: QA '.vscode/emufiles/lua/devices/humiditySensor.lua'
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DeviceCreatedEvent ID:5006
[07.02.2024] [09:42:22] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:354 prop:'lastChanged' val:1707295015
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5001]: Running 'main'
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5002]: Running 'main'
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5003]: Running 'main'
[07.02.2024] [09:42:23] [DEBUG ] [QUICKAPP5003]: Turned off
[07.02.2024] [09:42:23] [DEBUG ] [QUICKAPP5003]: Set value 0
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5004]: Running 'main'
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5005]: Running 'main'
[07.02.2024] [09:42:23] [SYS   ] [QUICKAPP5006]: Running 'main'
[07.02.2024] [09:42:27] [DEBUG ] [QUICKAPP5004]: onAction:  {"args":["batteryLevel",50],"deviceId":5004,"actionName":"updateProperty","type":"onAction"}
[07.02.2024] [09:42:27] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:5004 prop:'batteryLevel' val:50
[07.02.2024] [09:42:27] [DEBUG ] [QUICKAPP5004]: onAction:  {"args":["dead",true],"deviceId":5004,"actionName":"updateProperty","type":"onAction"}
[07.02.2024] [09:42:27] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:5004 prop:'dead' val:true
[07.02.2024] [09:42:33] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:399 prop:'lastChanged' val:1707295025
[07.02.2024] [09:42:33] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:399 prop:'value' val:93
[07.02.2024] [09:42:33] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:401 prop:'lastChanged' val:1707295026
[07.02.2024] [09:44:20] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:222 prop:'lastChanged' val:1707295131
[07.02.2024] [09:44:21] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:229 prop:'value' val:22.1
[07.02.2024] [09:44:22] [SYS   ] [refresh]: DevicePropertyUpdatedEvent ID:229 prop:'lastChanged' val:1707295131
Exception in thread Thread-2 (refreshRunner):
Traceback (most recent call last):
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connection.py", line 198, in _new_conn
    sock = connection.create_connection(
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\util\connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\socket.py", line 962, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 11001] getaddrinfo failed
The above exception was the direct cause of the following exception:
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connectionpool.py", line 793, in urlopen
    response = self._make_request(
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connectionpool.py", line 496, in _make_request
    conn.request(
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connection.py", line 400, in request
    self.endheaders()
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\http\client.py", line 1289, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\http\client.py", line 1048, in _send_output
    self.send(msg)
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\http\client.py", line 986, in send
    self.connect()
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connection.py", line 238, in connect
    self.sock = self._new_conn()
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connection.py", line 205, in _new_conn
    raise NameResolutionError(self.host, self, e) from e
urllib3.exceptions.NameResolutionError: <urllib3.connection.HTTPConnection object at 0x000001F46AE06710>: Failed to resolve 'hc3-00006080' ([Errno 11001] getaddrinfo failed)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\adapters.py", line 486, in send
    resp = conn.urlopen(
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\connectionpool.py", line 847, in urlopen
    retries = retries.increment(
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\urllib3\util\retry.py", line 515, in increment
    raise MaxRetryError(_pool, url, reason) from reason  # type: ignore[arg-type]
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='hc3-00006080', port=80): Max retries exceeded with url: /api/refreshStates?lang=en&rand=0.09580020181569104&logs=false&last=306903 (Caused by NameResolutionError("<urllib3.connection.HTTPConnection object at 0x000001F46AE06710>: Failed to resolve 'hc3-00006080' ([Errno 11001] getaddrinfo failed)"))
During handling of the above exception, another exception occurred:
  File "C:\Users\ASUS\Documents\fibemu\.vscode\emufiles\fibenv.py", line 107, in refreshRunner
    resp = requests.get(nurl, headers = options['headers'], timeout=30)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\api.py", line 73, in get
    return request("get", url, params=params, **kwargs)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\site-packages\requests\adapters.py", line 519, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='hc3-00006080', port=80): Max retries exceeded with url: /api/refreshStates?lang=en&rand=0.09580020181569104&logs=false&last=306903 (Caused by NameResolutionError("<urllib3.connection.HTTPConnection object at 0x000001F46AE06710>: Failed to resolve 'hc3-00006080' ([Errno 11001] getaddrinfo failed)"))
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\threading.py", line 1045, in _bootstrap_inner
    self.run()
  File "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.11_3.11.2032.0_x64__qbz5n2kfra8p0\Lib\threading.py", line 982, in run
    self._target(*self._args, **self._kwargs)
  File "C:\Users\ASUS\Documents\fibemu\.vscode\emufiles\fibenv.py", line 123, in refreshRunner
    except exceptions.TimeoutError as e:
AttributeError: module 'requests.exceptions' has no attribute 'TimeoutError'
[07.02.2024] [09:59:50] [DEBUG ] [QUICKAPP5000]: UIEvent:  {"eventType":"onReleased","elementName":"test","deviceId":5000,"values":[],"type":"UIEvent"}
[07.02.2024] [09:59:50] [DEBUG ] [QUICKAPP5000]: B pressed
    Platform is win32
    Loading
    Loaded
    Debugger attached
        conn.request(
        self.endheaders()
        self.send(msg)
        self.connect()
        self.run()
    Fixed in latest push. I've become a bit lazy working with strictly typed languages so I thought I would get a compile warning when using TimeoutError instead of Timeout - but python is not so strict... .
    6 hours ago, ClaudeH said:
    Hey @jgab,
    Don't know what happening, I can use the fibemu in multirootfolder mode, launching via the debug, and but none of the debugging feature,breakpoints, watches, works.
    Running on windows, so python seems all ok and local lua debugger extension installed.
    Even simpe lua is not debugging.
    Any idea where I should try to seek for the issue
    I will investigate and come back...
    @jgab Jan i am pretty list when, where to use brackets and semicolons when using if else inside  a rule. I am not using || >> format becuase i am even more lost there, but i want to do some if else statements. this is a test code, that doesnt throw error without <if else> part, but throws error when there is a <if else? part
    Hey @jgab,
    Are you on PC or Mac?
    I've pushed a fix that I think will work for both. Now (hopefully) the debugger will get the right path to the source file.
    Multi-root is a bit tricky and I haven't understod all nuances yet...
    The last example throws a parser error because there is no statements in the then or the else branch.
    I could allow for empty branches, but at the moment it's not.
    This doesn't
    Hi Jan,
    Im' using a Windows 11 and debugging is back 😀
    Many thanks !
    Edited by chelson
    41 minutes ago, chelson said:
    Hi Jan,
    Many thanks !
    Good, I believe that multi-root is the future for project setups...
    hi Jan,
    I have found a new strange issue:
    When I am using :
    571        cZd=api.get("/panels/climate")
    572        print(json.encode(cZd[1]))
    I have printed the correct table of key [1].
    But when I am trying to get the details of climate zone 1 like:
    576          currentZoneDetail = api.get("/panels/climate/"..ZoneId)-- why it does not work now?? get null...
    577          __print(json.encode(currentZoneDetail))
    I am getting a "null" response and then the QA crashes when any element of currentZoneDetails is requested.
    [14.02.2024] [20:07:20] [DEBUG ] [QUICKAPP5000]: connected to HC3, ZoneId: 1
    null
    [14.02.2024] [20:07:21] [ERROR ] [QUICKAPP5000]: onAction: QuickApp:manualButton(...):attempt to index a nil value (global 'currentZoneDetail'), C:\Users\ASUS\Documents\fibemu\test\Manual_Heating_Override_Vs.lua:getClimateZoneDetails:577
    null
    null
    even the direct api call for zone id=1 api.get("/panels/climate/1") gives also a null result.
    I AM SURE THAT THIS API COMMAND  WAS WORKING PERFECTLY 1 WEEK AGO...
    Were can be the problem?
    note: in the first declaration of the QA, I load fibaroExtra.lua
    --%%file=examples/fibaroExtra.lua,fibaroExtra
    The emulator doesn't have an emulation of panels/climate/<id>
    If you do
    local res, err = api.get("/panels/climate/1")
    you see that the err is 500.
    If you want to work against the HC3 climate panels do
    api.get("/panels/climate/1","hc3")
    and condition it with if fibaro.emu exists....
    Everything working fine now
    Thank you.👍
    I have been a little to quick to say everything OK: I have now the same issue with api.put(“panels/climate/”..zoneID, tableData).
    I tried api.put(“panels/climate/”..zoneID, taleData,”hc3”) but it seems to not work: have you a solution?
    Also api.get("/devices/267") or api.get("/devices/267","hc3") are not working as well .
    By what type of lua code I need to use for getting what I want?
    Edited by Christb
    add 2 lines
    What do you get as result?
    With the "hc3" flag the command is passed directly to the HC3 so the result is coming from the HC3.
    With your format (local a,b = api...) I am getting
    nil 501
    Ok, now I see it. The path is missing a slash prefix
     api.put(“/panels/climate/”..zoneID, tableData,"hc3")
    Sorry, the missing "/" was a typing error, the actual lines are :
        print(json.encode(climZTable))
    local a,b = api.put("/pannels/climate/"..ZoneId,climZTable,"hc3")
    print("c1; ",tostring(a),tostring(b))
    and I am getting still:
    [17.02.2024] [11:32:45] [DEBUG ] [QUICKAPP5000]: c1;  nil 501
    Is it possible to get more detailled info about the error?
    Do you think that the error 501 may come from a non compliant HC3 format of the climZTable?
    What is strange is that using the file "climZTable" in the Swagger, it is accepted (Code 200) and changes I have made in the file are accepted.
    Edited by Christb
    How does the table look?
    What is ZoneId?
    Could you also set
    so we see the request (unfortunately not the payload)
    [17.02.2024] [12:38:41] [DEBUG ] [QUICKAPP5000]: climZTable:  {"created":1707927223,"mode":"Manual","active":true,"properties":{"friday":{"evening":{"temperatureHeating":21,"temperatureCooling":23,"hour":17,"minute":0},"day":{"temperatureHeating":24,"temperatureCooling":26,"hour":10,"minute":15},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":23,"hour":22,"minute":0}},"saturday":{"evening":{"temperatureHeating":21,"temperatureCooling":23,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":23,"hour":22,"minute":0}},"monday":{"evening":{"temperatureHeating":21,"temperatureCooling":23,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":23.5,"hour":22,"minute":0}},"handTimestamp":1711769920,"wednesday":{"evening":{"temperatureHeating":21,"temperatureCooling":24,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23.5,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":24.5,"hour":22,"minute":0}},"handSetPointHeating":21,"vacationEndTime":1709765940,"vacationSetPointHeating":17.5,"handSetPointCooling":24,"currentTemperature":22.3,"mode":"Heat","vacationMode":"Heat","currentTemperatureHeating":21,"tuesday":{"evening":{"temperatureHeating":21,"temperatureCooling":23.5,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":24,"hour":22,"minute":0}},"calculationStrategy":"avg","devices":[267],"vacationStartTime":1707174000,"temperatureSensors":[209],"handMode":"Heat","vacationSetPointCooling":24,"incompatibleDevices":[],"currentTemperatureCooling":24,"thursday":{"evening":{"temperatureHeating":21,"temperatureCooling":23,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":23,"hour":22,"minute":0}},"sunday":{"evening":{"temperatureHeating":21,"temperatureCooling":23,"hour":17,"minute":0},"day":{"temperatureHeating":21,"temperatureCooling":23,"hour":9,"minute":0},"morning":{"temperatureHeating":21,"temperatureCooling":23,"hour":7,"minute":0},"night":{"temperatureHeating":21,"temperatureCooling":23,"hour":22,"minute":0}}},"modified":1707927223,"id":14,"name":"Vestibule"}
    [17.02.2024] [12:38:41] [DEBUG ] [QUICKAPP5000]: c1;  nil 501
    [17.02.2024] [12:38:41] [DEBUG ] [QUICKAPP5000]: ZoneId:  14
    Hi Jan,
    I have tested the same function code in TQAE (zeroBrane) and I got the same resul: nil, 501 and the "climateZTable" data are also accepted in Swagger...
    Again my fault, my huge fault...
    The comand to work has to be 🙂:
    local a,b = api.put("/panels/climate/"..ZoneId,climZTable,"hc3")
    previously I wrote: api.put("/pannels/... then 501 error is expected☹️
    dear JGAB,
    it seems that the json function: local AutoTemp = json.util.InitArray({}) is not yet accepted; I got error:
    [18.02.2024] [11:21:05] [ERROR ] [QUICKAPP5000]: :onInit() :attempt to index a nil value (field 'util'), C:\Users\ASUS\Documents\fibemu\examples\QA_UIselect.lua:_onInit:124
    --> C:\Users\ASUS\Documents\fibemu\examples\fibaroExtra.lua:onInit:111
    --> @.vscode/emufiles/lua/quickApp.lua:_init:194
    --> C:\Users\ASUS\Documents\fibemu\examples\fibaroExtra.lua:init:117
    --> @.vscode/emufiles/lua/class.lua:QuickApp:41
