9 minutes ago, jgab said:
So there is an error in the file so the QA restarts when you start it up. That can explain why your buttons don't work...
I'm a bit disappointed that there is no error message though...
Can you PM me the HouseCheck QA (the .fqa) so I can have a look at it?
The error could be that there is no QA variables as you expect.... but could also be something else.
I will send teh QA in PM, meanwhilte check on this pls..
This is coming with Fibemu i think
The lspaddon folder, fibaro.lua file
This is incorrect definition of fibaro.getName...so my QA debigging show it as error..It says fibaro.getName should return integer..I think there is a bug, because in the picture you can see,that it defines fibaro.getName as it should return device's room ID
/monthly_2024_01/image.png.6f537dc4e37bfff472f6dbde84de5750.png" />
    Yep, thats a bug - will fix. (should return string - the name)
    So I got 2 errors.
    [04.01.2024] [23:25:05] [ERROR ] [QUICKAPP1469]: :onInit() :attempt to index a nil value (global 'self'), dev/HouseCheck_helpers.lua:checkGlobals:147
    There is no self available here. Change to
    quickApp:setSilentmode(true, "Missing speaker IPs. Switching to silent mode.")
    Secondly, you call fibaro.cancel often with a nil reference. If you want/need to do that, redefine fibaro.cancel to
    function fibaro.cancel(ref) if ref then clearTimeout(ref) end end
    Having done that I get the following log output
    Which I guess is kind of reasonable as I haven't setup the QuickApp variables or access to the other devices on the HC3...
    and when I press Time-
    I get
    an error because local h1 is nil in the subsTimefunction, line 32
    6 minutes ago, jgab said:
    So I got 2 errors.
    I get
    Okay, will clear the bugs, and retry tomorrow..many thanks
    In general, the Task that downloads and unpacks a QA residing on the HC3 is there just for already existing QAs that I want to continue to develop in fibemu (or when I receive a fqa from someone in the forum and wants to inspect/test the QA in fibemu)
    After the download and unpack, that becomes the master code for the QA. It is developed and tested in fibemu. It could also be pushed to github for revision control.
    When happy with the QA's behaviour in fibemu then it can be uploaded back to the HC3 with the update Task... but it's just the very last verification step. If it works in fibemu it usually works on the HC3 too...
    In 99.999% of the cases I start to develop QAs in fibemu from scratch.
    In the emulator it's easy to create "fake devices" to test against.
    Adding this in HouseCheck.lua around line 40
    creates the simulated devices of all the devices in alldeviceIdsInUse so that doesn' generate an error anymore...
    I also see that the task download and unpack seems to have a bug as the HouseCheck.lua file created has 2 versions of
    function QuickApp:onInit() in the code - removing the last seems to work...
    ...which is now fixed in the latest version of fibemu.
    Now running it (with fake devices and the fixes)
    by adding these quickApp vars to HouseCheck.lua
    and this setup code in HouseCheck.lua :onInit (after alldeviceIdsInUse been defined)
    We then get the log
    All the Installs and "Running main" is the fake devices starting up (they are implemented as QuickApps)
    Because it was in demo mode it didn't turn off device 111 so we get the message.
    Maybe demo mode should not do that...?
    Now it only gives an error when pressing the Time- button in the UI. I believe it assumes that the TTS is setup...
    With the QA variables setup the emulator should be able to call out to nest etc...
    @jgab Jan, i am trying to create a QA from scratch, to get more familiar with deriectoves and other stuff.
    I set up 3 buttons a label and QA variables,
    Everything seems to be okay, but the label doesnt update in webbrowser on buttonclick. SHould there be any other directive? I did not find any in the documnetation.
    Yes, demo mode does not act on device, just mimcs it, and debugs.
    The old UI at :5004/ needs a reload of the page to see the changes (there is also a hack that reloads the page every x seconds). The old UI will soon be removed.
    Instead, use the new (alt.) UI at
    It updates automatically when you do a self:updateView(....)
    I'm currently hacking on the new UI to support the new select element and switch.
    If you set autoui=true in config.json it will auto reload the old UI every 2s.
    ...but the new (alt.) UI is the preferred approach these days.
    Okay, i will use the new UI..I didn't know about it. Now the update works..Thanks
    @jgab Jan, is there any option to trigger a function at a certain time, or at some custom event trigger wihout using fibaroextra, ER5 or using loops?
    I think the new subscription method doesnt work for times.. So i dont need to use fibaroextra in my VScode developoment just for one sinlge time event
    Should it also run on the HC3 or is it just for testing in VSCode?
    The HC3 only have the setTimeout/setInterval functions and you need to buid something ontop of that to time at specific times and not drift.
    The sourcerTiggerSubscriber can post events at specific times just like fibaroExtra, but is a bit smaller.
    Besides that there has been a multitude of timer-helper functions in the forum over the last years.
    If you just want something that runs at a specific time each day you can use
    Ex.
    Ex.
    It should run on HC3 too
    @jgab  Jan, when uploading or updating a QA from VS code, how can we upload/uppdate a QA that consist of multiple files. I know if there is one file, we can set . inside the task parameter textbox, but what to do when there is more files in QA. Will the directives handle the upload? So the task will know what files to update/upload when there are linked in directives with %%file = ... ?
    Edited by Neo Andersson
    Yes, it will copy the QA and all it's "linked" QA files --%%file=
    to the QA on the HC3 with the same --%%id=x as set in the main QA file.
    It will delete files on the HC3 QA that is not valid anymore, so make sure that all files are specified with --%%file=....
    It will then update the UI structure of the HC3 QA from the headers definition in the main QA.
    The '.' in the task parameter textbox is just to say that you want the current file in focus in the editor (I have many times made the mistake and had some other editor buffer in focus.... 😕 )
    You could also give the filename for the QA file (+ it's "linked" files) but it's usually more convenient to have the relevant QA's buffer in focus.
    v0.40 of fibemu pushed.
    -Lot's of minor bugfixes
    -Now support the select UI element
    see examples/QA_UIselect.lua for an example of use.
    Header definition looks like
    support self:updateView(<id>,"options",<options table>)
    support self:updateView(<id>,"selectedItem",<item value>)
    creates UI events with event.values[1] == selected item value
    New header directive --%%merge
    --%%merge=file<1>,...file<n-1>,file<n>
    will take a comma separated list of files and create a file with the name of the last file <n> that consists of the other files <1>...<n-1> merged together.
    In the example above it will create dev/OST.lua that consists of lib/OS.lua and lib/Table.lua (in that order).
    This means that we can automatically assemble a library file with pieces consisting of other files dynamically and the include that file with the --%%file directive.
    The advantage is that we create a new file that allow us to debug the file in VScode too.
    With this I'm rethinking my use of library files. I used to have one big file, fibaroExtra.lua, that consisted of everything. Now I'm building up a library of smaller files that I include with the merge command into a tailor-made library for the QA I'm developing.
    • 3 weeks later...
    I noticed the following "Unknown Event Type"s this morning. I looked at the fibemu code and saw there's a lengthy definition of the event types you've uncovered. Not sure if you are trying to add to this list as you discover more, but here's the screenshot of what I saw. If you need more info, just let me know.
    Thanks, I will add them so the log isn't spammed. Unsure if it's worth creating sourceTriggers out of them though.
    Yeah, you strike me as they type who would include stuff just to be complete. 😁
