    New feature: zombie
    Will instruct the QA on the HC3 with the deviceId 786 to send all its onAction and UIEvents to the QA running in the emulator - when the emulator is running.
    The emulator will ping the HC3 QA every 5s and if the HC3 QA don't get a ping it will revert to it's normal behaviour.
    The emulated QA in the emulator and the "zombified" QA on the HC3 may have different IDs.
    The emulator will make sure that when the emulated QA updates properties and UI views it will also update the HC3 QA.
    The advantage is that we have a QA on the HC3 that other QAs can interact with but we get all events to the emulator and can debug the code there.
    It also works with QuickAppChildren "automatically". Emulator created QuickAppChildren will be reflected on the HC3, and when the emulated QA starts up it will create copies of the existing children on the HC3 for the zombie, if any.
    Implemented the new switch button. Declaration looks like
    It gets "true" and "false" in event.values[1] and can be set by self:updateView(id,"value","true") or  self:updateView(id,"value","false")
    On 1/25/2024 at 5:36 PM, jgab said:
    New feature: zombie
    @jgab
    I'm trying to migrate to VSCode as there is zombie function now 👍
    How to translate this original setting to your new setup in VSCode:
    (ID 1008 is real QA in HC3 and I want to have everything to call to (or from) HC3 incl. global vars, QA vars, other QAs, children QAs, ...)
    Edited by petrkl12
    13 hours ago, petrkl12 said:
    @jgab
    Zombie is not really there yet.
    It's missing the concept of
    Need to think about how to do that - and not sure if the old way is the way to go.
    For the TQAE proxy concept, the proxy was autogenerated by TQAE and the master code was always the code in TQAE.
    For zombie model kind of creates a hybrid as we debug the "real" QA running on the HC3 using a copy running in fibemu/TQAE.
    My thinking was the following workflow
    1. We have the real version of the QA on HC3,
    2. using a vscode command to download the QA code from the HC3
    3. debug version in vscode by temporarily making HC3 QA a zombie
    4. when done, use a vscommand to update the HC3 QA with the new code
    For this to be really smooth, I'm not sure all pieces are in place yet...
    For the UI we have kind of 2 situations.
    We would like to use the Web QA UI editor for complex UIs...
    We would like to use fibemu/TQAEs UI declarations for creating layouts that are not possible in the UI builder (and it's difficult for getting a feeling for the layout - however, the fibemu QA UI we interface is getting quite ok)
    Yes, it could work
    For me the old concept of proxy was also OK :) and I was able to debug the complex QAs ie. for Philips Hue with a lot of separate QAs and also childern QAs with complex UI works without any issues ...
    Edited by petrkl12
    On 2/3/2024 at 11:51 AM, petrkl12 said:
    Yes, it could work
    vscode gives a lot of new possibilities that I'm exploring.
    Just did a first version of an vscode extension that "mounts" QAs and Scenes as a filesystem in vscode's file explorer.
    Try it by installing this extension in the extension view context menu
    Run hc3fs.workspaceInit in the command palette.
    Autosave is turned off by default and file are synched to the HC3 when explicitly saved.
    Here is a video of some of the features...
    An idea is to combine it with the emulator to run the files...
    OK, thanks
    but some errors with path. What I should change?
    /monthly_2024_02/image.png.fba1ff4b5e6681555447778d14b1c184.png" />
    Ok, it seems like the extension behaves differently outside the extension development environment.
    Go to extension settings or go to settings and search for 'hc3fs'
    Set the dir to a place where you have a .vscode, typically a workspace folder.
    I have set it to "hc3fs.dir": "/Users/jangabrielsson/Documents/dev/HC3fs/hc3fs",
    Anyway, I expect to come out with a 0.0.2 tomorrow as I found some issues when I packaged it.
    @jgab
    in this
    you should add this step
    del launch.json
    before mklink /H launch.json ..\..\fibemu\.vscode\launch.json
    what should be in local setting in items user and pwd? (for HC3 is clear)
    I have tried these paths - but no success - still same error - maybe I dont know how to correctly write absolute path in vscode
    Ok, I removed the dir setting - I don't think it was the right option.
    I've linked v0.0.2 in post
    @jgab
    still same error even with version 0.0.2
    37 minutes ago, petrkl12 said:
    @jgab
    You need to run the command "hc3fs: Setup Workspace" first, to mount stuff.
    If I don't and just run Download fqa I get your error.
    Download fqa should be run from the menu in the file explorer.
    yes - I run:
    first error - fetch failed
    and then error with path
    Next run of hc3fs: Setup Workspace - only error with path
    Could you add more debug mesages?
    Edited by petrkl12
    I linked v0.0.3
    You can look in output->HC3 fslog
    and you have done the settings for the extension?
    /monthly_2024_02/image.png.d25db3f53e9b3b005eb62bc1de77267e.png" />
    still same error
    sorry, I'm new in VSC where is: output->HC3 fslog
    Edited by petrkl12
    1 minute ago, petrkl12 said:
    still same error
    Look at the video in my first post how I show the output (in terminal OUTPUT->and then the pop-up that is set on Tasks as defaults
    So I tried it in WIn11 and it worked. Sometimes Win11 can be tricky with url access rights...
    output - HC3 fslog
    output - Extension host> error
    2024-02-04 12:48:38.257 [error] TypeError: Cannot read properties of undefined (reading 'path')
        at HC3.downloadFQA (c:\Users\xxxx\.vscode\extensions\[email protected]\out\hc3.js:297:43)
        at c:\Users\xxxx\.vscode\extensions\[email protected]\out\extension.js:102:13
        at s.h (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:150:175243)
        at s.$executeContributedCommand (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:150:176103)
        at d.S (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:147:5520)
        at d.Q (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:147:5286)
        at d.M (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:147:4376)
        at d.L (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:147:3455)
        at g.value (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:147:2242)
        at r.y (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:80:1902)
        at r.fire (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:80:2119)
        at n.fire (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:105:14073)
        at g.value (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:173:8051)
        at MessagePortMain.<anonymous> (c:\Program Files\Microsoft VS Code\resources\app\out\vs\workbench\api\node\extensionHostProcess.js:173:6331)
        at MessagePortMain.emit (node:events:514:28)
        at Object.emit (node:electron/js2c/utility_init:2:2285)
