    So in the command palette run the command "Python select interpreter"
    That seems to set the pyton.interpreterPath
    It may also solve @Christb problem - select the  interpreter with installed uvicorn...
    10 hours ago, jgab said:
    Ok, pushed the changes
    Let me know if you are missing some functions
    this doesn't work
    /monthly_2024_02/image.png.75a49513182651a29c2970b33b8d840c.png" />
    4 minutes ago, petrkl12 said:
    this doesn't work
    What? Read from the terminal?
    yes, I have some choices
    I tried but nothing happened
    Are you sure that command is correct?
    10 minutes ago, petrkl12 said:
    this doesn't work
    It works if you "Run Without Debugger "
    What is nothing - that the command was not found when running?
    I tried in Win11 - I got the same error, but when I run "python select interpreter" it worked.
    This seems to be a mess...
    I reverted and pushed a launch.json that just runs python3
    Make sure that you pip installed requirements for the global python 3.11 environment that is called when you type python3 in an external shell - or type >Pythin3 in the vscode terminal without an active venv. (it's visible at the left of the terminal prompt (venv) if there is a vent active). To exit the venv type exit, it's like a pushed shell that is exited.
    now it works again OK
    It works but only if there is not any breakpoint.
    You can try to add breakpoint to next row and you will see some interesting behaviour.
    There is also this error during start fibemu
    Edited by petrkl12
    Yes, thats a known problem. Sometimes when python is interrupted, it keeps a process that hangs the port.
    You need to kill the process.
    There is a script in examples/kill-port.ps1 for windows and on macOS it's
    >kill -9 $(lsof -ti :5004)
    Yes, thats a known problem. Sometimes when python is interrupted, it keeps a process that hangs the port. I believe it's uvicorn.
    OK - for others - in windows 11:
    run PowerShell
    set rights for running script: Set-ExecutionPolicy RemoteSigned
    run script in your folder: .\kill-port.ps1 5004
    result should be: SUCCESS: The process with PID xxxxx has been terminated.
    run PowerShell
    added it as a comment in the script
    13 hours ago, Christb said:
    I have made some progress, I do not have anymore the error message for python3; this result after having desinstalled: python, Git and Visual studio and reinstall all.
    For this new installation, I have followed your video step by step and everything went well and as expected but...
    I have now an error when pressing F5 with QA_UI.lua which seems to explain that the server uvicorn is not there:
      File "D:\Mes_documents_perso\St_Loup\St_Loup_Travaux_et_Fournisseurs\Electricit�\Domotique\Domotique_ST_Loup\HC3\Vscode\fibemu\.vscode\emufiles\__init__.py", line 1, in <module>
        import uvicorn
    ModuleNotFoundError: No module named 'uvicorn'
    I tried "pip install uvicorn "and get the following
    PS D:\Mes_documents_perso\St_Loup\St_Loup_Travaux_et_Fournisseurs\Electricité\Domotique\Domotique_ST_Loup\HC3\Vscode\fibemu> pip install uvicorn
    Requirement already satisfied: uvicorn in c:\users\asus\appdata\local\programs\python\python311\lib\site-packages (0.22.0)
    Requirement already satisfied: click>=7.0 in c:\users\asus\appdata\local\programs\python\python311\lib\site-packages (from uvicorn) (8.1.7)
    Requirement already satisfied: h11>=0.8 in c:\users\asus\appdata\local\programs\python\python311\lib\site-packages (from uvicorn) (0.8.1)
    Requirement already satisfied: colorama in c:\users\asus\appdata\local\programs\python\python311\lib\site-packages (from click>=7.0->uvicorn) (0.4.6)
    It seems that uvicorn is installed but not recognised when run from the QA.
    I have found a directory C:\Users\ASUS\AppData\Local\Programs\Python\Python311\Lib\site-packages\uvicorn
    Also in Visual Studio uvicorn is shown in directory Packages as below:
    Again a path issue? but I don't know how to solve it.
    @Christb
    Have you added this %USERPROFILE%\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts to your path in windows 11 ?
    Open the Windows - Setting
    Under System, click on "About"
    Click on "Advanced system settings"
    Click "Environment Variables..."
    The User variables panel shows up on the screen and there is Path (Click)
    Click the New button to add new paths for user
    Add this: %USERPROFILE%\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts
    Click "OK"
    check if path for Python.3.11 is correct for your enviroment -
    in cmd type
    cd %USERPROFILE%\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts
    You can also check it via command PATH in cmd.
    Edited by petrkl12
    If you read the documentation for the "Local Lua Debug" extension used, they say something about Windows can use "communication":"pipes" if they have issue with reading from stdin...
    Yes I did and I have checked path:
    Using cmd I am getting the following result:
    C:\Users\ASUS>PATH=
    C:\ProgramData\Oracle\Java\javapath;
    C:\Program Files (x86)\Intel\iCLS Client\;
    C:\Program Files\Intel\iCLS Client\;
    C:\WINDOWS\system32;
    C:\WINDOWS;
    C:\WINDOWS\System32\Wbem;
    C:\WINDOWS\System32\WindowsPowerShell\v1.0\;
    C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;
    C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;
    C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;
    C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;
    C:\Program Files (x86)\Google\Google Apps Sync\;
    C:\Program Files (x86)\Google\Google Apps Migration\;
    C:\Program Files\Intel\WiFi\bin\;
    C:\Program Files\Common Files\Intel\WirelessCommon\;
    C:\WINDOWS\System32\OpenSSH\;
    C:\Program Files\Git\cmd;
    C:\Users\ASUS\AppData\Local\Programs\Python\Python311\;
    C:\Users\ASUS\AppData\Local\Programs\Python\Python311\Scripts\;
    C:\Users\ASUS\AppData\Local\Microsoft\WindowsApps;
    C:\Users\ASUS\AppData\Local\Programs\Microsoft VS Code\bin
    When I looked to the environment variable I have this:
    /monthly_2024_02/image.png.03de0b0f4f57f52192f2d82ff9798a1d.png" />
    Still the same ModuleNotFoundError: No module named 'uvicorn'
    I changed "c:\users\ASUS\" by "%USERPROFILE%" with no result
    Some steps to try/verify.
    1. You use the version of launch.json that just uses "command" : "python3"
    2. Outside vscode, in a command prompt shell or power shell
    2.1 start python3
          >pyton3
    2.2 Inside pythons prompt, run
          >>>import uvicorn
    Does the import work without complaining?
    Well, I have a very good news today: the QA_UI.lua is now working perfectly as well as the "
    What I have done :
    Desinstall in this order the following programs:
    - Visual Studio
    - Git
    - Phyton
    REBOOT the PC
    Suppress files in user directories: \.vscode and \Microsoft Visual Code
    REBOOT the PC
    Reinstall Python 3.11 from Microsoft Store application
    Then following your video, I have reinstaledl everything.
    The important thing to see when you run pip "install -r requirements.txt" are the yellow warning messages which are copied below (easy to miss them as the results are scrollinq quickly):
    WARNING: The script chardetect.exe is installed in 'C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts' which is not on PATH.
      Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
      WARNING: The script wsdump.exe is installed in 'C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts' which is not on PATH.
      WARNING: The script normalizer.exe is installed in 'C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts' which is not on PATH.
      WARNING: The script uvicorn.exe is installed in 'C:\Users\ASUS\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.11_qbz5n2kfra8p0\LocalCache\local-packages\Python311\Scripts' which is not on PATH.
    So I have open the "Environment variables" window and added this missing path and then F5 with QA_UI.lua worked immediatly.
    All my thanks for your support.
    Now I need read all your post and play with fibemu
    In the debug console I have 2 messages which are not comming from the QA:
     Unknown event type:     {"data":{"oldValue":22.4,"id":5,"newValue":21.8,"unit":"C"},"sourceType":"system","created":1707232284,"objects":[{"objectType":"climateZone","objectId":5}],"type":"ClimateZoneTemperatureChangedEvent","createdMillis":1707232284092}
    and
    Error: HTTPConnectionPool(host='hc3-00006080', port=80): Read timed out. (read timeout=None)
    I am not to worried by the bleu message as it seems to be an information comming from HC3 aboout a climate change temperature but there is not programmed change for zone 5 at that time; I hope it is a change of the mesured temperature.
    The red one is more important: I know that sometimes my HC3 is long to answer to request : is this message reflecting this?
    I had just now this one:
    Connection error: http://hc3-00006080:80/api/refreshStates?lang=en&rand=0.09580020181569104&logs=false&last=7340438
    Exiting refreshStates loop
    Edited by Christb
    add an error message
    What I have done :
    - Visual Studio
    - Git
    - Phyton
    REBOOT the PC
    REBOOT the PC
    and
    Ok, ClimateZoneTemperatureChangedEvent is just an event from HC3 that I haven't seen yet. Added it to the source now.
    The connection error / timeout could be that your HC3 is a bit slow. Looking at the code I was a bit aggressive exiting the loop.
    I pushed a new version that is a bit more forgiving...
    Ok, I will update fibemu
    Just a new one: QA_UI.lua (no change done) running I hav frequently the message below:
    [error] .vscode\emufiles\lua\emu.lua:132: bad argument #2 to 'format' (no value)
    stack traceback:
        [C]: in function 'string.format'
        .vscode\emufiles\lua\emu.lua:132: in field 'syslog'
        .vscode\emufiles\lua\refreshState.lua:319: in field 'logEvent'
        .vscode\emufiles\lua\refreshState.lua:328: in field 'newEvent'
        .vscode\emufiles\lua\emu.lua:697: in local 'h'
        .vscode\emufiles\lua\emu.lua:712: in function <.vscode/emufiles/lua/emu.lua:709>
    I need to restart the QA.
    I did in fact made an unvoluntary change
    Edited by Christb
    stack traceback:
    Thats a bug that appeared when I added the new event. I pushed a fix.
    Hey @jgab,
    Don't know what happening, I can use the fibemu in multirootfolder mode, launching via the debug, and but none of the debugging feature,breakpoints, watches, works.
    Running on windows, so python seems all ok and local lua debugger extension installed.
    Even simpe lua is not debugging.
    Any idea where I should try to seek for the issue
