    But are you running the downloadFQA  function?
    It needs to mount the filesystem first.
    Does the extension map up the QUickApps and Scenes as filesystem in the file explorer of vscode?
    No - press CTRL+Shift+P then insert hc3fs: Setup Workspace + Enter
    result Error
    what is interesting that HC3 fslog is without change original time
    2024-02-04 12:48:37.252 [info] hc3fs says "Hello"
    2024-02-04 12:48:37.374 [info] HC3 version: 5.151.47
    Does the extension map up the QUickApps and Scenes as filesystem in the file explorer of vscode? NO
    Edited by petrkl12
    result Error
    Well, it's persistent so it may be old logs you see
    So Team Viewer was a rat hole for me - I don't have it and trying to install on MacOS is hellish....
    but this error is new every time when command> hc3fs: Setup Workspace is run
    2024-02-04 13:29:05.668 [error] TypeError: Cannot read properties of undefined (reading 'path')
    ctrl+shift+p + typing hc3 showing only these commands but NOT your Setup Workspace - is it OK?
    /monthly_2024_02/image.png.1bf64faaff92dc37c57ecf50f3e05dc4.png" />
    I have also check you source code and it looks that I'm running Download QA - but it is not true somehow my command is changed
    Edited by petrkl12
    So, if I go to the Command Palette Ctrl-Shift-P and do hc3fs: Download .fqa,
    I get exact your error. The HC3.downloadFQA function don't get any argument (that should have a .path arg) and it complains
    However, you should not run that from the Command Palette... (will try to find a way to block it) and only run it from the file explorer context menu
    ....on the other hand you say you get the error when you run Setup WorkSpace...
    If you don't see the command open a new vscode window and open a workspace folder before trying the command
    2024-02-04 13:42:35.009 [error] TypeError: Cannot read properties of undefined (reading 'path')
    at HC3.downloadFQA (/Users/jangabrielsson/.vscode/extensions/[email protected]/out/hc3.js:297:43)
    at /Users/jangabrielsson/.vscode/extensions/[email protected]/out/extension.js:102:13
    Some strange state where it thinks it already setup... try open a new window and open a workspace folder.
    I don't see where it should be in file explorer context menu
    Do you have any screenshot?
    btw. I think you could call init procedure in case that variable path is empty
    Edited by petrkl12
    It's vscode's file explorer (tree view), and only works if you have the remote hc3 fs mounted. (Did you view the video? :-) )
    DownloadFQA only works when a QA is selected in the tree view - otherwise we don't know what to download. When called from the Command Palette it gets null. I will try to disable it from the Command Palette.
    Anyway, this version will have Setup Workspace always enabled...
    I saw video in your first post and UI.lua example works OK :)
    but I'm lost where it should be ...
    Edited by petrkl12
    I have corrected myself:
    in your file extension.js
    /monthly_2024_02/image.png.dfebda3b4bb61a031d8f8c69770229d1.png" />
    Now you can run even via ctrl+shift+p   +  download fqa
    Edited by petrkl12
    But then you mount it when the extension is activated? In what workspaceFolder? The first when you start up vscode?
    The Setup WorkSpace command should add the filesystem to the workspace of your choice...
    because you don't want it always mounted.
    it was mounted when I have first run of any command in ctrl+shift+p  from hc3fs....
    problem was with this. It has to be run earlier to get correct path
    Edited by petrkl12
    OK now I have list of QA and scenes in VSCode and what I can with it in your fibemu?
    Here is v0.0.5 that does a "double mount". It seems to be a known fact that a fsprovider extension is restarted when it mounts a filesystem/workspace.
    Not sure how to do it in a clean way....
    Well, hc3fs and fibemu is not aligned yet ;-) and is 2 separate use-cases as for now.
    - hc3fs you edit files residing on the HC3 but using the vscode editor...
    - fibemu, you emulate running a QA offline.
    The idea is that we should be able to use fibemu to run files provided by hc3fs... I haven't tested it yet and I believe that there need to be some extra hacking to be done.
    I thought maybe autogenerate a ".meta.lua" file in each hc3fs QuickApp folder and when running that file with fibemu it will load all the quickApp files and set UI and quickAppVars etc correctly... The .meta.lua file could look something like
    and it should be runnable by fibemu.
    thanks, version 0.0.5 works OK, the rest I will try to test
    this in vscode return fqa nil
    Yes, it only exports QAs running in the emulator at the moment.
    DIR is the running QAs in the emu, if not there we could look at the HC3.
    Btw, app api.get, api.put, api.post
    accept a last argument "hc3" and then just makes a direct call to the HC3
    I would like to stop lua code/program in some situation - how to do it?
    something like:
    if fibaro.fibemu then  ??? stop ??? end
    I am in the same situation when pressing F5, I got the Pyton has not been found!
    I did change all "${file}" with "${relativeFile} but still get the python error mesage :
    (cannot find Python in French:
    Python est introuvable. Excutez sans argument pour procder l
    None of my directories had space in their name.
    What I did wrong wrong?
    something like:
    os.exit() was not exported to QA sandbox. I pushed a new version with os.exit available.
    If you can stand in vscode's terminal (at the bottom) and type
    >python3
    and it works, the launcher would also find python.
