  2. You can make a Lua script to modify the alarm panel configuration to use the API directly, no support for changing the configuration of the alarm zones via block scenes. Block scenes are more for control than configuration of specific aspects of the system.
  3. Today
  4. Hi @Willem-Jan , My understanding is that team already worked on that with you and there are some issues with reproducing on our side, without that finding a reason and ultimately fixing that is tricky. Seems like very individual case but we won't give up on that. We will still try to find a solution. At least for now, I suggest making a simple script that will reboot the hub if there is no connection with KNX IP bridge for 15 minutes (or something like that) - let me know if you need any help with that. PS If you will have the logs from this specific situation on new GA version please send them on PM, thanks!
  5. Yesterday
  6. The API is live again, but Buienradar changed all the json data. So I changed all code to the changes Buienradar made to the json data. See the first post for the new quickapp file. You can install the new .fqa file or overwrite the code if you know what you are doing.
  7. Is it Possible to get a copy of your QA? Thanks
  8. Hello. Does anyone here also use Fibaro HC3 and an Indevolt PV system? I'd be interested to know. Since I have three devices in my household and control various other devices with it, I've "built" a QuickApp that displays my systems on the HC3, including current values from the PV panels, battery levels with temperature and power output. This allows me to control a second, smaller QuickApp with a "switch" that allows devices to be switched on or off depending on the battery level.
  9. Last week
  10. Is there any smart way to group all door/window opening sensors under the "ustawienia alarmowe"? Or does each sensor have to be configured individually? Unfortunately, using a device group is not possible as a condition for a scene, and in any case, the sensors are not grouped there in the way I would need. Is there perhaps another way to include all door/window sensors in the alarm configuration without having to add and configure each sensor separately? Or is manual configuration of every sensor currently the only option?
  11. Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks! [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265}T $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257}T $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263}T $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258}T $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ➯ skip turnOff{leaveHome} if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ↪ skip turnOff{everybodyLeaveHome} if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966} 152
  12. Thank you very much. I knew that it's possible!
  13. api.post("/plugins/updateView", { deviceId = <id>, componentName = <elm>, propertyName = <prop>, newValue = <value> }) So, you must know the component name.
  14. Good morning, as we know access to other quickapp function is easy: fibaro.call(id, name, parameters). I would like to ask the following: is it possible to access (write to) other's quickapp UI field similar way? Alter other quickapp UI field remotely?
  15. Thanks for the update. This info slipped my mind as 3.0 upgrade was not really an option till now. Very good news, anyhow.
  16. It was a bug after I moved around the source files. v0.1.44 fixes it. I don't know. I usually have rules that initializes GVs to start values if they don't have values. It's up to your own logic. ER has no memory of what has been set.
  17. Jan, is there a possibility after restoring a backup to renew all values of the Global Variables? So TOD and other values are as they should be?
  18. Jan, if I want to update v0.1,43 it wil update but show updated v0.1.41!
  19. Yes true: log HC3 -> [12.06.2026] [20:42:00] [DEBUG] [QUICKAPP769]: =========== Load time: 0.618s ============ log PC -> [12.06.2026][20:44:01][DEBUG ][EVENTRUNNER75555]: =========== Load time: 1.097s ============ It is just an information for you; as you said I was also thinking that the PC will be faster... but 0.4s is nothing.
  20. https://find.fibaro.com/ or code like: func autoDiscoverFibaro() { for { if adFibaroOn.Load() == 0 { select { case <-adFibaroTrig: case <-time.After(10 * time.Second): } continue } adFibaroLastRunUnix.Store(time.Now().Unix()) adFibaroLastFound.Store(0) adFibaroLastBlocked.Store(0) hostsBySerial := make(map[string]*fibaroHost) for _, port := range []int{44444, 9999} { found := discoverFibaroOnPort(port) for ip, serial := range found { if serial == "" { continue } if _, ok := hostsBySerial[serial]; ok { continue } hostsBySerial[serial] = &fibaroHost{IP: ip, Serial: serial} } } adFibaroLastFound.Store(int32(len(hostsBySerial))) if len(hostsBySerial) > 0 { ensureFibaroServices(hostsBySerial) } select { case <-adFibaroTrig: case <-time.After(2 * time.Minute): } } }
  21. Hello everyone, As I bought recently an automated mower, I did some research about integrating it into Fibaro/Yubii. As the Mova (Dreame) does not officially publish the API I did some testing, based on the information found on different communities I was managed to prepare a QuickApp to actually control it. It is based partially on REST API but also utylise MQTT to handle the events. If someone is actually using one of Viax mowers it should be working with any variant. For now its mostly for testing purposes and supports only one device added to Mova app - API for the vaccums are basically the same so its possible that it will even handle those. Excercise I did is mostly for testing for now, if someone has any Mova mower feel free to use it - at some point, after some tweaks and comments I will drop it also on the marketplace for everyone to find. Viax_Mowers.fqax Steps to use: 1. Import 2. Fill email address and password for Mova account in variables 3. Done If any issues will occur there is also another variable to enable logging (debug) to the console. Regards, Michał
      • 3
  22. I have a new version that installs subfolders automatically and is fully functional. I need to test it on more devices, so if you're interested, please let me know.
  23. Yep, its additional condition on any other trigger - like device's one mentioned by @jakub.jezek
  24. Update: I finally managed to get it working. I was able to successfully include and use the lock again, but only with S0 security. The key difference this time was that I physically moved the HC3 controller much closer to the lock during inclusion. This had never been necessary before, as the lock had worked perfectly at its original location for a long time prior to the Z-Wave Engine 3 migration. Based on my experience, it seems that the ID Lock 150 Z-Wave module requires an extremely fast response during the security negotiation process. If there is even a small delay, the security handshake may fail. In my case, this appears to have been the root cause of the problem. One thing I noticed is that when the security handshake fails, the lock immediately flashes three quick red blinks right after the inclusion process. This turned out to be a very useful indicator that the inclusion had not completed successfully. I was not able to get it working with S2 security again. Unfortunately, I had discarded the original packaging for the Z-Wave module, and the DSK code was printed on that box, so I no longer have access to it. I would also strongly recommend not using Network Wide Inclusion (NWI) when including the ID Lock 150. NWI introduces additional routing and latency during the inclusion process, and it seems that the ID Lock 150 is particularly sensitive to this. This can easily cause the security exchange to fail. One additional observation: when creating PIN codes in HC3, the Label field appears to be sensitive to spaces and special characters. In my testing, PIN codes could stop working if the label contained such characters. If you experience problems adding PIN codes, try leaving the label field empty or use only simple alphanumeric characters without spaces or special symbols. So, for anyone experiencing similar issues after migrating to Z-Wave Engine 3, my recommendation would be: Move the HC3 physically close to the lock during inclusion. Disable Network Wide Inclusion (NWI). Use S0 security if S2 inclusion is not possible. Watch for the lock flashing three quick red blinks, as this may indicate that the security handshake has failed. When creating PIN codes, avoid spaces and special characters in the label field. Be patient during the inclusion process and ensure the lock remains awake and responsive. Hopefully this information helps others who run into the same issue in the future.
  25. @kapitan47, I would say device state, for example Motion if Breached or Safe, and Time Range if its between certain times.
  26. Fyase
    Videogate
  27. Hallo, herzlich willkommen. Gleich zu aller erst, hier solltest du in Englisch oder Polnisch schreiben, siehe Forumsregeln. Nun zu deinem Problem, ich vermute, dass bekommst du nur in den Griff, wenn du in den einzelnen Schaltern noch einen Null klemmen kannst und die Glimmlampe darüber angeschlossen wird. Der vollständigkeitshalber sei erwähnt, 230Volt ist lebensgefährlich!
  28. Hola Daniel, como estás? Estoy incursionando y vi este posteo. Yo tengo que resolver con la versión de Aidoo Z-Wave (pero bandas de frecuencia US, ya que es la banda aceptada acá en región LATAM, y Argentina más precisamente). Tengo unidades de interior de HVAC Mitsubishi Heavy, entiendo que también existiría la compatibilidad. Te surgido además una integración similar? Gracias de antemano!
  29. Thank you wery much. I guess im gonna use another scene for disabling. So what is the proper way to use the time range?
