Good Evening I am writing to report a critical bug affecting the FGS-213 Single Switch 2 after updating its firmware from version 3.3 to 3.4 on a Yubii Home Pro hub running firmware 5.210.12. Environment: - Hub: Yubii Home Pro, firmware 5.210.12 - Device: Fibaro Single Switch 2 (FGS-213), 3 units installed - Z-Wave Engine: 3.0 (ZW3) Steps to reproduce: 1. Perform firmware update 3.3 → 3.4 via Settings → Devices → Updates 2. Update completes successfully (status: "Fertiggestellt" / Completed) 3. Click "Reconfigure device" ("Gerät neu konfigurieren") as suggested by the UI Observed behaviour: - After reconfiguration, the device's Parameter Template is set to "No" (Parametervorlage: Nein) - The Parameters tab in the device view becomes inaccessible - Z-Wave Type drops from 3 to 0, SDK Version drops from 4.24 to 0.0 - Each additional "Read configuration" click further degrades the device profile - Endpoint XX.1 (Binary Switch, the actual switching channel with energy metering) is permanently deleted from Yubii — not hidden, but fully removed - Endpoint XX.0 remains and can switch the load, but has no energy metering capability - Energy reporting (Watt / kWh) is permanently lost until a full Exclude + Include cycle is performed Important note: The "Reconfigure device" button appears directly in the Updates view after the firmware flash completes, with no warning that it may destroy the device profile. This makes it a high-risk trap for end users. Additionally, I observed that on two of the three units, the firmware update did not complete at all (devices remain on version 3.3), despite the update process appearing to run. Requests: 1. Please confirm whether this is a known bug and whether a fix is planned 2. Please advise whether there is a recovery path short of a full Exclude + Include cycle 3. Please consider removing or clearly warning against the "Reconfigure" button immediately after a firmware update, until this issue is resolved I am happy to provide log files, device IDs, or further technical details if helpful. Thank you for your assistance.
Valuhase joined the community
- 69 replies
mar-tin joined the community
83398009 joined the community
- 69 replies
Anand25 joined the community
valu joined the community
- 1 reply
- 69 replies
Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks! [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265}T $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257}T $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263}T $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258}T $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ➯ skip turnOff{leaveHome} if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ↪ skip turnOff{everybodyLeaveHome} if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966} 152
User19 joined the community
PawelA joined the community
doorbird joined the community
- 377 replies
- 377 replies
- 377 replies
- 377 replies
- 3
Update: I finally managed to get it working. I was able to successfully include and use the lock again, but only with S0 security. The key difference this time was that I physically moved the HC3 controller much closer to the lock during inclusion. This had never been necessary before, as the lock had worked perfectly at its original location for a long time prior to the Z-Wave Engine 3 migration. Based on my experience, it seems that the ID Lock 150 Z-Wave module requires an extremely fast response during the security negotiation process. If there is even a small delay, the security handshake may fail. In my case, this appears to have been the root cause of the problem. One thing I noticed is that when the security handshake fails, the lock immediately flashes three quick red blinks right after the inclusion process. This turned out to be a very useful indicator that the inclusion had not completed successfully. I was not able to get it working with S2 security again. Unfortunately, I had discarded the original packaging for the Z-Wave module, and the DSK code was printed on that box, so I no longer have access to it. I would also strongly recommend not using Network Wide Inclusion (NWI) when including the ID Lock 150. NWI introduces additional routing and latency during the inclusion process, and it seems that the ID Lock 150 is particularly sensitive to this. This can easily cause the security exchange to fail. One additional observation: when creating PIN codes in HC3, the Label field appears to be sensitive to spaces and special characters. In my testing, PIN codes could stop working if the label contained such characters. If you experience problems adding PIN codes, try leaving the label field empty or use only simple alphanumeric characters without spaces or special symbols. So, for anyone experiencing similar issues after migrating to Z-Wave Engine 3, my recommendation would be: Move the HC3 physically close to the lock during inclusion. Disable Network Wide Inclusion (NWI). Use S0 security if S2 inclusion is not possible. Watch for the lock flashing three quick red blinks, as this may indicate that the security handshake has failed. When creating PIN codes, avoid spaces and special characters in the label field. Be patient during the inclusion process and ensure the lock remains awake and responsive. Hopefully this information helps others who run into the same issue in the future.
