valu joined the community
- 67 replies
- weathercondition
- weatherstation
(and 5 more)
Hello. Does anyone here also use Fibaro HC3 and an Indevolt PV system? I'd be interested to know. Since I have three devices in my household and control various other devices with it, I've "built" a QuickApp that displays my systems on the HC3, including current values from the PV panels, battery levels with temperature and power output. This allows me to control a second, smaller QuickApp with a "switch" that allows devices to be switched on or off depending on the battery level.
Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks! [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265}T $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257}T $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263}T $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258}T $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ➯ skip turnOff{leaveHome} if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ↪ skip turnOff{everybodyLeaveHome} if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966} 152
User19 joined the community
PawelA joined the community
doorbird joined the community
- 377 replies
- 377 replies
- 377 replies
- 377 replies
- 3
Update: I finally managed to get it working. I was able to successfully include and use the lock again, but only with S0 security. The key difference this time was that I physically moved the HC3 controller much closer to the lock during inclusion. This had never been necessary before, as the lock had worked perfectly at its original location for a long time prior to the Z-Wave Engine 3 migration. Based on my experience, it seems that the ID Lock 150 Z-Wave module requires an extremely fast response during the security negotiation process. If there is even a small delay, the security handshake may fail. In my case, this appears to have been the root cause of the problem. One thing I noticed is that when the security handshake fails, the lock immediately flashes three quick red blinks right after the inclusion process. This turned out to be a very useful indicator that the inclusion had not completed successfully. I was not able to get it working with S2 security again. Unfortunately, I had discarded the original packaging for the Z-Wave module, and the DSK code was printed on that box, so I no longer have access to it. I would also strongly recommend not using Network Wide Inclusion (NWI) when including the ID Lock 150. NWI introduces additional routing and latency during the inclusion process, and it seems that the ID Lock 150 is particularly sensitive to this. This can easily cause the security exchange to fail. One additional observation: when creating PIN codes in HC3, the Label field appears to be sensitive to spaces and special characters. In my testing, PIN codes could stop working if the label contained such characters. If you experience problems adding PIN codes, try leaving the label field empty or use only simple alphanumeric characters without spaces or special symbols. So, for anyone experiencing similar issues after migrating to Z-Wave Engine 3, my recommendation would be: Move the HC3 physically close to the lock during inclusion. Disable Network Wide Inclusion (NWI). Use S0 security if S2 inclusion is not possible. Watch for the lock flashing three quick red blinks, as this may indicate that the security handshake has failed. When creating PIN codes, avoid spaces and special characters in the label field. Be patient during the inclusion process and ensure the lock remains awake and responsive. Hopefully this information helps others who run into the same issue in the future. -
Henrik S Jensen joined the community
Emil123 joined the community
Jab Charif joined the community
Jose Silva joined the community
Probleme mit FGS224 (Glimmlampen in den Schaltern)
PitCock replied to m99999's question in Scenes and Interface
Hallo, herzlich willkommen. Gleich zu aller erst, hier solltest du in Englisch oder Polnisch schreiben, siehe Forumsregeln. Nun zu deinem Problem, ich vermute, dass bekommst du nur in den Griff, wenn du in den einzelnen Schaltern noch einen Null klemmen kannst und die Glimmlampe darüber angeschlossen wird. Der vollständigkeitshalber sei erwähnt, 230Volt ist lebensgefährlich! -
Hola Daniel, como estás? Estoy incursionando y vi este posteo. Yo tengo que resolver con la versión de Aidoo Z-Wave (pero bandas de frecuencia US, ya que es la banda aceptada acá en región LATAM, y Argentina más precisamente). Tengo unidades de interior de HVAC Mitsubishi Heavy, entiendo que también existiría la compatibilidad. Te surgido además una integración similar? Gracias de antemano!
