  2. The only reason would be that phones actually sends the events about arriving and leaving - and as we know, its a bit out of our hands - its based on the API of apple/google. I would try changing the radius definition of the point in location to something higher as a debug step.
  3. Today
  4. What version you've used before? If you rollback the previous version, is it works, OK? By the way I didn't change anything in the code. The geolocation trigger comes for mobile application, not generated by AOQ. In addition, I do have same issue. Interesting what Fibaro team has to say about it? @m.roszak any idea why it happens?
  5. Yesterday
  6. Good Evening I am writing to report a critical bug affecting the FGS-213 Single Switch 2 after updating its firmware from version 3.3 to 3.4 on a Yubii Home Pro hub running firmware 5.210.12. Environment: - Hub: Yubii Home Pro, firmware 5.210.12 - Device: Fibaro Single Switch 2 (FGS-213), 3 units installed - Z-Wave Engine: 3.0 (ZW3) Steps to reproduce: 1. Perform firmware update 3.3 → 3.4 via Settings → Devices → Updates 2. Update completes successfully (status: "Fertiggestellt" / Completed) 3. Click "Reconfigure device" ("Gerät neu konfigurieren") as suggested by the UI Observed behaviour: - After reconfiguration, the device's Parameter Template is set to "No" (Parametervorlage: Nein) - The Parameters tab in the device view becomes inaccessible - Z-Wave Type drops from 3 to 0, SDK Version drops from 4.24 to 0.0 - Each additional "Read configuration" click further degrades the device profile - Endpoint XX.1 (Binary Switch, the actual switching channel with energy metering) is permanently deleted from Yubii — not hidden, but fully removed - Endpoint XX.0 remains and can switch the load, but has no energy metering capability - Energy reporting (Watt / kWh) is permanently lost until a full Exclude + Include cycle is performed Important note: The "Reconfigure device" button appears directly in the Updates view after the firmware flash completes, with no warning that it may destroy the device profile. This makes it a high-risk trap for end users. Additionally, I observed that on two of the three units, the firmware update did not complete at all (devices remain on version 3.3), despite the update process appearing to run. Requests: 1. Is this is a known bug and do you know if a fix is planned? 2. Anyone knows whether there is a recovery path short of a full Exclude + Include cycle? I am happy to provide log files, device IDs, or further technical details if helpful. Thank you for your help.
  7. sorry mate, i havent upgraded to zwave 3 engine just yet. looking @tinman post earlier looks like it doesnt work at the moment
  8. New version 5.0. Changed all the json names back because someone at Buienradar changed them AGAIN. Look for the first post to download and install or overwrite the code with the new code.
  9. Hello, do you have any idea, how to solve this problem without swiching back to zw2? I am able to arm house, but disarm without accessControlEvent doesnt work. It seems this keypad is cursed. In entry control mode is not possible call buttons, In access control mode is no longer possiible to call the scenarios.
  10. Seriously? Yep, Buienradar changed the json again, probably back to what it was. Looks like bullying the developer? Just disable the quickapp again, I will have to see what #@%^ they are doing.
  11. Last week
  12. You can make a Lua script to modify the alarm panel configuration to use the API directly, no support for changing the configuration of the alarm zones via block scenes. Block scenes are more for control than configuration of specific aspects of the system.
  13. Hi @Willem-Jan , My understanding is that team already worked on that with you and there are some issues with reproducing on our side, without that finding a reason and ultimately fixing that is tricky. Seems like very individual case but we won't give up on that. We will still try to find a solution. At least for now, I suggest making a simple script that will reboot the hub if there is no connection with KNX IP bridge for 15 minutes (or something like that) - let me know if you need any help with that. PS If you will have the logs from this specific situation on new GA version please send them on PM, thanks!
  14. The API is live again, but Buienradar changed all the json data. So I changed all code to the changes Buienradar made to the json data. See the first post for the new quickapp file. You can install the new .fqa file or overwrite the code if you know what you are doing.
  15. Is it Possible to get a copy of your QA? Thanks
  16. Hallo. Wollte einmal nachfragen, ob hier noch jemand HC3/HC3L und Indevolt PV Anlage nutzt/hat? Ich habe mir zur Steuerung diverser Szenen und zur Übersicht im HC3 eine kleine QuickApp "gebastelt" die mir die wichtigsten Werte liefert (benutze 3 Indevolt SolidFlex2000) und kann jetzt somit über den Ladestand der Batterien meine Szenen steuern lassen. (z.B. wenn Akku SOC bei 75% darf Boiler heizen, unter 50% nicht). Ein Screenshoot ist angehängt wie die QA aussieht. Bei Interesse gerne melden. Hello. Does anyone here also use Fibaro HC3 and an Indevolt PV system? I'd be interested to know. Since I have three devices in my household and control various other devices with it, I've "built" a QuickApp that displays my systems on the HC3, including current values from the PV panels, battery levels with temperature and power output. This allows me to control a second, smaller QuickApp with a "switch" that allows devices to be switched on or off depending on the battery level.
  17. Is there any smart way to group all door/window opening sensors under the "ustawienia alarmowe"? Or does each sensor have to be configured individually? Unfortunately, using a device group is not possible as a condition for a scene, and in any case, the sensors are not grouped there in the way I would need. Is there perhaps another way to include all door/window sensors in the alarm configuration without having to add and configure each sensor separately? Or is manual configuration of every sensor currently the only option?
  18. Hi cag! I uploaded version 22 and since then the geolocation is not working properly. When I arrive home or any place, I first get a notification about arriving home, then leaving, and finally arriving home again, but sometimes, when I arrive home, I get a notification about arriving home and then leaving home. It's annoying because I use geolocation to arm and disarm the alarm system, and even if we're at home, the alarm is armed because of it. Do you have any idea what the problem could be? Thanks! [2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{265}T $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:15] [TRACE] [AOQ5784]: jM{260}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{257}T $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{266}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{264}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{263}T $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{258}T $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{259}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila leaves Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ➯ skip turnOff{leaveHome} if not {leaveHome(false)=true}[2026-06-14] [16:09:16] [TRACE] [AOQ5784]: jM{62}A $geoAction[enter] ↪ skip turnOff{everybodyLeaveHome} if not {everybodyLeaveHome(false)=true}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{265}A $geoAction[enter] ➯ skip setGlobal{&Noncsi} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser(Attila)=Noncsi}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{257}A $geoAction[enter] ➯ sendPush(Noncsi,Attila) 'GPS','Attila arrived Feri papa') if{$geoLocation(Feri papa)<>HC3-00003966}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{263}A $geoAction[enter] ➯ skip setGlobal{&Attila} if not {$geoLocation(Feri papa)=HC3-00003966 and $geoUser=Attila}[2026-06-14] [16:09:17] [TRACE] [AOQ5784]: jM{258}A $geoAction[enter] ➯ skip sendPush{GPS} if not {$geoLocation(Feri papa)=HC3-00003966} 152
  19. Thank you very much. I knew that it's possible!
  20. api.post("/plugins/updateView", { deviceId = <id>, componentName = <elm>, propertyName = <prop>, newValue = <value> }) So, you must know the component name.
  21. Good morning, as we know access to other quickapp function is easy: fibaro.call(id, name, parameters). I would like to ask the following: is it possible to access (write to) other's quickapp UI field similar way? Alter other quickapp UI field remotely?
  22. Thanks for the update. This info slipped my mind as 3.0 upgrade was not really an option till now. Very good news, anyhow.
  23. It was a bug after I moved around the source files. v0.1.44 fixes it. I don't know. I usually have rules that initializes GVs to start values if they don't have values. It's up to your own logic. ER has no memory of what has been set.
  24. Jan, is there a possibility after restoring a backup to renew all values of the Global Variables? So TOD and other values are as they should be?
  25. Jan, if I want to update v0.1,43 it wil update but show updated v0.1.41!
  26. Yes true: log HC3 -> [12.06.2026] [20:42:00] [DEBUG] [QUICKAPP769]: =========== Load time: 0.618s ============ log PC -> [12.06.2026][20:44:01][DEBUG ][EVENTRUNNER75555]: =========== Load time: 1.097s ============ It is just an information for you; as you said I was also thinking that the PC will be faster... but 0.4s is nothing.
  27. https://find.fibaro.com/ or code like: func autoDiscoverFibaro() { for { if adFibaroOn.Load() == 0 { select { case <-adFibaroTrig: case <-time.After(10 * time.Second): } continue } adFibaroLastRunUnix.Store(time.Now().Unix()) adFibaroLastFound.Store(0) adFibaroLastBlocked.Store(0) hostsBySerial := make(map[string]*fibaroHost) for _, port := range []int{44444, 9999} { found := discoverFibaroOnPort(port) for ip, serial := range found { if serial == "" { continue } if _, ok := hostsBySerial[serial]; ok { continue } hostsBySerial[serial] = &fibaroHost{IP: ip, Serial: serial} } } adFibaroLastFound.Store(int32(len(hostsBySerial))) if len(hostsBySerial) > 0 { ensureFibaroServices(hostsBySerial) } select { case <-adFibaroTrig: case <-time.After(2 * time.Minute): } } }
  28. Hello everyone, As I bought recently an automated mower, I did some research about integrating it into Fibaro/Yubii. As the Mova (Dreame) does not officially publish the API I did some testing, based on the information found on different communities I was managed to prepare a QuickApp to actually control it. It is based partially on REST API but also utylise MQTT to handle the events. If someone is actually using one of Viax mowers it should be working with any variant. For now its mostly for testing purposes and supports only one device added to Mova app - API for the vaccums are basically the same so its possible that it will even handle those. Excercise I did is mostly for testing for now, if someone has any Mova mower feel free to use it - at some point, after some tweaks and comments I will drop it also on the marketplace for everyone to find. Viax_Mowers.fqax Steps to use: 1. Import 2. Fill email address and password for Mova account in variables 3. Done If any issues will occur there is also another variable to enable logging (debug) to the console. Regards, Michał
      • 3
  29. I have a new version that installs subfolders automatically and is fully functional. I need to test it on more devices, so if you're interested, please let me know.
