Philips HUE AIO VD v3.1
(standalone version)
With Philips HUE preview VD v1.1 - brings easier setup and support for multiple Philips HUE bridges
INTRODUCTION
Philips HUE lighting brings colorful way of lighting experience. More about this lights you can find here https://www2.meethue.com/en-us Philips HUE AIO VD is All In One solution for HC2 owners to control Philips HUE lighting with support for all types of HUE lamps made by Philips and some other manufacturers.
PREREQUISITES
  • Fibaro Home Center 2 with firmware 4.120 or greater (tested up to 4.540)
  • Philips HUE bridge V1 (round) with firmware up to 01041302 (released 05 February 2018) or
  • Philips HUE bridge V2 (square) with firmware up to 1901181309 (released 07 February 2019)
FEATURES
  • Consists of two VD's: Philips HUE Preview VD which connects to Philips HUE bridge and downloads information of all lights and groups of lights and greatly simplifies installation of Philips HUE AIO VD that controls individual HUE bulbs or group of bulbs. Also added unreachable icon for Philips HUE bridge v1.
  • Philips HUE Preview VD has button for generating authorization username and for easy connection to Philips HUE bridge
  • Support for multiple HUE bridges and most of the Philips HUE bulbs including bulbs from other manufacturers that can be connected to HUE bridge.
  • HUE AIO VD recognizes different types of bulbs like multicolor, white ambience and dimmable and enables proper controls
  • Can control brightness, hue, saturation, color temperature and transition speed that can be set from instant to 10 seconds duration
  • Buttons to activate colorloop efect and Alerts
  • Multilanguage support with 27 languages included. VD's can use HC2 selected language or user can select any other available language. VD will be automatically translated to the selected language (visible after refreshing page on browser or refreshing network data on Fibaro mobile application)
  • Easy setup for VD icons that will also setup icons for all buttons and sliders of the VD. (on UHASTM compatible version is even more easier to setup VD icons with Icon Preview VD)
  • On HUE AIO VD user can setup separated on and off button or have on/off toggle button
  • Self adding of global variables needed and global variable data integrity checking
  • Automatic repair of global variables without user intervention
  • New approach to programming other code to control this VD enables future upgrades without needing to change that code. (See more about that in User Manual provided)
INSTALLATION
Please check provided User Manual where all steps are explained in detail and this video made by @MarcoTorino71:
PACKAGE CONTENT
  • Philips HUE Preview VD v1.1 standalone
  • Philips HUE AIO VD v3.1 standalone
  • Icon pack Philips HUE E27 bulb indoor
  • Icon pack Philips HUE E27 bulb outdoor
  • Icon pack Philips HUE GU10 bulb indoor
  • Icon pack Philips HUE GU10 bulb outdoor
  • Icon pack Philips HUE LED strip indoor
  • User Manual v1.1 EN
CREDITS
Many thanks to BodyArt, gucio1234 and many other Fibaro forum users for help with testing, translations and user manual.
TERMS AND CONDITIONS
Permission to use, copy, modify and distribute this software and its documentation for educational, research, personal use and non-profit purposes, without fee and without a signed licensing agreement is hereby granted, provided that the copyright notice, with "Terms and conditions" and "Disclaimer" appear in all copies, modifications and distributions.
It is strictly forbidden to sell, rent, lease and/or lend this software for profit without prior consent from the Author.
DISCLAIMER
Fibar Group S.A. and their employees are not responsible for support of the Philips HUE AIO VD. Please contact the author Sankotronic, on the Fibaro Forum, for any questions or support required.
LEGAL NOTICE
HUE is registered trademark of Philips Lighting Holding B.V. registered internationally.
LATEST NEWS
1 April 2019
Philips HUE bridge firmware new version 1901181309 is out. If you upgrade to this latest firmware Philips HUE AIO VD will continue function properly.
VERSION HISTORY
3.1 - Corrected bug that was causing HUE AIO VD main loop to stop with error if user set light or group ID that does not exists on HUE bridge. Also corrected bug that was not updating list correctly after first scan if user removed or added light or group on HUE bridge.
3.0 - All In One solution, one VD for all types of bulbs and for control of individual light or group of lights with supporting Philips HUE Preview VD.
2.1 - added Philips HUE White dimmable VD of same version as color version.
2.1 - Corrected error handling when HUE bridge is not reachable.
2.0 - Added On/Off button; two version available: 2.0m with Main loop refresh  or 2.0b with button refresh for systems with more than 15 HUE lamps to improve response and reduce network traffic; changing brightness, color or Saturation sliders now immediately refreshes VD status; code improved so users can easier setup necessary data
1.5 - Added sliders for color (hue) and Saturation, VD is now getting ID & TCP port setting from VD general tab
1.0 - Changing icons based on the brightness level, Changing icons based on HUE lights state (unreachable/error); Error handling for HUE response data, status information in the bottom bar of the VD; detailed comments in LUA code, main loop refresh code added
Here is a new look of Philips HUE AIO VD and companion Philips HUE Preview VD:
   28855720_SAPhilipsHUEPreviewv1.1.thumb.png.6265881218e323ce300a09274d214529.png 1237575361_SAPhilipsHUEAIOVDv3.1.thumb.png.4350a30e1fd4412fb92d77ed82c73a25.png
Enjoy coding and your new Philips HUE virtual device!
Sankotronic :P
PS
This solution is only for HC2. If you have HCL then please check @AkilliYuva.com solution here:
What's New in Version 3.1   See changelog
  • Moved VD from Fibaro marketplace here to Fibaro forum DOWNLOAD section
  • Corrected bug that was causing HUE AIO VD main loop to stop running if user setup light or group ID that does not exists on HUE bridge
  • Corrected bug that was preventing proper update on HUE Preview VD of lights and groups after user changed setup on HUE bridge
  • Added icon for HUE bridge v1 unreachable
UPGRADE
  • From 3.0 to 3.1 - If you are happy with 3.0 then you can skip this version. If you still want to upgrade then delete all previous version VD's and then added global variables and install v3.1 according to user manual.
  • From 2.X to 3.1 - Please delete all old VD's and global variables and follow installation instructions in user manual provided.
  • Like 9
  • Thanks 4
Guest Sankotronic
2 minutes ago, roeggi said:
Hello Can I use a scene to select a fixture via the Preview VD and turn it on / off? So far, I can only control the dialing light but do not select over a scene.
Hi @roeggi ,
HUE Preview VD main goal is to help you with setting up HUE AIO VD by connecting to HUE bridge and showing ID numbers of all lamps and groups that are found on the HUE bridge. After importing and setting up HUE Preview VD (connecting to HUE bridge by setting IP address and port of the HUE bridge and getting username and setting up icons) then you need to import HUE AIO VD for each lamp or group of lamps that you want to control.
If HUE Preview VD is properly setup before importing HUE AIO VD's then each imported HUE AIO VD will get all settings needed and even icons from HUE Preview VD and all what is left to setup on HUE AIO VD is ID number of the light or group of lights and those ID's can be found with help from HUE Preview VD.
HUE Preview VD therefore main goal is to speed up and simplify installation of HUE AIO VD which is then used to control HUE lights and groups of lights.
I suggest to read User Manual where I did my best to explain installation process and how to use VD's.
roeggi
Hello @Sankotronic
Now I understand it. Unfortunately, my English is not very good. Your guide is very good.
I still have a question if I want to replace the icons. How do I find the ID number out of the icons? I made some myself.
Guest Sankotronic
On 2/7/2019 at 7:02 AM, roeggi said:
Hello @Sankotronic
Hi @roeggi ,
You can download Icon Preview VD  and use it to find out ID number of imported VD custom icons.
Musino
Hello, I wanted to ask if this VD works on HC2 4.531 and HUE BSB 002 - 1811120916? I'm not getting a connection. Can I ask for advice? thank you very much
Guest Sankotronic
Hi @Musino ,
I can confirm that Philips HUE AIO VD works on 4.531B and with BSB 002 1811120916.
What do you mean by "not getting connection"? Did you first install Philips HUE Preview VD and also setup HUE bridge to be on static IP address?
I can just recommend to follow installation guide in user manual, without skipping any steps and it should work without any problems.
Bodyart
Hi @Musino,
the current firmware version on BSB002 is 1901181309 already and this VD works with it very well :-)
Musino
Hello, thank you very much for the answer. Problem resolved :)), I had to create an account manually via API in HUE Bridge and paste this account into VD, according to the instructions I was unable to link, thank you
Guest Sankotronic
Hi @Musino ,
that is very strange. I have tested this feature so many times that I have now too many usernames generated on my HUE bridge. I hope you did follow instructions in user manual to the letter and in the specified order.
Musino
Good evening, thank you for your reply, I'm very careful studying your equipment and learning programs so I will not. I do not know where the bug was: (Maybe I have a lot of equipment - 140 physical modules Fibaro, 1x HC2 and 2x HCL, I do not know how many scenes and other things, Thank you
I'm sorry for my English
I am sorry for my English
Edited by Musino
Musino
I apologize for the error on my side
Edited by Musino
athome
I'm trying to add the preview and at 3.7  step 7(inthe manual) after importing the icons and when checking id it stops for me(maybe I'm being stopid):
I dont understand how I should check the id, before entering it in the main loop.
When I right click the image under it shows addresses like this: http://xxx.xxx.xxx.xxx/fibaro/n_vicons/User1001.png
Could anyone give an example of an id to enter in the main loop?
Anders
Edited by athome
xxJAREKxx
hi i couldn´t save hue preview because selected id already exist. what did i wrong. id doesnt exist but it says
Guest Sankotronic
Hi @athome ,
ID number of the icon selected is that number in name of the icon: http://xxx.xxx.xxx.xxx/fibaro/n_vicons/User1001.png so in this case ID number is 1001.
Hi @xxJAREKxx ,
sorry but can you be more specific what ID already exist. Maybe screenshot of the error or something?
xxJAREKxx
sovled the Problem. IE was the problem and now i use crome
Bosman
Hi all is perfect working VD.
I wan't to try set up a scene in Lua with several Hue lights.
code for light on is: fibaro:call(38, "pressButton", "1")
code for light off is: fibaro:call(38, "pressButton", "0")
that works great. But what is the code to set brightness, hue, saturation  etc.
Please help my, thanks
Guest Sankotronic
Hi @Bosman ,
to change slider value you can use this code:
fibaro:call(38, "setSlider", "3", 100)
But I have also explained howto control HUE AIO VD from user code in user manual chapter 4.1
Bosman
thank you for your advice.
Sjakie
Hi Sankotronic,
Today I become owner of a Hue Bridge and one light, where I find the light ID number to add in Philips HUE AIO VD - Version 3.1 (Standalone version)
that is the only error (till now) to solve.
Thanks in advance and keep going the good work!!!
Guest Sankotronic
14 hours ago, Sjakie said:
Hi Sankotronic,
Hi @Sjakie ,
did you read User manual and install HUE preview VD?
Sjakie
Sankotronic @
Yes, I thought I had read it, found the solution in the picture of the preview VD. I was following your text to much, sorry.
Thanks, the VD is not give any error in debug let me start to pay with it.
Thanks and have a nice weekend
miwa
Hi, does VD work with VSL?
Guest Sankotronic
Hi @miwa ,
Thanks for asking and reminding me to take care for VSL scene! I have just published latest version of VSL scene v1.4.3 that is compatible with Philips HUE AIO VD v3.0 standalone!I hope that forum administrators will release it very soon!
Enjoy coding! :-)
Sirhideo
@Sankotronic  According to manual to press the Alert button from a scene.. But I cannot get it to work with below error.  What have I done wrong?
[DEBUG] 13:46:49: 2019-05-23 13:46:49.397359 [ fatal] Unknown exception: /opt/fibaro/scenes/342.lua:20: attempt to index field '?' (a nil value)
%% properties
%% events
%% globals
-- local jT = json.decode(fibaro:getGlobalValue("HomeTable"))
local hM = json.decode(fibaro:getGlobalValue("HueMain"))
local hA = json.decode(fibaro:getGlobalValue("HueAlert"))
local hueID = 543
hA.hue.flg = true;
hA.hue.rst = true;
hA.hue.dur = 10;
hA.hue.bri = 90;
hA.hue.hue = 10;
hA.hue.sat = -1
hA.hue.ct = -1
fibaro:setGlobal("HueAlert",json.encode(hA))
fibaro:call(hueID, "pressButton", hM[hueID].alButton)
Edited by Sirhideo
