New Fibaro Motion/Multi Sensor - when will it be available?
Aeon, Ezmotion, Vison, Everspring, Fibaro
  • Replies 174
  • Created
  • Last Reply
Top Posters In This Topic
Guest nohed
how to turn off the light blinks when motion detector motion ara activated
nohed, parameter 80
Guest nohed
nohed, parameter 80
What to do to get the Last breach time?
Also find out that the iPad and the iPhone will not show the status changes all the time..
In the browser it will show correct
I am struggling to buy 2 sensors (new or used!)
It seems that Vesternet is the only place where the sensor is available and in stock, but shipment cost and prices are really high.
Is there any other reliable site to shop in EU?
Ucciogenerale
Wait a few days. They have basically started shipping this week and will soon be available in many places. I got two yesterday and those were one of the first batches in the country.
Later this week more available in my shop.
Ucciogenerale
I received 2 last saturday from Robbshop.nl
Btw, is there anyone who got the "earthquake" settings write, so the "shake" is reported to the controller. According to the manual there is a separate screen for that, but I have not seen it yet.
Ucciogenerale
Earthquakes in the Netherlands are common then?
No not in current HC2. I am still intrigued by that one but don't expect to be able to test it in the UK any time soon.
Only in certain parts of The Netherlands where they have been exploiting some gas fields or cole mines in the past decades. But apart from serious damage to the houses of the people that live there, no personal damage has occurred.
Got mine to...whau it's small
Oh yes, us dutch, what we do not have naturally we make ourselfs:
It is in the manual, should be working when setting parameter 24. Do we have to wait for a firmware update?
Sensor in my garage keeps breaching and staying breached until real movement is detected... Range issue? Cold battery? Any advice or what to look for?
deanrparry, i think that is alarm tamper, check it by turn off it parameter 20
Looking like range... Violet flashing but all other devices in garage are fibaro relays so no way to test ZWave range? Might have to move my hc2 box closer...
With one of my sensors I have the same issue, stays breached forever. Included/excluded/reset/restart HC2/close to the HC2 but sensor stays breached. Already contacted support, but no solution yet. The others are working just fine.
Guest Kuuno
I tested node neighborupdate and it works. It is little tricky tho. First start nn ubdate for the movement sensor. Then right away for some module close by. Then wake up the movement sensor until you see nn update complete.
Let me know. I got it working ok in a pretty large installation
Setting parameter 20 to 0 didn't help, also the trick of Kuuno didn't changed anything. Still breached forever and never updates the LUX and TEMP (only if i do a reconfigure device it will update once).
I had the same situation and sadly nothing has helped. I am waiting now for new device from Fibaro...
