i'm trying to create a block scene with my Remotec ZXT-120.
I set some time schedules but i can't set temperature, mode and fan option into the device
It's a bug?
Regards
Share this post
Link to post
Is it compatible with HC2
How does it works for you
can you give a image of the device in HC2 included with the buttons
Share this post
Link to post
  • Thanks j.nowacki.
    Kage, yes it's compatible with HC2 but i use it only with lua scene.
    Share this post
    Link to post
    Hi All,
    I'm trying to build a lua scene to turn off the air conditioner when there is no movement in the room.
    unfortunately I can not find or know what they are commends.
    Can you please help?
    Thx
    Share this post
    Link to post
    Ok..
    You can reverse engineer the codes to send in LUA by testing each one, then going back to the "Your Home" or "Devices" UI and see what it is now set to
    e.g.
    If you send (174 if the "Mode" device for me)
    then go back to the UI you'll see that it says your Aircon is in Fan mode.. likewise if you send 0 , you get OFF
    Hope this helps. I might decode later and repost [if I get bored]
    Share this post
    Link to post
    As a side note, has anyone used the custom programming feature of the ZXT-120 to control a TV ? e.g. program certain temps with a button on the remote then send the correct combination of codes?
    Share this post
    Link to post
    LiG
    very nice
    is it possible to share the LUA
     and i heard that the on off not working, is that true
    greats Kage
    Share this post
    Link to post
    LiG
    I bought a remotec zxt-120 include it to HC2 on version 4.054
    when it's done I see only 4 devices include as show in your picture
    only I can not see anything in  the selection like cooling or heating
    I can see the fan control it's OFF and nothing more
    what do you think I can do
    Share this post
    Link to post
    LiG
    Visit
    and download code list for version of your device, and choose code for your controled device.
    In Fibaro parameter 27 in remotec device put your chosen code and then make soft reconfuration.
    After soft reconfiguration your should be able change mode and set other functions in interface (Idle, set temperature,...).
    Share this post
    Link to post
    Thanks but found the problem.
    my provider wash hacked (ziggo) en therefore i can not correctly included the device
    when the problem wash solved it works correctly
    greats Kage
    Share this post
    Link to post
    LiG
    ...now I am in exactly the same situation, but my HC2 firmware version is 4.056.
    how can I solve this problem?
    Share this post
    Link to post
    For me it was that i don't have internet. Een i have it again i excluded it en include it again.
    Share this post
    Link to post
    ZXT-120 dynamically changes available modes due to different parameters settings.
    Please select one of codes set in parameters or learn codes manually and then soft-reconfigure the device - this way during softreconfiguration HC will request supported modes for ZXT-120 and then every supported mode will be visible in interface.
    Share this post
    Link to post
  • Thanks Kage, my internet connection is ok. I noticed that this problem came out when i updated the unit to 4.054 firmware version.
    thank you m.roszak, i've already set the correct parameter, it's not the first time that i include this device into my z-wave network, i'm a tester and i noticed this problem after 4.054 firmware upgrade.
    Share this post
    Link to post
    Unfortunately no, I played with it and eventually it appears.
    It's still not perfect, I tried to build a new scene but lacks of modes.
    Need to go to work, new update will follow.
    Thx
    Share this post
    Link to post
    Hi, Did you ever resolve this? I can't control the AC, only see the 4 devices and can't change anything. I've set parameter 27 to the proper code, soft config, and nothing. It was working fine, but now I can't even change turn on the AC. Any clues?
    Rui
    Share this post
    Link to post
  • unfortunately no....i haven't resolved my problem, i tried to exclude and include again the remotec but it still doesn't work.
    Share this post
    Link to post
