i'm trying to create a block scene with my Remotec ZXT-120.
I set some time schedules but i can't set temperature, mode and fan option into the device
It's a bug?
Regards
I've also tried the exclude and reinclude, no luck. It's simply not working.
Rui
If you are using newest HC2 fw version and have problems with Remotec Configuration please contact [email protected] directly - they will help you resolve your issues.
If you cannot change anything, because select lists seems dead, please try the same on Chrome browser. It looks like last Firefox updates might have introduced some bugs in this feature.
OK! It works on Chrome, so it's a browser thing. Thanks.
Rui
    now it's work fine! also block scenes!
    Hi, it still doesn't work for me, i've also tried on chrome but select lists are dead.
    Times ago the remotec wasn't compatible, then It's worked on previous firmware version and i sold several devices, now doesn't work again...how can i have a stable product to sell?
    the same problem again...
    the controller doesn't include correctly my remotec zxt-120 anymore. The picklists are all blanks...again...
    i'm on HC2, last firmware (4.063) and brand new remotec. I've tried with different browsers, i've tried to exclude and include several times and to set conditioner code also.
    Does anyone have any ideas how can i solve this problem?
    Thank you!
    First please set desired codes set using device parameters.
    After that soft-reconfigure it and picklist will be filled.
    ok, now it works.
    thank you
    Hello
    Remotec can work with HCL ??
