Lets see if i got this right
Rule #1 will pressButton on my VD when i arrive at home and it is dark
Rule #2 same as #1 except user
Rule #3 will pressButton 2 after 15min if Label1 is "ON"
All true @jgab ?
    All true @jgab ?
    Yes, but "event triggers" can't have any other tests on the left hand side (it may change in the future), so you move the darkness test to the right.
    Ok, but if you are already home and Mona comes home and it's dark it still presses the button? That's why I had the logic that when the first person came home it sent #presence{state='home'} and one could trigger on that.
    <exprA> & <exprB> is like an IF <exprA> then  <exprB>...
    Third rule looks ok.
    @jgab do you know how often phone location update to apple servers?
    It did take almost 5 min before it did update when i did arrive to home, this mean the lights did not turn on like i want.
    Have you notice the same behavior?
    Update
    I notice that i was not logged on to "find my iPhone" app, perhaps it was that?
    Edited by jompa68
    Well, it seems like they update every minute (when you run the FindFriends app on the phone it updates every minute).
    Having said that, I have seen a lot of varying update intervals.
    The loop in the iOSLocator loops through the people/family members checking one person each minute, so if you are 4 person it check each person every 4 minutes, are you 2, it becomes every second minute. You can try to lower that interval (line 222 in iOSLocator), to check more often. However, too frequent checks to the server (10''s per minute for the same person) seems to make Apple block you for a while... I had that bug once :-)
    You can also experiment with the radius to the home so iOSLocator detects that you are close to home earlier. I used to have a radius of 800m to detect if people were home or not and start/stop the alarm, and it worked 9/10 times (I usually arrived by car). Now I just moved so I don't have an alarm yet.
    This line
    to
    26 minutes ago, jompa68 said:
    This line
    to
    Yes.
    Do you have a large enough radius defining “home”?
    Yes i think so.
    7 minutes ago, jompa68 said:
    Yes i think so.
    Yes, that should work.
    @jgab
    is ti possible to check variable that wasn't change for some period of time? (I know it will generate error but maybe you have some simple solution in your framework)
      rule("for(00:02, test==10) => log('Variable test had 2 minutes value 10')")
    42 minutes ago, petrkl12 said:
    @jgab
    No, it only works for fibaro globals now i.e. $x. I'm afraid that triggering on local variables could cause a lot of strange unintended behaviours and even performance issues... I have to trigger all rules where the local is used, ex.
    That last expression would trigger the first two rules (and the second would log)...
    To let this loose on variables in general feels a bit dangerous...
    Maybe some special kind of trigger variable, so one doesn't need to use a fibaro global.
    Let me think about it.
    Now one could do.
    Do you have a specific use case? The solution can differ a lot depending what it is you want to achieve.
    OK, I know it will be complicated
    but what about to use for example special type of value: $$ and trigger only this variables
    Edited by petrkl12
    Ok, pushed a new version that triggers on variables starting with an underscore.
    Whenever the value of a variable starting with underscore is changed an event {type='variable, name=<name>, value=<value>} is posted.
    So, it works ok for now but I will optimise it a bit how these events are dispatched in the future.
    Super, Super, Super!
    With great power comes great responsibility.
    Will create an infinite loop. (that's why there shouldn't be any side effects on the left hand side of a rule)
    On the other hand
    is a rather elegant loop construct.
    OK, Thanks for explanation of potential issue
    BUT I think that it has really huge potential how to use it!
    Ok,
    I just pushed a new version where there is a script compiler error if a trigger variable or a fibaro global is assigned in the rule header (left hand side).
    e.g.
    A subtlety is also that trigger variables will not trigger if their values changes (from whatever old value they held). That is more consistent on how fibaro's own global variables behave.
    e.g.
    will not create an infinite loop.
    Perfect! Thanks
    Made some changes in EventScript syntax. New version pushed.
    CentralSceneEvent is triggered like this.
    What's happening behind the scene is that an event of type
    {type='event', event={type=<eventType>, data={...}}}
    is internally reposted as {type='property', deviceID=<ID>, propertyName=<eventType>, data=data}.
    I have to know what <eventType> it is to be able to pick up the <ID> and insert it in the new event (seems to be no consistency in naming event data fields...).
    So for the moment it can only deal with CentralSceneEvent and AccessControlEvent. If you know about other types of event I can easily add them.
    Anyway, it results in that I can easier use the ':property' syntax like in the example. It also means that the event in 'env.event' has the structure {type='property', deviceID=<ID>, propertyName=<eventType>, data=data}
    AccessControlEvent is similar.
    Both the ':central' and ':access' returns the 'data' field of the event.
    SceneActivation is still accessed as 55:scene
    @jgab
    Thanks for adding that features.
    How to use in :central for example long press of button?
    1 minute ago, petrkl12 said:
    @jgab
