    12 hours ago, jgab said:
    The second issue, the feature of having a list of deviceIDs in an event "disappeared' in the new version. I will fix it tonight.
    Ok, fixed that.
    rule("#property{deviceID={4,5,6}} => ...") works now. Pushed a new version but didn't bump the version number.
    Still can't reproduce the error with rule("Switches:central => d=env.event.deviceID; log('Test switch id=%s',d)")
    /J
    Thanks. Fix is working.
    for switch issue - still doesn't work (in my previous example there was only 3 values but  issue appear if there is more than 3 values). Example bellow definitly doesn't  work :)
    Problem is in function esort :
    2 hours ago, petrkl12 said:
    Thanks!, nothing better than starting the day with fixing a bug :-)
    Yes, the problem was that incoming events are tagged with timestamps that I sort on, correction, that I though I sorted on. Pushed a fix.
    Why sort?, <table>:central returns an array of all the data parts of the event ids in the <table>. All <table>:prop return a table with the prop values. However, for :central and :access, the result array is sorted with the last event first. That means that it is possible to write something like this, because the last event was the event that triggered the rule.
    Works! Thank you!
    can i combine an variable and a lux value together?
    like If var == xxxx and lux > 100 then xxxx ?
    Yes, the rule should triggered when UHASDarkness changes value or deviceID 800's value changes - and the left hand is computed and if true the right hand side is run.
    You need to declare
    %% properties
    800 value
    %% globals
    UHASDarkness
    @jgab can you tell what is wrong with your example code of alarmmode?
    Compilation error on line 65:
    C:\zerobranestudio\myprograms\EventRunner.lua:65: '=' expected near 'Rule'
    line 65 is this:
    UPDATE!
    Never mind, must been some copy&paste error, did redo it and now it works.
    Edited by jompa68
    if i want to have a delay for 30 sec before it runs the #dwBreached, how to achieve that?
    Scenario: when arriving to home the alarm will go off direct when i open the door so i have no "window" time to disarm it.
    I think this should work. When it wakes up from the wait, and the state has changed it won't run the transition. 'wait' always return true.
    ...or even
    and you could sound a warning (Sonos?) instead of the log.
    Yes, that did do it. Thanks :D
    ...or even
    Notice one thing, when i arm by keypad and opens the door when leaving the house it will trigger #dwBreached after 30sec and trigger the alarm
    Yes, that doesn't work. I'm starting to suspect that it may be a need for some more states...
    However, a fix may be like below, i.e to re-check after the sleep if the sensors are still breached. Maybe you have to extend the sleep period depending on how long the sensors stay breached.
    Thinking about it, maybe it is easier to delay the arm event from the keypad so you have time to get out? A delay in the post?
    Yes could also be possible, but above fix did also work. (atleast in ZBS) :)
    I think from a theoretical stand-point (state-machines that is), if you find yourself adding a lot of extra conditions to state a transition, it is probably hiding a state-machine involving more states and transitions. The risk is that one miss some transitions.
    Having said that, it's also an art to keep state-machines reasonable small - they have a tendency to grow fast (states x transitions), and carefully placed extra conditions can help in "collapsing" the code into fever states and transitions.
    However, in this case, I think it's cleaner to delay the posting of the arm event. Better to put conditions on what and when fires events that changes the states. I guess one could also wait posting the arm until the door is opened and closed.
    About the cat... can the delay, 'wait(00:00:30)' allow a burgler to sneak in, instead of the cat getting out?
    True, i thinking to use iOSlocator and set variable and use that together with alarmmodule
    So if  door opens and nobody at home it will trigger alarm direct.
    When my cat wants to go out or come in during the night, my pirSensors will react and disable alarm for 10min
    This is not working
    3 minutes ago, jompa68 said:
    This is not working
    It should be or ’|’ instead of and ’&’. Two events can’t be true at the same time
    i don't see that this line is working for me, what could be wrong?
    and how can i do test with users that leave and arrive at home?
    I need some context - what is posting the presence event and in what way isn’t it working?
    This is my lines in EventRunner
    So when all iOS devices get a new location away from 'Home' should not #presence{state='allaway'} be true?
    On 11/3/2018 at 11:54 AM, petrkl12 said:
    Rule.eval("@20:00 & wday('sat,sun') & $BankHoliday>0 & $HolidayTime>0 => 125:on")
    @petrkl12 how have you implement the bankholiday function? in ER or outside?
