OK, thanks
@jgab
i have trouble with this 2 lines, will never be active on live scene. Works very well in ZBS and i cannot find where the problem is.
    17 minutes ago, jompa68 said:
    @jgab
    You have the pirsensors and dwsensors declared in the scene headers?
    Also, something need to trigger the rule to start the ‘for’ monitoring. Like a sensor being breached or safe or time being 22:30 or 05:30:01.
    The second rule doesn’t work either? (to exclude any issue with ‘repeat’)
    If i understand right the first rule should arm ring if pir and door/window sensor was safe for 20 min and time is between 22:00 and 05:00. But that never happens in live scene, nothing is written in debug window (only in ZBS)
    Yes have sensors declared in headers
    Edited by jompa68
    On the HC2, if you wrap the first rule like this, what output do you get?
    3 minutes ago, jompa68 said:
    Ok, that's strange. I will try to reproduce it when I'm back this evening.
    Ah!, one of dwSensors or pirSensors is empty?
    {}:safe should return true. Is that it? Will fix this evening.
    Hm, doesn't explain why it works on ZBS - or you have different tables?
    i define pir and dwsensors in scene. Could be it, i will recheck that.
    Ah! think i found the problem. Look at the time since last update....
    /monthly_2018_12/image.png.003ed76d922e385e1837b052b98184f4.png" alt="image.png.003ed76d922e385e1837b052b98184f4.png" />
    Edited by jompa68
    Ok, that’s probably it. Anyway, you helped me finding a bug with {}:safe ...
    New version, v1.6, of EventRunner. Update EventRunner.lua, EventRunnerDebug.lua, example_rules.lua
    Lot's of changes but mostly internal stuff . Most changes are in EventRunnerDebug, so there shouldn't be much affecting (live) HC2 versions.
    -Complete rewrite of setTimeout on ZBS (doesn't affect HC2). The framework depends on setTimeout for scheduling rules and posting events, and Lua/ZBS doesn't have a setTimeout. I used to have home cooked version that worked, but now it is implemented with Lua's coroutines which makes it much more robust and cleaner and allows for mixing setTimeout with fibaro:sleep etc. I hope this will allow me to add more features like stepping through time etc (It is also a preparation for reusing EventRunnerDebug.lua  to implement a framework that can run standard HC2 scenes (and VDs), and several in parallell... a nice Xmas project). I have tested it quite extensively but there can still be bugs - it's like replacing the heart of the code, and I may have overlooked something...
    -Incompatible changes; _setClock, and _setMaxTime is replaced by _System.setTime(string starttime, int number). Ex. _System.setTime("08:00", 24*30), start simulation at 08:00 and run for 30 days.
    -EventRunner.lua. Fixed parsing of scene headers when running without debug in ZBS. Fix {}:safe to return true.
    -Log output in ZBS uses colors like on the HC2.
    it looks there is problem with folowing rules where is -xx:xx :
      rule("@@-01:00 => log('Start Run scene ClearDebugMsg'); scene.ClearDebugMsg:start; log('End Run scene ClearDebugMsg')")
      rule("@@-00:02 => log('Start Update VD - Multizasuvky'); MultiZasuvky:btn=19; log('End Update VD - Multizasuvky')")
    rules run every a few seconds ...
    Edited by petrkl12
    Sorry, disappeared when I rewrote the last time (I had forgotten about that hack, maybe need to start document this...). I have pushed a new version that fixes it.
    Now everything is OK! Thanks a lot.
    @jgab i still have problems with my alarm setup. It does now work in HC2 but same setup do work in ZBS.
    HC2
    It should have arm the house when "lock" on keypad but it did not. It should also arm arm when "presence" state is "allaway"
    ZBS debug
    any idea what could be wrong?
    Can you pm me the scene rules?
    Try to add log on #arm rule and see what you get  - something seems to stop the transition from happen.
    ZBS debug
    The color output in ZBS debug window is really ugly when cut and paste into other places... I will make color output an optional flag in the next release.
    Added it now and will monitor it tonight and tomorrow and let you know the result.
    On 12/14/2018 at 1:23 PM, jgab said:
    Possible to group rules & event handlers in sections
    This does not work in ZBS, at least not the code example
    I seem to have invented this new function "Event.rule" that doesn't exists. It should have been 'Rule.eval'. I have changed the example in the previous post.
    So, the way it is implemented is that 'Rule.eval' and 'Event.event' definitions add their event handlers to the current 'SECTION' table, and the enable/disable command then do enable/disable on every handler belonging to the section specified. (In fact, a typical EventScript rule defined with Rule.eval 'compiles' to one or several 'Event.event' definitions, so I'm in reality only collecting Event.event definitions)
    Ah, i see :D
    Time to sort up rules, thanks Jan.
    Merry Christmas!
