    20 hours ago, jompa68 said:
    Really surprised how fast it is to send a string from EventRunner --> Node Red --> Sonos
    Installed sonospolytts to node-red
    requires
    I updated my latest flow with a pollytts node.
    It also moves .volume field from event to msg.volume before sending to pollytts node. In theory that should allow control of volume but I can't make it work. It always play with the pre-configured volume in the node. I have an old Play5 so I'm thinking that could be an issue - can you control the volume? {type='speak', data='Hej', volume=50} should work.
    Changed 'speek'->'speak'
    i will check this when i come home and report back.
    Ok pushed new version of EvenRunner.lua and EventRunnerDebug.lua,
    Variable 'NodeRed' at beginning of EvenRunner set to true will start node-red listener (_PORTLISTENER)
    _debugFlags.node_red set to true will log incoming events from node-red server
    5 hours ago, jgab said:
    Played a bit more with node-red
    Something wrong with the node, can not import it from copy and paste
    Ok, updated post - see if it works now.
    oh! that flow did crash my node-red. Did not like dir /tmp settings
    That must be the pollytts node?
    Yes, did just add my settings and leave yours first. But now after i remove your settings it works.
    Ok, great! - maybe if I remove my settings before copying the flow and pasting to the post it will work better for others.
    tested this now and volume does not have any affect
    and speak does not work
    Edited by jompa68
    Strange because it seems to be the last feature added by the author of sonospollytts.
    8 hours ago, jgab said:
    rule("remote(NodeRed,#https{url='https://api.dryg.net/dagar/v2.1/2019/01/03'})") rule("#response{data='$d'} => log('Got back:%s',d)")
    when i test this with ZBS it works ok but not with HC2. I can see in node-red that it goes the right way but could it be so that it don't start scene because of authentication is needed?
    #echo does not seems to work, tested with ZBS and HC2(samme issue with authentication?)
    answer myself
    Yes it was authentication problem, did add login:password in url and it did work
    Edited by jompa68
    Yes the zbs and hc2 in the send event subflow need to be configured. The zbs with the IP adress of the PC and the hc2 with the hc2 credentials (basic authentication) and ip.
    hmm, I could make the zbs node not needing any configuration if I set the ._from field to be the address back to the zbs server, instead of just ‘-1’...
    Ok,
    I updated the flow in the last post
    and the problem with speak and volume is that the node wants the volume as a string.
    {type='speak', data='Hej', volume='50'} works. However, I had hard-coded the volume to 50 when I tried to debug it so the flow needed to be updated too. Now the volume works for me.
    updated flow to control my IKEA outlet/plug (in Domoticz) from EventRunner
    /monthly_2019_01/20190104_13-26-25.png.aa55968354b44211fd543b1cb168227f.png" alt="20190104_13-26-25.png.aa55968354b44211fd543b1cb168227f.png" />
    node-red flow
    EventRunner
    does new function for hue map support :toggle?
    i suspect that it was :toggle that did create error and stopped scene. Or can you see some other mistake i have made?
    No, they should support toggle (because they support getValue). You have a log of the error?
    However
    does not make sense in the rule. You need to test against a variable set to the state.
    However, it may still be an issue with hue as it is new code. If you just do an rule(“@@00:00:04 => hue.huekok.lampastora:toggle”) will it blink?
    Hmm, now it does not give any error. I changed that state part to a variable instead.
    Then it could be that. I will check it up when I’m back home this afternoon/J
    In ZeroBraneStudio when you test BankHoliday function you can declare BankDays like below without it gives any error.
