    Ok, that's the problem.
    That means that you can do 596:on and 596:off. However, to toggle you need to know if it is playing or not - how do you do read the status?
    Possible to do thia
    43 minutes ago, jompa68 said:
    Possible to do thia
    Ok, a bit more elaborate
    I assume they return 'on' and 'off' as state. Otherwise change to whatever value represents that.
    I'm not a fan that Fibaro "reuses" commands like "turnOn" this way. Many devices you want to toggle and one usually implements that with getValue to get the current value. Now you need to treat different devices specially. . An alternative would be if they implemented a "toggle" command, and that all devices that accepts "turnOn" and "turnOff" also accepted "toggle".
    Yeah, seems to work. Thanks again
    jgab, Working through all examples in your previous conversations in my effort to change most of my scenes to your EventRunner model. Succeeded so far with all my light scenes, even 'Närvarosimulering'. Stumbled on  this code in your alarm example:
    Quote
    -- If safe for 20min during night, consider quietAtNight -- used for enabling ring
      rule("for(00:20,dwSensors:safe & pirSensors:safe & 22:30..05:00 ) => post(#quietAtNight); repeat()")
    -- If safe for 10min, consider quiet, used for turning off running alarm
      rule("for(00:20,dwSensors:safe & pirSensors:safe & 22:30..05:30 ) => post(#quiet)")
    Shouldn't it the second rule read ?
    Quote
    rule("for(00:10,dwSensors:safe & pirSensors:safe & 22:30..05:30 ) => post(#quiet)")
    And one more question. How can I get e message which dwSensor was breached?
    Quote
    Yes, the second rule should be 00:10 if you want 10min. I seem to have copied the previous rule and forgot to change the time value.
    When a rule trigger, the triggering event is available in the variable 'env.event'. Because it's a door/window sensor the event looks like
    The last 'value' field is filled in by the framework. Anyway that means that the device id is available in env.event.deviceID
    Because you have done Util.reverseMapDef with you "hometable" you can get the name of the device with Util.reverseVar(<id>)
    log(<text>) logs the message to the console but also returns the string. That can be used to send it as a message. <phoneID>:msg=<message> sends a message to a phone with <phoneID>. <phoneID> could be a table  with many phoneIDs or a variable...
    Let me know if you have other rules that you would like help with
    /J
    Btw, in the next release of the framework, Util.reverseVar will be a builtin eventscript function named 'idname(<id>)'
    Hi Jan,
    got an error when running my above mentioned AlarmEventRunner scene (ID# 313)on the HC2:
    DEBUG] 08:29:45: Posting {"type":"pirBreached"} at Fri Jan 11 08:29:45
    [DEBUG] 10:52:16: Posting {"type":"dwBreached"} at Fri Jan 11 10:52:16
    [DEBUG] 10:52:16: Error in 'dwSensors:breached => post(#dwBreached); log(dwSensors:breached)': /opt/fibaro/scenes/313.lua:1048: /opt/fibaro/scenes/313.lua:200: bad argument #1 to '_format' (string expected, got boolean)
    [DEBUG] 10:55:38: Posting {"type":"pirBreached"} at Fri Jan 11 10:55:38
    [DEBUG] 10:55:56: Posting {"type":"pirBreached"} at Fri Jan 11 10:55:56
    /F
    2 hours ago, FrankT said:
    Hi Jan,
    /F
    Yes, the 'log' function expects a format string before the arguments - it's more or less an alias for Lua's '
     log(dwSensors:breached) is the same as log(true) if a sensor was breached and that doesn't work. The solutions is log('%s',dwSensors:breached),
    To be clear, the first argument can be a string without formatting directives, but then it's the only argument. Type log("Hello").
    New version, v1.9. Download EventRunner.lua, EventRunnerDebug.lua, globals.data
    Not a lot of new features but some changes in scene setup.
    -Lots of restructuring in EventRunnerDebug.lua (preparing for coming features...)
    -Fixed timeout parameter in offline emulation of net.HTTPClient().
    -Some changes in configuration variables. This is now how it looks in the beginning of a EventRunner scene:
    Running _GUI *and* _SPEEDTIME at the same time is not recommended (It slows down speedtime significantly. Trying to find a remedy for that for a future release.
    HueIP and _HueUserName have got an underscore in front of the names - trying to be consistent in naming.
    To receive events when running offline set _EVENTSERVER to true. Both for node-red events and when sending events back from a HC2.
    _deviceTable has no real significance as globals are read in by _System.readGlobalsFromFile, but it's always good practice to use a constant for the HomeTable global name anyway.
    Likewise, the _myNodeRed declaration in the example above has no real significance either. It's just for remembering the address to the node-red server. To receive incoming node-red events set _EVENTSERVER to true.
    To debug incoming events to the event server port (Hue events etc), set _debugFlags.eventserver=true
    To debug interaction with the Hue node, set _debugFlags.hue=true
    I will start to update documentation as the setup procedure has changed with the new way of handling globals offline.
    -When running offline, if _System.readGlobalsFromFile() has not been called before the first fibaro:getGlobal/fibaro:setGlobal is called, _System.readGlobalsFromFile() will be called to setup globals from "globals.data" per default. That means no need to call  _System.readGlobalsFromFile() if "globals.data" is setup. However you can call ex. _System.readGlobalsFromFile("myOtherGlobals.data") to setup another set of globals. It is also possible to change the _GLOBALS_FILE variable to another default than "globals.data"
    -function 'idname(<deviceID>)' available in eventscripts.
    ...will log "Sensor bed.sensor breached" or "Sensor kitchen.sensor breached"
    -sunset and sunrise is now calculated when running offline.
    Need to set _LATITUDE and _LONGITUDE of your HC2 in the beginning of EventRunnerDebug.lua file.
    This makes fibaro:getValue(1,"sunsetHour") return "real" values.
    Is updated at 00:00 every night in simulated time, just like on the HC2.
    thanks for new version!
    Can I use more hue bridges? It means ie. _HueIP = {“192.168.1.10”,”192.168.1.11”} and same for _HueUserName
    Not yet. It's doable and on my todo list.
    ok thanks!
    Need some more help. The alarm scene I have been using is a modified scene from Bastian (mkshb.de) and I use Fibaros UBS scenActivation.
    I've tried to use EventRunner but failed so far because I don't know how i can get the scenID.
    rule("sceneID = ???????).
    %% properties
    228 sceneActivation
    %% globals
     local rfidreader = 228
    local checkWindows = true   -- true
    local sceneId = tonumber(fibaro:getValue(rfidreader, "sceneActivation"))
    local sirene = 198
    local reddiod = 257
    local greendiod = 258
    if sceneId == 21 then
      if globalalarm == "armed" then
        unarmAllSensors()
        debug("green","unarmed")
      elseif globalalarm == "unarmed" then
        if checkWindows then
          checkWinAndDoors()
          sendPopUp(openwindows)
        armAllSensors()
        debug("red","armed")
    /F
    A rule that should trigger on device 228’s sceneActivation and test on scene 21 would look like
    rule(“228:scene==21 => ...”)
    I could help you give an example of how to translate the rest of the code tomorrow morning when I’m back home.
    /J
    @jgab
    in last version I have this error:
    Error loading rules:EventRunnerDebug.lua:185: attempt to index field '_globals' (a nil value)
    in row:
      for _,v in ipairs(vars) do
        fibaro._globals[v.name] = {tostring(v.value),osTime()}
    It looks that fibaro._globals is nil and I think it should be  fibaro._globals = { }
    I migrated from version 1.7 to 1.9. and I tried to create the globals via those two rows:
      _System.copyGlobalsFromHC2()   -- copy globals from HC2 to ZBS
      _System.writeGlobalsToFile()   -- write globals from ZBS to file, default 'globals.data'
    Edited by petrkl12
    Quote
    /J
    Thank you, that would be nice.
    53 minutes ago, petrkl12 said:
    @jgab
    in row:
    You do it inside main()?
    yes, of course
    oh
    I have _REMOTE = true
    17 minutes ago, petrkl12 said:
    yes, of course
    I’m sorry I need to test it when I’m back home - you have a fix early tomorrow morning. /J
    OK, thanks a lot
