14 hours ago, jgab said:
Ok, to be clear. It's only the code that respond to a PING with a PONG that is built-in to the ER framework currently (that's a 1-liner)
The logic to ping scenes and restart them is not built-in. Then you have to add code like the one from Oct.25.
here is my WatchDog scene:
and in every other ER scene id={222,227,228,217,192,226} I have:
Interesting is that when I use only PING a PONG in WatchDog scene and in other scene I don't have anything because I want to use your build in one - it doesn't work.
Any idea where could be problem?
    Very strange - it's the same logic just different names of the messages.
    However,  @jompa68 seems to have made it work (again) using v1.10.
    In your scene you disable the scenes and then start them with with some intervals. Wonder if that creates some problems...
    You could start pinging after you start them up
    Btw, you can define the local vars in the loop to have access to them in the script - cleaner than to concatenate strings.
    ok thanks
    I will have to test version 1.10 ...
    New  version 1.11 pushed. EventRunner.lua and EventRunnerDebug.lua.
    - Multiple Hue hubs supported.  The setup looks like this now
    If there is only one Hue bridge/hub the hub name part of device names can be left out and defaults to that hub name.
    Ex. if we have a hub with name "Hue", Hue.define("My light","mylight",88) is the same as Hue.define("Hue:My light","mylight",88)
    Disclaimer, I only have 1 Hue hub myself so there could be bugs...
    A small addition to the Hue support.
    New firmware for Hue lights (Dec 8) support "Power-on behaviour". From the app one can choose default (standard bright) or power loss recovery, that is the value the lamp had the last time (before power off).
    However, there is also a customs settings that is not selectable by the app but can be set via the API.
    The advantage is that we then can set whatever values a lamp should start with when it is powered on - and we can do it even if the lamp is off!
    So, in the morning or in the night you can set the lamp to dimmed values and it will start to those values when powered on(!)
    Example:
    ...and the lamp will startup with a red color...yay!
    If the argument to <id>:value is a table with a 'startup' key it is sent to the light as ' /config/startup/<table>', so whatever is supported as startup parameters will work.
    If the id is a Hue group, I will call the config on all lights in the group.
    The custom setting will show up in the Power-on behaviour tab in the app for the lights.
    Google "hue power-on customsettings" to find more info...
    This should work
    Addition: If you flick the switch on a lamp twice within ~20s, it will always revert to "full light". It seems to be a security things so bad defaults wouldn't hinder lamps to light up a room in an emergency case, like fire.
    A new flow for node-red.
    The bottom part is the 'node-red-contrib-wemo-emulator ' node that pretends to be a wemo device controllable from Alexa. I tried the other Alexa echo node that emulates Hue but I didn't get it to work. Anyway, it's easy to work as it runs locally and doesn't need any cloud setup.
    Setup the node rename it and configure it and you can say "Alexa, turn on Party' or 'Alexa, turn off Party'. It will be sent to the HC2 or the ZBS off line as an EventRunner event.
    The topic is the name of the "device" and the payload is the command.
    In the response node, if msg.ESceneID=-1 it will send it back to the configured ZBS instance, else it will send to that scene ID on the configured HC2 instance
    and the log running on ZBS is
    ...and it responds very quick.
    @jgab thanks for adding support for more hue bridges!
    I will start testing today with my 4 bridges :)
    Do i need to change layout of HomeTable now to implement 1.11?
    Edited by jompa68
    No, if you only have one Hue hub there is no change.
    But you need to setup the new Hue  credentials/IP
    ...and just give it the name "Hue".
    Hue.define should work as before.
    have trouble to get the command to my HC2, it send only to ZBS. It works with ZBS.
    What have i missed?
    You must change ESceneID in the response node. If it's set to -1 the flow in the upper part will send to the ZBS node, otherwise it will send to the HC2 node, and to the scene with ESceneID
    If you want different commands to send to different scenes you need to have several response nodes with different ESceneIDs. I don't know if there is a more elegant way to do this...
    Btw, have you configured the HC2 node in the flow below? (actually in the top of the flow canvas)
    If ESceneID is less than 0 the message is switched to the ZBS node, and if it's over 0 it is switched to the HC2 node.
    Working now, thanks
    Bad that it don't work with Google Home,  i have one GH and one Alexa.
    @jgab
    1. this syntax doesn't work:
    2. I think toggle command doesn't work for hue groups
    3. this also doesn't work
    Edited by petrkl12
    3 hours ago, petrkl12 said:
    @jgab
    The second argument to Hue.define is to define a eventscript variable with that name. So that "variable" is only available inside rules.
    So 1. could be
    or
    ..and 2. has the same problem- There is no Lua variable named 'HueSwitchGarden', only an eventscript variable, available inside rules.
    However, Hue.monitor takes a ID or a "fully qualified Hue name", so this works
    or you can do monitor in a rule
    Anyway, so here afterwards, the argument to define an eventscript variable with Hue.define was unnecessary.
    I, and @jompa68, have the eventscript mapping in the HomeTable anyway. If it was Hue.define(<Hue name>,<id>) one could do
    define(<eventscript variable>,Hue,define(<Hue name>,<id>)) if needed.
    So, for the next release I may change Hue.define... simpler is better.
    Thanks for your answers!
    I have some other questions/ideas about hue as I want to transfer all my hue rules/scenes to your ER:
    1. Is there possibility how to define hue via hue id. I know in this case i will have to say what is light, group, sensor etc.
    Something like:
    3. How to run hue scene for groups - based on scene id, based on scene name? Do you have any examples?
    4. How to run hue lights/groups with combination of parameters ie. "on":true,"hue":5996,"sat":254,"bri":127
    5. Is it possible to use:
    6. How to check if deviceID (ie. 30500) belongs to hue in event?
    7. Do you have any examples for using Hue motion sensors, light sensors, temperature sensors in ER (all is one physical device) ?
    Sorry for many questions but I don't have any other source :)
    Just idea for hue support:
    Current solution for Hue.monitor is OK for less number of monitored devices.
    I think if there will bigger number of devices where I will need to check sensors, lights,... there could be better to use following pattern:
    1. read info about all sensors, lights, groups via ie. /api/../sensors every xx miliseconds (define period)
    2. compare if something was change from previous reading
    3. if true in point 2 then to check define hue devices in ER if something was change in specific/define device
    I think it could be more efficient. What do you think?
    I think there could be both option - for a few hue devices current solution, for more devices new one
    Edited by petrkl12
    Something like:
    1. I pushed a new version with a new function Hue.hueName(<Hue descr>) so you can do
    Hue.hueName gets the "fully qualified name" from the Hub name and Hue id with that specific syntax (SensorID, GroupID, LightID)
    2. That was a bug. Fixed in the pushed version.
    3. By name.
    'Bright' is a scene defined on the hub where the group is
    4. :value again
    5. No, loop over the table and call monitor.
    6. To check if an id is a Hue id do
    7. The only thing I have is a button switch... but let's see if we can get it to work,
    Hue.monitor takes a third argument that is a filter. The default is {buttonevent=true, on=true}
    When the state changes for a Hue device, for every property I check filter[prop]==true ? and if so, I do a
    That means that if a device changes the on property from true to false or the other way, I will post the event
    _hue is just a marker that it comes from a Hue device and _sh that the post shouldn't be logged.
    On the HC2 there is no trigger with properyName=='on', so we want to rewrite it to a standard 'value' trigger and we do that with the rule
    We could do the same with button events but there is no code for that at the moment. (probably rewrite it to a centralSceneEvent)
    Anyway, I don't know what the names of the properties are for your device, but assume that they are 'motion','temp', and 'lux'
    would make it start to post events when those properties change values.
    Ex.
    ...and you can add an Event handler like above to rewrite the event to look more like a fibaro temp sensor if you want.
    There is problem because fibaro:getValue(id,'value') is kind of hardcoded for Hue lights currently. fibaro:getValue(id,'temp') works though
    Yes, that's a possibility - how many sensors do you have?
    One can get the full state of every device on a hub (that's what I do at startup), but Philips recommend in their development guidelines to not do that more often than every 10s for synchronisation tasks. Doing three calls (lights, sensors,groups) for every hub every 500ms will generate some traffic... I still wish that they fixed a call-back mechanism.
    My sensors in 4 bridges
    25x Hue dimmers
    11x Hue motion sensors (motion, light and temperature sensors inside)
    Motion sensors:
    Light sensor:
    Temperature sensor:
    So,
    would start to post events for those devices.
    OK thanks a lot for your support !
    38 minutes ago, jgab said:
    3. By name.
    but there are more same names for scenes in one hub as you can see:
     I'm wating for 3 years ... but still nothing btw. based on developers pages this is most wanted functionality ...
