  • 4
Yet Another lastWorkingRoute visualiser
Please stop forcing the use this app!
Edited by 10der
  • Like 7
  • Thanks 3
3 hours ago, 3JL said:
how to use this information for our benefit? :)
benefit? hmm, when everything works, no benefit. When something didn't work as expected, it might help to find the issue (like a cleaning personal removing wallplug, or daughter giving party each every time parents not at home - now you might wonder why, well, lot of people means lot of objects blocking zwave, and when at that time wind gust comes and breaks your venetian blinds, you will not know why scene was not working). During last years i visited lot of houses/flats, with sometimes very wired issues, especially combination of bad routing plus broken or misconfigured devices makes things very bad. For years it was always job for some exerts, zwave alliance was always like "add extra device when something didn't work" - which of course didn't make things better when devices are not working properly in first place, it will even get worse! But now there are tools available for installers and power users. Yes, sometimes it is hard to understand, but the basics are simple -> less communication is better, more devices is better, stable gateway is a must (add everywhere variable to be able to stop all scenes / VDs when necessary with one click), understanding of dependency between zwave gateway and external services is (more and more) important.
On 8/31/2018 at 11:47 PM, 10der said:
06/09/2018 23:00 - some minor UI updates
Edited by AutoFrank
higher res image
    @AutoFrank
    Quote
    BTW - how long does it take to load and render ?
    : just 2 call API with devices & rooms, but rendering is not quickly cuz, for example, chrome rise some warning exception on hooking each node.  and I do not know how to prevent this.
    all good - thanks @10der
    I dropped in the rooms and devices files
    Hello @10der
    I did some comparings between your output and /api/devices of HC. It seems that some routes are in a sorted order in the graph. The routes (I can see in HC) are different. Let me explain with a picture 8-)
    You see screenshots of api/devices/ of HC and firefox with debug console. There seems to be a kind of sorting process and then routing displayed wrong. I hope it is understandable what I mean :) Any ideas? Thank you for your efforts.
    omg! you right!
    @AndyY thank you so much. fixed!
    1 hour ago, 10der said:
    omg! you right!
     first post updated ?
    Yes!
    Yes
    Thx
    @Hey @petergebruers . Yes, I hear from you more times what Z-devices do not operate with the concept "distance/etc". but it looks like crazy: 519 - UBS. it located near HC2... 40 cm (sic!) - shy of within arm's reach.
    • lastWorkingRoute: "[1,815,465]",
    815 - upstairs (lol) bedroom
    465 - upstairs (lol) bathroom
    it's like a trip to Belgium via Moskow... , particularly given what I am living near Poland...
    kill me! ;D
    Edited by 10der
    @10der LOL
    I have to guess... But this explanation seems plausible.
    If your UBS sends data, because its input changed or the temperature probe wants to report... It will try to deliver its message 3 times...
    (a) If the network is very busy... It might collide, collide an collide again. That means "three failed attempts = try next available route"
    (b) If you have another source of interference, data or ACK might get lost 3 times.
    (c) If the HC does not respond in a timely manner (I don't know if that is technically possible, I don't know if and how the controller chip could be "to late", maybe because a queue fills up) again after 3 attempts the UBS decides "I cannot get to node 1, have to try routes".
    Can you please tell me the "node IDS" of 815 and 416? Here's why!
    I just tested an old HSP02 motion sensor. I took out of direct range, and observed the captured data:
    - 3x node ID 1 -> direct connection failed.
    - 3x node ID 3 -> NOK
    - 3x node ID 5 -> NOK
    - 3x node ID 7 -> NOK
    After this, the HSP gives up, for now, and the data never reaches the HC2. The device is really orphaned now.
    Why that sequence? Impair numbers only? No... Node 2 does not exist and neither does node 4. I probably did a few exclude and includes when I built the network. Then node 6 exists, but is battery operated so it is not a candidate repeater.
    In other words... It's trying three mains device ordered by node ID.
    It learned those node IDs when I included it very close to the HC (and far way from where it is failing now.).
    Because I have moved the device, the neighbors it stored  are no longer really neighbors.
    Then I bring the HC2 a bit closer to the HC2, because I want to send it a "update neighbor" command.
    After this:
    - node 31 Ok -> node 23 OK -> node I OK
    - Routed ACK 1 -> 23 -> 31
    Now the device has established it can reach the controller via route 31, 23.
    The I do "mesh reconfigure again" so the HC2 gets the LWR. This would appear on your chart with device IDs and if you look at the raw data on your HC you will see
    LWR: [1,X,Y]
    X is master ID of node ID 23 and Y is master ID of node ID 31
    When I move the sensor about 1 meter... It selects a one-hop route over node ID 8
    If you do not have a sniffer, and you do not "update mesh" before you run your visualizer, then you completely miss the dynamic nature of routing. You'll be looking at a snapshot of 03:00 AM.
    815   nodeId: "143",
    465  nodeId: "80",
    519 - patient :)  nodeId: "88",
    OK, looks random. Can you please mesh reconfigure that UBS... What LWR do you get? Do you have a Zniffer?
    had. sold. too expensive to have such tools, considering the fact that I am not distributor or developer z-devices... and now I am back to Ukraine and jobless homeowner :D
    [12:45:46] 519: Requesting neighbor list from the node is in progress
    [12:45:59] 519: Requesting neighbor list from the node is in progress
    [12:46:07] 519: New neighbor list received
    A-ha-ha
    • lastWorkingRoute: "[1]",
    how do you get the rooms.json and devices.json files?
    thanks
    thanks
    http://HC2IP/devices
    http://HC2IP/api/rooms
    right click and save.
    copy and save from browser
    So anyone figured why the Fibaro double relay Plus doesn't work when doing a manual get neighbor command ?
    Not yet, because... I do not own an FGS-223. The older versions, in my house, are all OK.
    Can also confirm that’s fact, colleague!
