  • 4
Yet Another lastWorkingRoute visualiser
Please stop forcing the use this app!
Edited by 10der
  • Like 7
  • Thanks 3
42 minutes ago, 10der said:
@FonsBrand
¯ \ _ (ツ) _ / ¯
Nice,
 but for me still not working.
As described before:
I placed the files index.html, load.php, devices.json and rooms.json in the www dir, in this case Fibaro2.
The file index.html has not been modified.
In the file load.php I have modified:
$username = $settings['username'];  <-- for username I filled in my username
$password = $settings['password'];  <-- for password I filled in my password
$url = $settings['hc2Url']; <-- for hc2Url I filled in my local IP adress
After opening index.html a blanc page and in de www dir, the devices.json and rooms.json are changed to 0 bytes.
Edited by FonsBrand
    6 minutes ago, FonsBrand said:
    devisec.json and rooms.json are changed to 0 bytes.
    the root issue here.
    but. you can;
    rename load.php to load.php.bak
    re-save devisec.json and rooms.json from browser manually
    and you should get a picture :)
    what happens with load.php you may see before... for example, you may call http://localhost/load.php.... add to load.php debug messages like die :) print var_dump etc :)
    Edited by 10der
    but. you can;
    Thanks 10der,
    after renaming load.php to load.php.bak it is working.
    @FonsBrand welcome!
    10der please, you can also add the old version that existed before changing to Select device: input.
    I was stupid to download and overwrite the old index and load files. The new files do not work at all. Rooms and Devices files become 0 bytes with the latest version.
    The previous version just gave me the result I wanted.
    instruction how to config load.php in header!
    @RH_Dreambox simnple create and fill
    example load.settings  for load.php
    Edited by 10der
    Load.php is properly configured but the latest version no longer works, Rooms and devices are empty.
    I do not have a web server so I run PHP on Windows according to tips from you.
    @RH_Dreambox can you call load.php directly ?
    But anyway thank for reporting I’ll check at evening. Issue not in index.html — issue just in load.php
    @RH_Dreambox can you put this file and call load.php directly?  here is an example what you should get.
    Edited by 10der
    http://My_PC_IP/php/load.php
    The result, not so good...
    The site can not be reached
    ERR_CONNECTION_REFUSED
    If I run index.html the files rooms and devices is still empty (0 bytes)
    @RH_Dreambox Sir. kill load,php at all.
    save files manually.
    otherwise configure load.php via load settings properly!
    The new load.php is properly configured and I use exactly the same login as on the older load.php that worked.
    Unfortunately, I was stupid enough not to make copies of the older files before I tested the latest version.
    But if you have copies of the older files, I'm grateful if you want to post copies of them.
    I can, however, manually create rooms and devices, but it will be quite tediously every time you want to check the routing because I have two HC2.
    There must be something with the new code that does not work with PHP installed locally on my PC.
    Edited by RH_Dreambox
    old php file was
    (only start fragment)
    OK, but the index-file? There is a new input dialog that was not previously available. Could there be something changed that does not work for me?
    I am now testing to rename load.php and manually download rooms and devices.
    Then index.html works.
    I had the same issue.
    @FonsBrand @RH_Dreambox guys. put your creds in php file directly instead of a config file. idk why it's not works.
    if smb have a time - I can provide some instructions for php and we can trying to find issue.
    I don't use the load.php file, only the index.html and the self made devices.json and rooms.json
    is simply not working, if u use the load.php it wil clear the both .json files.
    added screen diagnostic
    @RH_Dreambox
    that load.php doesn't works for me :D
    Hello Guys,
    new files working fine for me. @FonsBrand, @Dreambox did you create new file with credentials? I think the intention is to have your special settings in a seperate file so you can update load.php anytime without canging your login data. Create empty file "load.settings" in same directory as other files an put:
    with your settings in in. Works very well...
    Anyway, whould it be usefull displaying older LWR in other colour? In my net most devices update LWR within 3 days. There are some few with older LWR which have no wakeup interval or have any problem reporting it to HC. In my opinion it can be a nice feature mark those devices in the visualiser and whould help find problems at first glance. @10der what do you think? ;)
