  • 4
Yet Another lastWorkingRoute visualiser
Please stop forcing the use this app!
Edited by 10der
  • Like 7
  • Thanks 3
    @AndyY for first THANK YOU very much for positive feedback and clearly describe how to use config file!
    about color - yes, propose me color :) cuz deciding what color best it’s pain for me, lol :)
    No, the new load.php with load.settings does not work for me. The rooms and devices files are not created, but I can still create them manually.
    What I note when I create them manually is that I have about 3-4 seconds delay before the login dialog pops up. Can this delay cause the files to not be created?
    I begin to think I have problems with the internal network :-(
    load.settings
    load.settings
    please call directly load.php and read screen error!
    for example, i am a simulated error with accessing to HC2
    I have also tried to pause Kaspersky Internet Security, but it will be the same.
    :) Hmm, difficult decision :). How about yellow?
    What comes to my mind, if we use a color for older LWR datetime, we loose other colors. Whould it be possible to use present color with a bright hue? NORMAL -> BRIGHT
    If that gets too complicated to implement we can take yellow. Thanks for your great efford!
    check box like  [X] Show LWR
    I think it can solve our problems :)
    Hello 10der, did you do already something? No problem at all ;). I don't know much about js but I did some copy&paste and try&error in your index.html :). Result:
    Maybe not perfect but it works for me. If anyone is interested try attached file index2.html. I only added 3 lines. Hope this is ok @10der
    Since 3 days ago my network stopped doing the mesh reconfiguration every night.  I am not awake at that time to actually look at the status box, but judging after the result of this script,  all were last updated on the 25th.
    Anyone else experienced this ?
    Fibaro Skynet is dead, you won! ;)
    Many users on this forum dreaming about turning off this feature....
    But if be honestly idk what happened.
    Mine updated this night again.. and have some very weird results.... Non-logical routes and a few nodes never got an update at all (purple)  6 of 64 devices are purple..
    Just FYI, it works on mac as well on chrome and safari
    I downloaded the 2 files on page 1, updated with my credentials/IP
    saved the 2 files, devices.json and rooms.json from the apis:
    http://<IP>/api/rooms
    http://<IP>/api/devices
    Started a simple HTTP server in the downloads-directory with: python -m SimpleHTTPServer 8000
    Then, by going to 0.0.0.0:8000 you will get the index.html-file.
    Excellent!
    Edited by hansib
    thank you  @10der thanks to you i've got a nice spaghetti soup :)
    Less funny if I loose 2 of my devices I'm "loosing" half of the network. I don't understand why so much devices are using those 2 nodes to build the routes.
    I've got 50 extra devices splitter between  2 other machines, both are slaves of the machine on the graph displayed. Didn't had a look to those networks yet ...
    Any idea doctor ?
    Edited by Tony270570
    @Tony270570 wow. You're right, this is pretty magical.
    but I am not a doctor :) But I know who is doc here :) @petergebruers
    thoughts aloud: turn off power on one of.. and you lose :) look like crazzzy!
    Don't know if magical is the appropriate word :-D Not want to bother @petergebruers he already spent lot of time for the community but if somebody from the @FIBARO team wants to have a look inside the beast, i'll let them in.
    This weekend I'll physically disconnect the 2 overloaded devices and force to rebuild the entier network , then read the result, I'll then reconnect the 2 devices and rebuild the neighborhood only for these 2. I'll then check if it remains more "logical" after the daily automatic network rebuild.
    To be followed.
    Thank you @10der as usual nice job ;)
    No no no no.
    1) This is not TCP/IP routing. It is Z-Wave routing. If it *was* IP routing then loss of those devices *might* be a catastrophe (unless you have special routing protocols and a backup router).
    2) This is only the last working route. Please check text output of my script, the devices have plenty of alternatives
    For example:
    As you can see, LWR of device 86 indeed contains "4" as a hop.
    Device 4 is acting as a router for 14 other devices as well. (the data is slightly different, because this report says "2018-09-04").
    But this part "# 32 [1,4,1090..." means device 86 has 32 (thirty two) neighbors! It is not an orphaned node.
    Also, device 4 is *not a bottleneck* because in Z-Wave only one device can talk at once... All communication happens sequentially. When the radio channel is busy, no other device can talk.
    If you power down those (magic) "hub" nodes before 03:00 and turn them back on after 04:00 the HC will send new routes to all devices. Interesting experiment to do...
    In fact, you can turn them of right now. All impacted devices will then select a different route, but you cannot see that on this visualizer, unless you run neighbor update on an impacted node (to update neighbors, remove node with device id 4, get new routes and update the LWR data on the HC). You might notice a "glitch" but it should not break down.
    EDIT:
    I'll keep repeating this until it sinks in... The ROUTER is the SENDING device. The devices in between, the hops, are "repeaters". They make no routing decisions at all. Z-Wave is source routed. This means: Node 86 asks node 4 to send data to the controller. The decision to use node 4 is made by the sending node.  Node 4 dutifully accepts the packet from the sending devices (86) and forwards (repeats) it to the controller.
    Even if you have 4 hops... It is the sending node that decides which nodes to use.
    Edited by petergebruers
    no no no no & no ! you said that you slow down !! :P
    This is why I use " " when I wrote "loosing" :)
    So is it correct if I say that having one device as a repeater for 32 other devices might cause some delay if several devices starts taking at the same time? could we consider such situation might become in some cases a bottleneck ?
    EDIT  : OK sorry understood it is exactly the same in direct communication with the HC. Extra question is a simple device has the same capacity as the main router to handle a stack of messages ? if I understand you well I'd say yes, but do I understand you well ? :)
    This is exactly what I'm expecting, I'll check that.
    Correct ! I said i'll force rebuild the network for those 2 devices and I was wrong I need to rebuild the entire network instead. Thank you Peter for the clarification !!
    Well registered and understood :-D but why node 4 is the center of the world in this house ?? it's really place less then 2 meter from the HC2 does it mean that I need to move the HC2 to get a better communication with all those device ? I'll also try this, I've got a stronger antenna and I'll connect it tonight !!!
    Peter thank you X 1000 for your lights ...
    ORA-03113
    7 hours ago, Tony270570 said:
    ORA-03113
    End of file communication ? I do not remember now, cuz more than 10y now I am MS SQL DBA :) but I clearly remember Oracle SQL ;)
    And ha ha if I right guess about your nick ... you are one month older than me ;)
    Totally off topic here ;)
    Edited by 10der
    You're seeing right ! Let me guess you're from Jun :) the EOF was addressed to @petergebruers, he's spending so much time helping people and I don't want giving him extra work, but I know I has understood the message ;)
    off topic closed ;)
    ORA EOF
    :-D
    Give me some time to formulate some answers. And while you're waiting, you can play Another exciting game of Clusenix
