  • 4
Yet Another lastWorkingRoute visualiser
Please stop forcing the use this app!
Edited by 10der
  • Like 7
  • Thanks 3
7 minutes ago, 10der said:
that’s fact, colleague!
Thank you, "master of the visualizer"!
Guest chaicka
I have both the older z-wave double relay switch (FGS-222) and the newer z-wave plus double switch 2 (FGS-223). Only the newer FGS-223 is mis-behaving (not responding to z-wave mesh reconfigure and visual-mesh shows last updated 01/01/1970 despite this FGS223 module was recently re-included). @T.Konopka, possible to have a look at the FGS-223 module with firmware 3.3 if there is really something wrong with HC2 getting mesh info from FGS223?
W dniu 9.09.2018 o 21:12, Momos napisał:
So anyone figured why the Fibaro double relay Plus doesn't work when doing a manual get neighbor command ?
Send command on root device (hidden) not endpoint
@A.Socha Thank you for the suggestion. It doesn't work unfortunately. Still nothing.
/monthly_2018_09/image.png.5299260259addd714a1ce144076adf24.png" alt="image.png.5299260259addd714a1ce144076adf24.png" />
Guest chaicka
Done that. Nothing.
It's the S0 in my screenshot and it is also the one which has the firmware check button.
Even done the command with the Master (hidden) device (FGS223 Stu in my screenshot), nothing too.
same. tried all . nothing.
@chaicka @Momos
Sorry my mistake send command on master device
  @10der nice job
You can mark battery devices and FLIRS device on other color because they send only command - they are no taking part in routing as a hop, then you will see few potential bugs (office motion should not be a hop as a battery device)
    nice idea, will do!
    index.html updated
    now all battery powered devices or FLiRS* devices are "gray:
    * FLiRS — Frequently Listening Routing Slaves — the device periodically quits the sleeping mode on a short period and checks, whether a message is sent to the device. If no packets are present for this device on air, the device goes back into the sleeping mode.
    Guest chaicka
    1 hour ago, A.Socha said:
    @chaicka @Momos
    Nothing happens. Using same script on another Single Switch 2 works. But on the problematic FGS223, nothing happens.
    @chaicka then is problem with device, try soft configuration maybe that will fix problem on problematic device
    3 hours ago, A.Socha said:
    Still nothing. And i doubt that there is a problem with the devices as all double relays plus do the same, still they work very good.
    I have also soft reconfigured and excluded/included at least 3 times.
    @Momos when you turn ON /off on this device it changing state and report energy? if yes you are sure that you sending command to master device? If on all is yes then i can only suggest contact with support to check what is a problem using remote session. I checked on my 4.510 so i can tell that is not a software problem and support must inspect your problem
    7 hours ago, 10der said:
    index.html updated
    @10der, you might simplify load.php as well, we don't need to read all non-zwave devices and plugins, so you can query directly for what we looking for:
    or
    Edited by 10der
    On 9/7/2018 at 6:31 PM, AutoFrank said:
    copy and save from browser
    It is not working.
    I loaded the data of the devices and the rooms an saved them.
    see screenshot 1 the json files are 549kB and 5kB.
    screenshot 1
    when I load index.html the files are regenerated(???)  bij index.html and are empty, see screenshot 2.
    screenshot 2
    and thee webroser shows a blank screen, see screenshot 3.
    screenshot 3
    I use wampserver v3.0.6 on windows 7.
    I tried in Firefox, Safari and Chrome.
    All the seem result.
    thx in advance
    Fons
    Edited by FonsBrand
    @FonsBrand can you load Chrome => press F12 => [Console] => F5
    show me error window in Console
    Thank you!
    Edited by 10der
    Thank you!
    No error to see, only >
    when I put a 1 in the inputbox en press the button then I get,
    index.html:217 Uncaught TypeError: Cannot read property 'body' of null
        at HTMLInputElement.select.onclick (index.html:217)
    @FonsBrand
    ¯ \ _ (ツ) _ / ¯
