  • 4
Yet Another lastWorkingRoute visualiser
Please stop forcing the use this app!
Edited by 10der
  • Like 7
  • Thanks 3
14 minutes ago, chaicka said:
Guys, is this graphical representation still working with HC2 4.530?
I don't know, but my non-graphical version is still working. Which suggests there were no fundamental changes on 4.530...
Guest chaicka
Thanks Peter. I will check your script out later tonight.
    hi Sir,
    On iPad also works
    Hi
    thanks for your great work - I ran the script for my HC2, where I have 55 nodes (according to ZWave Network page in GUI) but I only see 39 in your script's map and the ones I don't see are in the GUI, working, and also in the devices.json file
    Edit: I have also tried re-fetching the json's using curl directly on the RaspberryPi but still only 39 devices show up on map...
    Where can I look for a clue?
    Thanks!
    Riccardo
    Edited by rcanetta
    Guest chaicka
    @10der
    I am seeing this in console. Include the page that's stuck on 'loading.....'
    Found the cause and fixed it. For unknown reason, after clicking synchronise in the Access Control page, there is now 2 accounts with exact same credential/username (one is Super User account, one appears added out of nowhere - perhaps the Fibaro ID).
    Edited by chaicka
    Fixed
    This script is simply amazing! Finally I can see the routes and hops of each device, thanks for sharing!
    would you think it Ian possible to kind of “re-use” it as a function to check the routes - and especially response times - when running a scene? Like an extended Debug-function?
    Reason why I am asking, my “good night” scenes does a lot of things (20 blinds go down, 20 door sensors armed, 25 devices off etc...) so it sends a lot of commands at once (I have a 250ms delay implemented already). At one point (and I do not know which), the network seems to hang for a few seconds, sometimes 10, 30 or more and then continues... Wirh such a response time/routing debug you could see which device is causing the delay...
    Without global function I know you would have to include it in every scene but still...
    Happy to hear your thoughts...
    the current (last) routing showing how z-wave signal passes over nodes to HC2. You can't calculate the time between hops without z-wave sniffer.
    and last, current (last) routing stored in the device is not guaranty what device always uses this routing.
    for clearing again: my graph flow or list by @petergebruers only show current routing and can't help you find issues with delays. at all.
    this information like "just for your info" :)
    I thought so, too bad... thanks :-)
    @dcspock
    as an alternative to an epilogue :)
    for example you have a current route for device 123: 111 -> 222 -> 777 -> HC2.
    this route currently saved in device  123. You can get it by itself: http://hc2_ip/api/device/123
    lastWorkingRoute
    now you turn off 222 device.
    Hc2 stuck on 222 and   will get another field from device
    neighborList
    and will try to use a device from this list.
    Hi @10der any idea why I'm stuck at 39 out of 55 devices in the map? I tried again now to fetch the 2 jsons and run your great tool again - the map looks different from the other day, but still only with 39 devices... BTW I did a little script to fetch the 2 files directly on my raspberryPi
    curl -u [email protected]:password -o rooms.json http://HC2_IP/api/rooms
    curl -u [email protected]:password -o devices.json http://HC2_IP/api/devices
    Thanks!
    R
    21 minutes ago, rcanetta said:
    any idea why
    idk.
    for example please provide me here response from
    http://HC2_IP/api/devices/777
    where 777 is the missing device
    7 minutes ago, 10der said:
    idk.
    Hi here it is, from one of the missing devices (and I checked, it's in the devices.json)
    Thanks!
    R
    @rcanetta ok next step
    master
    http://HC2_IP/api/devices/392
    Edited by 10der
    master
    ok, got it - 392 is set to disabled because it's one of those devices that was causing the mesh network update failure error during night
    and actually since I disabled all the nodes that were reporting the update failure, my HC2 hasn't frozen anymore... so now I'm a bit concerned about re-enabling them.. what do you think?
    Thanks!
    R
    Interesting. Can you post json of 392 anyway? I'd like to see if there is anything special...
    of course here it is
    Thanks!
    R
    @rcanetta btw, on last FW Fibaro disable auto-update-mesh-networking.
    Quote
    btw
    was updated (succ!) Thursday, 10 January 2019 р., 02:16:09
    current routing also was succ updated tonight
     Friday, 11 January 2019 р., 02:16:05 (+1h)
    btw
    uhm... so the update is requested and done even if the node is disabled... I wonder why I did not have any more zwave network freeze then... I will re-enable gradually the master nodes involved and keep an eye on the map!
    Thanks!
    R
    So that's a FGS222 Switch 2x1,5kW, FW:  2.(0)2 - the json, parameters, associations, all look perfectly normal to me.
    And that means @rcanetta you are running a FW version between 4.500 and 4.520. I suggest you take the necessary precautions (extra backup, reread the recovery procedure, take into account business hours of Fibaro support, ...) and give 4.530 or the next non-beta release a try.
    EDIT: indeed, "disable" does not stop mesh update. fw >= 4.521 doesn't do auto mesh.
    Edited by petergebruers
    Yes, true I’m running 4.510 but my golden rule is not to upgrade during winter unless there is some bug with heating panel... so I’ll re-enable the nodes little by little in the area where I have intermittent zwave network, to understand what’s happening..
    thanks once more!
    R
