All-in-One Scene: How to do it Better
cag014
Hi cag!
The AOQ which one NTP server use? Because today the sunset at 21:18 in the AOQ, but in Hungary that time is 20:44.
Hi @cag014,
Only for the purpose of optimizing code, it would be nice if in one jM line multiple states could be the trigger.
F.i. :
{0,"`OverloopSwitch`",{state="sceneActivation=`But1Release`", trueAct={
    {"&SwitchScene","setGlobal","ArmSlapen","if {&Huisstatus:value<>Slapen}"},}}},
{0,"`OverloopSwitch`",{state="sceneActivation=`But1Single`", trueAct={
Two jM lines with the same action. This could be one jM line:
{0,"`OverloopSwitch`",{state={"sceneActivation=`But1Release`" or "sceneActivation=`But1Single`"}, trueAct={
I have a lot of these state triggers with the same action.
Edited by Rover
  • On 6/27/2021 at 10:57 AM, Rover said:
    Hi @cag014,
    F.i. :
    Let me se what can I do...
    Hi @cag014,
    F.i. :
    OK, have added the option, please notice it works for equal comparison only ( greater or less doesn't work)
    Please set the state to all possible options and use operator ==
    For example
    {0,"`OverloopSwitch`",{state="sceneActivation==`But1Release` or `But1Single`", trueAct={
    Since the string could be very long the full data won't be displayed in the table ( only first 30 characters).
    Using HcWebEye and by hovering the mouse on the line, full condition will be displaeyd.
    Let me know if it works
    Edited by cag014
  • On 6/17/2021 at 8:49 AM, SmartLifeSystems said:
    Hi cag! I have an interesting question for you. I have a WalliDimmer, and a WalliOutlet. In the AOQ I can change this devices parameters? I would like to change the device's LED color.
    Yes, you can do it
    for example to change on device with id 31 with arguments:
    parameter number - 5
    size of the parameter in bytes - 1
    value of the parameter to set - 128
    use -
     trueAct={"31", "setConfiguration,5,1,128"}
    SInce the last time I have checked that was few months ago, let me know if it works
    Edited by cag014
    On 6/21/2021 at 10:29 PM, SmartLifeSystems said:
    Hi cag!
    AOQ uses system timedate of the controller.
    Please verify that your system shows correctly the timedate.
    sometimes if the clock changed (summer/winter)  reboot might help
    Edited by cag014
  • I am sorry for a late response, but had a cataract surgery on both eyes...
    At least now I don't need the glasses?
  • On 6/20/2021 at 10:06 PM, bbolgar said:
    Hi!
    What would be the best way to set a switch to be on for 2 hours then off for 1 hour, repeating?
    Please try below
    {120,"`wallSw`,{state="true",timeoutAct={"`wallSw`,"turnOff"}}},
    {60,"`wallSw`,{state="false",timeoutAct={"`wallSw`,"turnOn"}}},
    When you will start the AOS the counting will be started from current state of the switch, meaning if the switch is on the 2 hours count will begin, if switch is off the one hour will begin.
    Just for testing please set let's say 5 minutes ON and 2 minutes OFF
    {5,"`wallSw`,{state="true",timeoutAct={"`wallSw`,"turnOff"}}},
    {2,"`wallSw`,{state="false",timeoutAct={"`wallSw`,"turnOn"}}},
    Edited by cag014
    For example
    Thanx @cag014 ?, it works beautiful! Very elegant ?
    It makes it possible to remove a lot of jM lines with the same remaining functionality!
    On 7/2/2021 at 3:00 AM, cag014 said:
    Yes, you can do it
    use -
    Hi cag,
    I tryed your code, but don't working. Did I something wrong?
    The problem was my location settings. The HomeCenter3 was the factory location. Now this is working fine.
    Thanks your help!
    Edited by SmartLifeSystems
    Your eyes is ok now?
    45 minutes ago, SmartLifeSystems said:
    Hi cag,
    Thanks your help!
    Here is the devices templates, if these help for you.
    Yes, thank you
    Just to see what doesn't work properly can you please use "+setConfiguration,X,X,X" in your jM lines.
    Let me know...
    Hi @cag014,
    Could it be this one?
    Edited by Rover
  • 8 hours ago, Rover said:
    Hi @cag014,
    Yes, it means no state defined, so AOQ waits for first changed value to display. It could be any available value. For example for wall plug it could be state, power or energy. Every changed on any parameter will be displayed.
    By the way in this case every changed parameter will trigger the line.
    Of course if this is a motion sensor then only one parameter available - motion.
    Let me know...
    OK, working fine now.
    Thanks your help!
    Thanks your help!
    Thanks, now I know how to fix it... will include that in next release...
    Thanks your help!
    Make I ask you what exactly you are changing and why? I want to add this to Tips and Tricks document for other user to explore this option.
    Tanks n advance
    The Wallis led ring color and status what I change. At xy time in the night the led ring is turning off, at xy time the led ring is turning on. And another option: if the door will be opening in the room, or the motion sensor will breach, the led ring will turn on state if I haven't automation for the actualy situation and I can see the switch in the dark. I have no problem if the led is on, but my children can't sleep sleep. :)
