Hi
QA works but suddenly stopped, now i get this error
Edited by marczu_83
    30 minutes ago, marczu_83 said:
    Hi
    Fix v0.45 - I hope... let me know.
    Looking good :)
    Hi @jgab
    For me the 0.45  seems to tease me a lot
    I got an error when initiliazing
    [14.07.2022] [08:44:04] [DEBUG] [QUICKAPP1670]: Matched device Dr. Søgaard(iPhone 13 Pro Max) for user Christian
    [14.07.2022] [08:44:04] [ERROR] [QUICKAPP1670]: in Event({"type":"checkPresence"}) => ..: /usr/share/lua/5.3/common/device.lua:49: attempt to index a nil value (field 'properties')
    Polling seems to run fine
    [14.07.2022] [08:47:03] [DEBUG] [QUICKAPP1670]: Matched device Dr. Søgaard(iPhone 13 Pro Max) for user Christian
    [14.07.2022] [08:47:33] [DEBUG] [QUICKAPP1670]: Next polling in 30s
    [14.07.2022] [08:47:33] [DEBUG] [QUICKAPP1670]: Matched device silje :)(iPhone X) for user Silje
    [14.07.2022] [08:48:03] [DEBUG] [QUICKAPP1670]: Next polling in 30s
    [14.07.2022] [08:48:03] [DEBUG] [QUICKAPP1670]: Matched device Ea iPhone 11(iPhone 11 Pro) for user Ea
    [14.07.2022] [08:48:33] [DEBUG] [QUICKAPP1670]: Next polling in 30s
    But the Children are not being updated.
    Eg when screenshot was taken 1675 was away for more that one hour. And testing running 0.44 is parallel shows difference
    /monthly_2022_07/2022-07-14_08-50-03.png.b4e2a6ad426994343e51e61b389a51ff.png" />
    6 minutes ago, ChristianSogaard said:
    Hi @jgab
    Very strange error that I can't find a reason for at the moment. Can you just delete the children and restart the QA so the children are created again and see if it helps?
    thank you. - that worked ?
    Hi @jgab
    Thank you for this IOSLocator - its really awsome
    Finally we are getting location feedback from our Android
    Android = User Marius
    Rest of the users is IOS
    Status in the QA is "Some at home", real status is All is Home
    Also the Children for Marius is not updated .but screenshot show he is home
    Any thoughts?
    Edited by ChristianSogaard
    P
    Hello Christian,
    I have the same issue Debug> some_home in real all_home.
    Perhaps an error in IOS Location???
    If I do it manual all are home
    Did you made your own $iOSHome?
    fa userA_home | userB_home => $iOS= 'some_home ???
    should be
    userA_home & userB_away => $iOS= 'some_home
    Edited by Sjakie
    add data
    20 hours ago, Sjakie said:
    Hello Christian,
    should be
    Hi Sjakie
    Im using the build in iOSHome or do I misunderstand what you ask?
    I looked for the "userA_home | userB_home => $iOS= 'some_home" in the code
    I only found
    could you elaborate ?
    I saw this error yesterday, but only once.
    OK it could be possible you created your own rule some_home.
    I have one phone with difficulties I saw yesterday location was resented to off.
    Redid the location and will see if we go away today what it will do.
    On two phones I also have error
    the error is much longer but I have no clue what info is embedded.
    Despite this error (a few times a day) location is working.
    • 1 month later...
    Hi Jan
    I have issues with my IOS locator - i tried reinstalling the QA - with same issue.
    I dont thing i had i working probably since version 033 - but it had focused on other things so i am not 100% sure,
    I have four IOS users, all are being authenticated at correct at iCloud.
    User Silje home=false, rest is true.
    [27.08.2022] [14:26:16] [DEBUG] [QUICKAPP1726]: iOSLocator deviceId:1726, v0.45
    [27.08.2022] [14:26:16] [TRACE] [QUICKAPP1726]: Home set to ‘HC3-xxxx'
    [27.08.2022] [14:26:16] [TRACE] [QUICKAPP1726]: Global variable for home status: iOSHome
    [27.08.2022] [14:26:16] [TRACE] [QUICKAPP1726]: Name of home place: 'Home'
    [27.08.2022] [14:26:16] [TRACE] [QUICKAPP1726]: Name of AWAY place: ‘Away'
    [27.08.2022] [14:26:18] [DEBUG] [QUICKAPP1726]: XXXXX, Device type:iPhone 13 Pro Max, battery:0.50%, Latitude:55.6775, Longitude:12.4073, Altitude:0.0000, Floor level:0
    [27.08.2022] [14:26:18] [DEBUG] [QUICKAPP1726]: ----------------------------------------------
    [27.08.2022] [14:26:18] [DEBUG] [QUICKAPP1726]: Matched device XXXXX(iPhone 13 Pro Max) for user Christian
    This is error is shown first time for this user only, every time QA restarts.
    [27.08.2022] [14:26:18] [ERROR] [QUICKAPP1726]: in Event({"type":"checkPresence"}) => ..: /usr/share/lua/5.3/common/device.lua:49: attempt to index a nil value (field 'properties’)
    [27.08.2022] [14:26:41] [DEBUG] [QUICKAPP1726]: Devices for [email protected]:
    [27.08.2022] [14:26:41] [DEBUG] [QUICKAPP1726]: Name:silje :), Device type:iPhone X, battery:0.43%, Latitude:55.0611, Longitude:10.6514, Altitude:0.0000, Floor level:0
    [27.08.2022] [14:26:41] [DEBUG] [QUICKAPP1726]: ----------------------------------------------
    [27.08.2022] [14:26:41] [DEBUG] [QUICKAPP1726]: Matched device silje :)(iPhone X) for user Silje
    [27.08.2022] [14:27:04] [DEBUG] [QUICKAPP1726]: Devices for [email protected]:
    [27.08.2022] [14:27:04] [DEBUG] [QUICKAPP1726]: Name:Marius Phone, Device type:iPhone 13 Pro Max, battery:0.88%, Latitude:55.6775, Longitude:12.4071, Altitude:0.0000, Floor level:0
    [27.08.2022] [14:27:04] [DEBUG] [QUICKAPP1726]: ----------------------------------------------
    [27.08.2022] [14:27:04] [DEBUG] [QUICKAPP1726]: Matched device Marius Phone(iPhone 13 Pro Max) for user Marius
    [27.08.2022] [14:27:27] [DEBUG] [QUICKAPP1726]: Devices for [email protected]:
    [27.08.2022] [14:27:27] [DEBUG] [QUICKAPP1726]: Name:Ea iPhone 12, Device type:iPhone 12, battery:0.75%, Latitude:55.6775, Longitude:12.4072, Altitude:0.0000, Floor level:0
    [27.08.2022] [14:27:27] [DEBUG] [QUICKAPP1726]: ----------------------------------------------
    [27.08.2022] [14:27:27] [DEBUG] [QUICKAPP1726]: Matched device Ea iPhone 12(iPhone 12) for user Ea
    [27.08.2022] [14:26:17] [TRACE] [QUICKAPP1726]: Global variable for user: 'Marius' is 'iOS_Marius'
    [27.08.2022] [14:26:17] [TRACE] [QUICKAPP1726]: Global variable for user: 'Christian' is 'iOS_Christian'
    [27.08.2022] [14:26:17] [TRACE] [QUICKAPP1726]: Global variable for user: 'Silje' is 'iOS_Silje'
    [27.08.2022] [14:26:17] [TRACE] [QUICKAPP1726]: Global variable for user: 'Ea' is ‘iOS_Ea'
    Then after this ... Polling is successful for all users
    Neither IOS variables or the QA Childs are being updated. I also tried let the QA recreate the QA. but noluck.
    Any ide what this could be?
    Christian,
    Reminder? If user is "home" he should physically leave home before status change in away.
    User need to open Yubii app to activate
    to force "home"
    I hope it will help you.
    On 8/10/2022 at 9:08 PM, jgab said:
    The integration with ER€ will come - just need ti make sure that the basics works first.
    1 hour ago, Sjakie said:
    Christian,
    to force "home"
    Thank you @Sjakie always helpful :-)
    - Unfortunate its not that. QA and Var simply dont update.
    I why should user open Yubii app ? - i think with IOS locator you dont need the Yubii app
    Now i tried 0.46 from Github but is getting
    [27.08.2022] [20:57:22] [ERROR] [QUICKAPP1726]: in Event({"type":"start"}) => ..: ./include/iOSLocator.lua:59: ./include/ ./include/ bad argument #6 to 'format' (no value)(debugf)(debugf)
    P
    Very strange - but really good.
    I deployed again, but this time from ZBS and version v.046 direct
    Now variables and QA updates right away. Finally.
    Sorry log in at HC3 or Yubii app to (re)activate user
    I am only getting one update per user, and then status is not updated.
    Polling for all users works
    [30.08.2022] [17:52:15] [DEBUG] [QUICKAPP1737]: ----------------------------------------------
    [30.08.2022] [17:52:15] [DEBUG] [QUICKAPP1737]: Matched device Seagaard(iPhone 13 Pro Max) for user Christian
    [30.08.2022] [17:52:16] [TRACE] [QUICKAPP1737]: User Christian at Home (0.02 km from home)
    This TRACE is only showed once per user in QA lifetime -
    Deleting all Childs, triggers the "User Christian at Home (0.02 km from home)" again and location is updated.
    Running 0.46
    Hi @jgab
    I could really use some assistance for the IOSLocator.
    I have reinstalled the QA multiple times, re-entered credentials, i tried multiple versions of the QA .
    Now is running 0.46, fibaro.FIBARO_EXTRA = "v0.950"
    No matter what i do, I only gets the GEO information for the user, when initializing the QA.
    Polling for all users works for each schedule
    This TRACE is only shown once per user, and only after the initializing of the QA.
    and for all for users the..."Matched device xxxxxx" is showed for every interval
    Deleting all Childs, triggers the Childs to be recreated and "User Christian at Home (0.02 km from home)" will show again and location is updated once.
    Looking at the variables - tonight they seems right.
    I understood that you don't need the Yubii app for this, and the communication is with icloud direct.
    And the corresponding Childs are not in Sync with the variables
    /monthly_2022_08/2022-08-30_21-37-39.jpg.dfd8e4278a8771e164d6596cae45c15b.jpg" />
    On 8/30/2022 at 9:45 PM, ChristianSogaard said:
    Hi @jgab
    I will try to have a look this weekend. It requires for me to setup something similar and requires a bit of work (I have prioritized answering easy questions this week ;-) )
    sounds to me a good thing to prioritize all easy stuff, then you get a lot more done ;-)
    I have IOSLocator running in both HC3 and ZBS TQAE, so let me know if there logs can can provide or test
