    20 hours ago, ChristianSogaard said:
    sounds to me a good thing to prioritize all easy stuff, then you get a lot more done ;-)
    I have IOSLocator running in both HC3 and ZBS TQAE, so let me know if there logs can can provide or test
    Ok, it turned out there were a lot of strangeness in v0.46.. (and maybe 0.45)
    I have pushed iOSLocator to QAUpdater (v0.47) with the bug fixes I could find. Try it out.
    Future updates will preserve iOSLocator.main for your settings, but you need to move them over from the old iOSLocator and it's format.
    Oh, a freshly installed iOSLocator will create Childs for Bob and Tim.... will remove it in next version (and no problem after you configure your own main)
    Jan, error
    After filling in my credentials
    iPhone Sjaak>> is listed in settings iPhone
    Edited by Sjakie
    41 minutes ago, Sjakie said:
    Jan, error
    Interesting that was a very old bug that showed up first now... that's the beauty of having testers for your QAs, thanks @Sjakie!
    Pushed v0.48 (QAUpdater)
    Thank you for providing this update. I have installed it and started testing, I have really looking for this. Thank you
    A observation - only cosmetically
    iOS_BOB, iOS_Tim is still in my variables after replacing those two with my own four users. Old Childs are removed and replaced with new my four own.
    The user shown here, seems a little random? - could it be possible to show status for all users here ?
    Besides that. Jan... I salute you, your work is remarkable
    /monthly_2022_09/image.png.6e08580e100b4a16f9615e6ace13cf37.png" />
    Edited by ChristianSogaard
    Typo
    Jan, proposal
    tree and red are difficult to reed >>> aqua and buttermilk?
    You mentioned to delete Bob etc?
    Yes, in next version I will remove the creation of Bob and Tim...
    I can't remove variables because maybe someone have a user named BOB...
    Yes, it's the last status update. I could probably set it to all users current locations.
    10 hours ago, Sjakie said:
    Jan, proposal
    You are running with dark mode on the HC3? I could probably make the colors a configurable option
    Jan, I am running light mode, dark mode show QA debug black and dark blue letters for me very bad readable
    Ok, pushed v0.49
    -user label in QA shows all known users locations (separated with newline)
    -colors can be configured with variables from 'main' (for enabled/disabled listing of devices)
    -Bob and Tim are not created anymore from a fresh iOSLocator
    -A separate 'doc' file in the QA with the documentation, so you can remove stuff from main.
    43 minutes ago, jgab said:
    Ok, pushed v0.49
    Thank you Jan.
    It seems that QAUpdater, says "Downgrade" for v0.49 ?
    1 hour ago, ChristianSogaard said:
    Thank you Jan.
    Ops, I had put the wrong serielnumber for iOSLocator so QAUpdater couldn't find the installed iOSLocator.
    I have updated the version file so if you do a Refresh in QAUpdater it will work again,
    Hi Jan - thank you for this update, things are getting better and better - i am so excited
    My primary issues are fixed - Users is being updated correct now, both var variable and childs.
    perhaps i missed it - main was overwritten ;-). i got a copy, no problem
    i assumed we where on Future updates now ?
    And one more thing ?
    I have four users in my system
    Silje is  home=false, rest is true
    3 users is shown in GUI, so Ea is missing or Should be replaced with Silje that is the only user with Home = False
    Typo
    Sorry, I missed an options in version file. QAUpdater Refresh will have a new file where main is preserved for iOSLocator.
    UI should show all users where a place has been determined (home or not). Are you sure EA has a place?
    Also, I'm a bit unsure how many lines it will fit.
    EDIT
    I was too eager..
    Ea was added - when she arrived home.
    I assumed you primed the users when init.
    /monthly_2022_09/image.png.54e70fe1ae8d0dd16cdee826f89f5c59.png" />
    Typo
    Jan,
    New version 0.49 nothing copied
    one user added
    It list for this user in green iPhone and in red iPad
    Update false because this location is't set in iOSLocation
    Strange no report of coming home
    Edited by Sjakie
    extra info
    11 hours ago, Sjakie said:
    Jan,
    one user added
    The error may have broken the status. Pushed v0.50 that should fix the sort bug once and for all...
    Jan no v0.50 inh QAUpdater
    Pressed "Refresh"?
    It says 0.5 and not 0.50, ...but it's the same.
    Jan my QAupdater is acting up>>> did a reinstall
    if clicked refresh it did't show new version
    Now I see v.05
    The UI in the HC3 interface is still a bit buggy when it comes to updating labels etc
    Jan,
    I changed green into blue
    My wife's devices are one in red (iPad) and one in blue(iPhone)
    I copied her "user data" with my credentials and I have two devices in blue
