    30 minutes ago, Sjakie said:
    Jan,
    I changed green into blue
    My wife's devices are one in red (iPad) and one in blue(iPhone)
    I copied her "user data" with my credentials and I have two devices in blue
    You use .deviceName and .deviceType to match the device that you want to track.
    Morning Jan.
    An observation for IOSLocator
    This morning I had user Silje (home=false) - both Var & Child is "home" but she left home yesterday at eg 15.00 .
    I rebooted IOSLocator QA, and now it looks right again.
    Edited by ChristianSogaard
    Typo
    11 minutes ago, ChristianSogaard said:
    Morning Jan.
    I rebooted IOSLocator QA, and not it looks right again.
    Is Silje an iPhone user? or just a HC3 user?
    Do you see if in the log if Silje is polled correctly?
    Still both MacBook and iPhone listed blue in debug
    Silje is an Iphone user - and is polled correctly
    Sorry, yes all devices that are locatable are green/blue. Your MacBook is locatable.
    It will log
    "Matched device X for user Y" for the device that it's using.
    Ok, but does it say something after that? Like
    It will log
    Hi Jan -
    I did a QA restart twice
    Logs for both times where like this.
    No "Matched device X for user Y" for user Silje
    43 minutes ago, ChristianSogaard said:
    Hi Jan -
    Ok, then it didn't got a match. What is the .deviceName and .deviceType configured to for Silje?
    Sorry, you got a match.
    Could you post here or PM me your configuration for Silje (without the credentials :-) )
    Done - used a old communication thread
    Typo
    Jan, we both left home and came back.
    Till now I used my own rules based on user enters and leaves weird is that it has worked good but last weeks it's not working for my wife.
    Before we left I added email notification to figure out what is going wrong.
    The email surprised me we both left my wife came back according the email.
    Observations:
    If I look into your iOSLocator debug it's more to the reality! She did't left
    So perhaps the difference is you are polling and HC3 act only if position changes?
    In the passed I added some positions in the HC3, I see them coming back in your iOSLocator.
    Now I must change my locations in ER.
    Will your iOSLocator ask much of the phone batteries?
    I will let you know where I am stuck
    Well done with this QA!!
    Jan See file for observation
    For me strange is that if we are away next second we are back home!
    The route we did is at crossroad point of marination and the route is only away from home. Perhaps thesis a normal practice but I see it for the first time.
    I never had a delay in arming my house but now I need to set minimum 2 minutes okay I know the change somebody will break in will be 0.0.....%
    Ok, I believe that you and @ChristianSogaard may suffer from the same bug. I think I have an idea what it can be....
    Jan I am. not suffering but seeing light at the end of the tunnel
    Ok, pushed v0.51.
    I think the problem was conflicting positioning between iPhone and HC3's own positioning.
    (I guess I thought they would complement each other... ;-) )
    1 hour ago, jgab said:
    Ok, pushed v0.51.
    Hi Jan
    The is still some stange things - look at user Ea in GUI - and compare with logs
    Ea is , away, home and unknown at the same time,
    Typo
    Well, I think Ea away but the first time there is nothing to be away from (no last place) - so nothing is updated for Ea...
    I think I fixed it now so she would be set to 'away' first time around.
    Pushed v0.52
    Jan, please
     Name of home place: 'Home' Name of AWAY place: 'away'
    'Home' and 'Away' or 'home' and 'away'
    47 minutes ago, Sjakie said:
    Jan, please
    I have the same OCD ;-)
    You can set you own names...
    i remember that from a former version - looking in my logs i also have - it used to be at the Variables site
    [06.09.2022] [11:12:39] [WARNING] [QUICKAPP1760]: Variable  HomeVar not found
    [06.09.2022] [11:12:39] [WARNING] [QUICKAPP1760]: Variable  HomeName not found
    [06.09.2022] [11:12:39] [WARNING] [QUICKAPP1760]: Variable  AwayName not found
    Typo
    They are quickAppVariables now.
    Hi Jan
    it looks great and it works great, and i has started creating Alarm rules.
    - i have two observations
    If you are using several locations like the screenshot below - the user will be mapped to the relevant location, this is cool.
    In this example - Ea is at ATO.
    But when Ea is leaving ATO as you see in the logs, her location is sticky to ATO - and don't change to away.
    I have only testet 600m away from ATO - where HC3 location radius is set for 150m.
    I will do some more testing, but if you already know, it by design, i will not test more on this.
    Also Marius left home
    the two GUI is showing different , and Child is not updated
    Correct is Ude/AWAY
    This is the same error as before with Ea
    /monthly_2022_09/2022-09-06_12-58-23.jpg.2cb5d96dfb5c8829f10807081d3296b2.jpg" />
    Typo
