Somewhere it's going wrong if I want to arm "all away" my system refuse.
I did fa iOS_Sjaak == 'a\East' | iOS_Sjaak == 'West' iOS_Sjaak == SouthNorth iOS_Sjaak == 'd' iOS_Sjaak == 'e | iOS_Sjaak == ' away' => Location_Sjaak ='Left_Building'
Location_Sjaak ='Left_Building' is used in arming scene
Need to investigate!
Arming 'some_home' works like a charm
    2 hours ago, ChristianSogaard said:
    Hi Jan
    it looks great and it works great, and i has started creating Alarm rules.
    - i have two observations
    If you are using several locations like the screenshot below - the user will be mapped to the relevant location, this is cool.
    In this example - Ea is at ATO.
    But when Ea is leaving ATO as you see in the logs, her location is sticky to ATO - and don't change to away.
    I have only testet 600m away from ATO - where HC3 location radius is set for 150m.
    I will do some more testing, but if you already know, it by design, i will not test more on this.
    Also Marius left home
    the two GUI is showing different , and Child is not updated
    Correct is Ude/AWAY
    This is the same error as before with Ea
    I'm wondering if the GUI is not updating. If you switch GUI tab between 'Variables' and 'Edit & Preview" it usually updates.
    The code that sets the child status and the one making the list should not be able get out of sync on this matter.
    In the log for Ea there are many updates to "ato" - is Ee moving away between the log messages? Otherwise it shouldn't update the GVs etc but just say "User Ea in same place 'ato'"
    In the Marius example - the QA GUI is the only one right - its was showing away.
    Both the child and var is showing home (and still is) - so they are not updated.
    I know the  switch GUI tab between 'Variables' and 'Edit & Preview trick - and its not that. I have done this every time i checked the var and gui
    Ea - was at a restaurant with her work, so i'm pretty sure they were fixed there for some hours.
    and looking at the logs now - she is heading home - but still sticky to ATO
    Rebooting the QA makes everything look right, also in variables and Childs
    /monthly_2022_09/2022-09-06_16-25-12.jpg.923420207e3ff038c99659c9404debd8.jpg" />
    Edited by ChristianSogaard
    Typo
    Jan
    After updating we left the building>>>arming scene "all_away" worked well.
    I recieved around 400 Telegrams My wife is away >>Notification in ER only her not me we have the same rule for notification. This I can change no problem but why now every 45 sec and not for me?
    What I see in your iOSLocator the position is like a pinball machine it go's back and forward between positions.
    Can you adapt more precise. I will send debug in pm. Practically
    Home>>>Ter_Reede_HHSchool
    and vice versa if we come back
    Today back to basic all other locations removed from HC3
    Edited by Sjakie
    back to basic
     Good morning Jan
    Just providing some more logs for above issues
    please notice Marius in this Log (full log in Spoiler).
    And the status for Marius Child and Variable is not updated again. Both is showing Home/Hjemme
    Correct is the Log belog and QA GUI shows Away/UDE
    [07.09.2022] [09:12:20] [DEBUG] [QUICKAPP1760]: Matched device Marius Phone(iPhone 13 Pro Max) for user Marius
    [07.09.2022] [09:12:20] [DEBUG] [QUICKAPP1760]: User Marius in same place 'Hjemme'
    [07.09.2022] [09:13:52] [DEBUG] [QUICKAPP1760]: Matched device Marius Phone(iPhone 13 Pro Max) for user Marius
    [07.09.2022] [09:14:14] [DEBUG] [QUICKAPP1760]: Next polling in 23s
    [07.09.2022] [09:15:24] [DEBUG] [QUICKAPP1760]: Matched device Marius Phone(iPhone 13 Pro Max) for user Marius
    [07.09.2022] [09:15:24] [DEBUG] [QUICKAPP1760]: User Marius in same place 'Ude'
    Typo
    Jan, before I left I removed all other locations in HC3
    In the log from iOSLocation I see still that we are in those "deleted" area's??  How to solve?
    Restart iOSLocator, it will read in the defined locations at startup.
    10 hours ago, ChristianSogaard said:
     Good morning Jan
    Hi Jan
    Any thoughts for these issues ?
    Do you want me to provide additional logs or set it up again in ZBS ?
    On 9/7/2022 at 7:38 PM, ChristianSogaard said:
    Hi @jgab
    Sorry for asking for this again
    Any thoughts for these issues ? Do you want me to provide additional logs or set it up again in ZBS or should we put it on hold ?
    • 3 weeks later...
    Very interesting QA, but unfortunately only for iPhone users... here in this topic, I read that somehow this QA can be used for Android devices as well, using a separate application on the phone itself... but unfortunately there is no description of this procedure and does it even work now?
    • 3 weeks later...
    Guest fstae
    Hello, is it possible that with iOS16 and iPhone 14 iOSLocator (0.52) no longer works? I always get the error message "Access denied". With an iPhone12 and iOS15 it worked perfectly.
    Edited by fstae
    Hello, I have done a fresh install of iOSLocator (0.52). My iPhone 12 has IOS 16.0.3 installed and after setting up iOS Locator I always get an "Access Denied" error message. HC3 has 5.130.45 installed. It is possible that this problem does the new IOS 16?.
    Oh I thought I was alone!
    I created an alternative in scenes. I create for user/participants home and away
    A separate QA for all geofence related triggers and execution
    Guest fstae
    Hi Jan, do you have any idea what the problem could be?
    Yes, I can confirm that it doesn't work any more.
    It's not iOS16 itself as the service use a cloud service from apple that all apple devices update for their location.
    Something changed in the API for this service, and it's difficult to understand where and what at the moment.
    I noticed that after the last SW HC3 update, in the mobile phone settings for any user, the phone name is now always "iPhone". Similarly, for the tablet it is always "iPad".
    Before the update, the phone name was taken directly from the phone.
    EX. before the update the name was:
    "My iPhone12"
    after update the name is just:
    "iPhone"
      This is all ios phones with the same name "iPhone" but with a different id.
    I'm letting you know, but it's also possible that it's just my two HC3s.
    it's a pity, I hope it will work again someday
    Still working on IOS 15.6.1 glad i haven't got auto updates turned on
    • 3 weeks later...
    Is it possible that this issue is related to the "Two-way authentication" ?
    (If you're already using two-factor authentication with your Apple ID, you can't turn it off.)
    With two-factor authentication, you’ll need a verification code to sign in with your Apple ID on a new device or browser.
