  2. @m.roszak, Because there is no z-wave device with those options. Can you add this device FP300 Zigbee. It's a real game changer it has pir and mmWave. Tip if possible also the enter and leave option, what is missing in the FP1 Thanks in advance
  3. Today
  4. Yesterday
  5. That is going to be due to Fibaro's implementation of the Zigbee protocol. Not much you can do natively in HC3 - Zigbee devices either work or they don't. There are no editable parameters etc
  6. I‘ve included the Aquara FP300 zigbee occupancy sensor, but it only shows temperature, illuminance, but no occupancy - any ideas? Thanks!
  7. I‘ve been a bit too hasty with my previous comment - the plugin is still not working 😟
  8. Hello everyone, Yesterday and today i started seeing all my customer's and my own Fibaro Home Centers unavailable and in an inconsistent state. On my own i had to reverse to a previous backup and reverse version to 5.200. All my cstomer's Fibaro Home Centers are unavaible and would like to know if this an isolated case or not. Thank you.
  9. Hi @GasDeKu, Geofencing on HC3 with Apple iPhones working flawlessly for me for two months now. I have made Quick app which listen to events received from iPhones and acts accordingly:
  10. Last week
  11. Hi everyone, I'm reviving the discussion because I thought hc3 was finally able to handle this damned geofencing, but at least for me, I just can't seem to figure it out. Since I'm completely new to LUA, I created a Presence_Home variable set to 0, followed by a phone tracking scene (two iPhone 16-inch models), and then two more block scenes to deactivate and reactivate the alarm. For the phone tracing scene, I relied on AI help because I don't have your expertise. The device ID numbers are those obtained from the yhubii user modification app. Until now, I've been using Google Home (with the Fibaro plugin) with a simple scene created in the app. Do you have any suggestions?
  12. Please download and run to identify LQV and LQI. Will be helpful if you can post your table later.
  13. Thanks. I think I followed the VSCode setup from github but tbh, was jumping around between this topic and github alot!
  14. Jeg har en eldre homecenter 2, har nå kjøpt en home fenter 3 lite, og ønsker å få overført mest mulig fra 2 til 3, hvordan gjør jeg det?
  15. But isn't stepValue the same as fibaro.call(id, "setValue", fibaro.getValue(id, "value")+5) ?
  16. Is there an issue with remote access at the moment? My HCL keeps cycling online and offline, and it hasn't stabilized yet. The same thing is happening with my Yubii. Sometimes, when the 'Open' button appears in remote access, it goes offline again as soon as I click it while loading
  17. **ZigBee devices completely unresponsive for 8+ hours — root cause confirmed: Lua scene sending hub.call() to ZigBee devices every 5 minutes via matchInterval** Firmware: 5.210.12 | Yubii Home Pro Posting this in case others are experiencing similar ZigBee instability — I've spent several days tracking this down and can confirm the root cause with reproducible evidence. --- **Symptoms** - 10 ZigBee dimmers (Simpex SC-9101, ZigBee 3.0) randomly unresponsive to app commands - turnOn / turnOff commands reach the hub immediately (confirmed via DeviceActionRanEvent in CSV export) but the physical device does not respond — no DevicePropertyUpdatedEvent follows - Workaround: moving the brightness slider (setValue) wakes the device up, after which on/off works again - Progressive degradation over several evenings: first delays of seconds to ~3 minutes, then complete loss of ZigBee communication for 8+ hours - Only a full hub reboot restored ZigBee communication - Physical device operation (rotary knob) worked perfectly throughout — devices themselves were fine --- **Root cause (confirmed by direct testing)** A Lua scene (matchInterval trigger, every 5 minutes, 24/7) was sending hub.call() commands to two SONOFF SWV irrigation valves — which are also ZigBee devices. This continuous ZigBee traffic progressively degraded the ZigBee stack on the hub until all other ZigBee devices became unreachable. Proof: deactivating that scene immediately resolved all ZigBee issues. All 10 dimmers have responded instantly and reliably ever since — no delays, no dropouts, tested including rapid successive commands. --- **Workaround implemented** Replaced the matchInterval trigger (288 calls/day) with a daily Cron trigger (1 call/day at 03:30). ZigBee traffic reduced to two brief pulses per day. Problem completely gone. --- **Open questions for Fibaro / community** 1. Is there a known minimum interval for hub.call() to ZigBee devices in Lua scenes? What polling frequency is safe? 2. Is this a regression in 5.210? The scene ran on an earlier firmware without causing ZigBee instability. 3. The "Reconfigure devices" button on Settings → ZigBee (Settings → 14. ZigBee) was greyed out / inactive throughout. What is the prerequisite to activate it? 4. Is there any ZigBee diagnostic view available (LQI, signal strength, routing/mesh map) in Yubii 5.210.12? I could not find one. --- Hope this helps others. Happy to share CSV event exports or Lua code if useful. Andrea
  18. **ZigBee devices completely unresponsive for 8+ hours — root cause confirmed: Lua scene sending hub.call() to ZigBee devices every 5 minutes via matchInterval** Firmware: 5.210.12 | Yubii Home Pro Posting this in case others are experiencing similar ZigBee instability — I've spent several days tracking this down and can confirm the root cause with reproducible evidence. --- **Symptoms** - 10 ZigBee dimmers (Simpex SC-9101, ZigBee 3.0) randomly unresponsive to app commands - turnOn / turnOff commands reach the hub immediately (confirmed via DeviceActionRanEvent in CSV export) but the physical device does not respond — no DevicePropertyUpdatedEvent follows - Workaround: moving the brightness slider (setValue) wakes the device up, after which on/off works again - Progressive degradation over several evenings: first delays of seconds to ~3 minutes, then complete loss of ZigBee communication for 8+ hours - Only a full hub reboot restored ZigBee communication - Physical device operation (rotary knob) worked perfectly throughout — devices themselves were fine --- **Root cause (confirmed by direct testing)** A Lua scene (matchInterval trigger, every 5 minutes, 24/7) was sending hub.call() commands to two SONOFF SWV irrigation valves — which are also ZigBee devices. This continuous ZigBee traffic progressively degraded the ZigBee stack on the hub until all other ZigBee devices became unreachable. Proof: deactivating that scene immediately resolved all ZigBee issues. All 10 dimmers have responded instantly and reliably ever since — no delays, no dropouts, tested including rapid successive commands. --- **Workaround implemented** Replaced the matchInterval trigger (288 calls/day) with a daily Cron trigger (1 call/day at 03:30). ZigBee traffic reduced to two brief pulses per day. Problem completely gone. --- **Open questions for Fibaro / community** 1. Is there a known minimum interval for hub.call() to ZigBee devices in Lua scenes? What polling frequency is safe? 2. Is this a regression in 5.210? The scene ran on an earlier firmware without causing ZigBee instability. 3. The "Reconfigure devices" button on Settings → ZigBee (Settings → 14. ZigBee) was greyed out / inactive throughout. What is the prerequisite to activate it? 4. Is there any ZigBee diagnostic view available (LQI, signal strength, routing/mesh map) in Yubii 5.210.12? I could not find one. --- Hope this helps others.
  19. The cmd line flag for plua to run a tool is -t (or --tool) { "label": "Plua, Download and unpack from HC3", "type": "shell", "command": "plua", "args": [ "--tool", "downloadQA", "${input:QA_id}", "${input:path_id}", ], "group": "build" } ], "inputs": [ { "type": "promptString", "id": "QA_id", "description": "deviceId of QA from HC3 you want to download?", "default": "-" }, { "type": "promptString", "id": "path_id", "description": "path where to store the QA", "default": "dev" } ]
  20. It's a pip error that the pip install cache was somehow corrupt However, it successfully installed plua-1.2.13 at the end so it should work. scoop installation of python keeps the cache under scopes somewhere... You can try >pip cache purge
  21. Now is 2026 and still Beta Would be very helpful to have full zigbee capability. Thank you
  22. I'm not able to import an existing QA, command line of via VSCode Task.
  23. Installed successfuly but I have at start this WARNING: PS C:\Users\bruvi> pip install plua -U Requirement already satisfied: plua in .\scoop\apps\python\current\Lib\site-packages (1.3.11) WARNING: Cache entry deserialization failed, entry ignored Collecting plua ---/--- Installing collected packages: plua Attempting uninstall: plua Found existing installation: plua 1.3.11 Uninstalling plua-1.3.11: Successfully uninstalled plua-1.3.11 Successfully installed plua-1.3.13 Any idea why or where is the issue?
  24. I‘ve deleted and re-installed the plugin - now it‘s working again! Don‘t know what failed in the first place …
  25. Indeed, some issue with the onClock=true. Meanwhile remove onClock=true. Should work while fixing the bug
  26. Hi Jan, Thank you for the detailed update. For the step-dimming API, I would prefer the Fibaro-style approach: `fibaro.call(id, "stepValue", 5)` `fibaro.call(id, "stepValue", -5)` The keypad/controller should handle hold-repeat timing, so I do not think Yahue needs an internal `diminterval` repeat function. Regarding stopLevelChange, I have not identified a specific failure pattern. My main focus is ensuring reliable interoperability between EV7 and Yahue, so EV7’s level-change and stop behaviour maps cleanly to Hue’s native dimming_delta commands. The capabilities variable and the scene-stepping additions also look good. My immediate focus has unfortunately shifted. My HC3 entered recovery mode twice, and I spent nearly two weeks with Fibaro Support trying to identify the cause and prevent it from happening again. I have now given up on that support process and decided to start over instead. Fortunately, I had saved a substantial part of my rules on my Mac, so migrating the logic to EV7 should be much easier. Best regards, Christian
  27. Hi @cag014, Using v22.0: {5,"943",{state="value=false", onClock=true, initOnStartup=false, timeLoopAct={{"945","turnOn"}, {"945","turnOff",30}}}}, produces a timeloop while state="false": It does not matter if state = "false"or "true", the looping is going on. This should be different according to the Advanced User Manual.
  28. Working, thanks!!
  29. Are you sure that battery level is not jumping above and below the threshold? Once a week will work if its stays below the threshold.
