- 136 replies
- quickapp
- development
(and 1 more)
Vidar S joined the community
Unilove joined the community
**ZigBee devices completely unresponsive for 8+ hours — root cause confirmed: Lua scene sending hub.call() to ZigBee devices every 5 minutes via matchInterval** Firmware: 5.210.12 | Yubii Home Pro Posting this in case others are experiencing similar ZigBee instability — I've spent several days tracking this down and can confirm the root cause with reproducible evidence. --- **Symptoms** - 10 ZigBee dimmers (Simpex SC-9101, ZigBee 3.0) randomly unresponsive to app commands - turnOn / turnOff commands reach the hub immediately (confirmed via DeviceActionRanEvent in CSV export) but the physical device does not respond — no DevicePropertyUpdatedEvent follows - Workaround: moving the brightness slider (setValue) wakes the device up, after which on/off works again - Progressive degradation over several evenings: first delays of seconds to ~3 minutes, then complete loss of ZigBee communication for 8+ hours - Only a full hub reboot restored ZigBee communication - Physical device operation (rotary knob) worked perfectly throughout — devices themselves were fine --- **Root cause (confirmed by direct testing)** A Lua scene (matchInterval trigger, every 5 minutes, 24/7) was sending hub.call() commands to two SONOFF SWV irrigation valves — which are also ZigBee devices. This continuous ZigBee traffic progressively degraded the ZigBee stack on the hub until all other ZigBee devices became unreachable. Proof: deactivating that scene immediately resolved all ZigBee issues. All 10 dimmers have responded instantly and reliably ever since — no delays, no dropouts, tested including rapid successive commands. --- **Workaround implemented** Replaced the matchInterval trigger (288 calls/day) with a daily Cron trigger (1 call/day at 03:30). ZigBee traffic reduced to two brief pulses per day. Problem completely gone. --- **Open questions for Fibaro / community** 1. Is there a known minimum interval for hub.call() to ZigBee devices in Lua scenes? What polling frequency is safe? 2. Is this a regression in 5.210? The scene ran on an earlier firmware without causing ZigBee instability. 3. The "Reconfigure devices" button on Settings → ZigBee (Settings → 14. ZigBee) was greyed out / inactive throughout. What is the prerequisite to activate it? 4. Is there any ZigBee diagnostic view available (LQI, signal strength, routing/mesh map) in Yubii 5.210.12? I could not find one. --- Hope this helps others. Happy to share CSV event exports or Lua code if useful. Andrea
- 136 replies
- quickapp
- development
(and 1 more)
- 136 replies
- quickapp
- development
(and 1 more)
- 136 replies
- quickapp
- development
(and 1 more)
- 136 replies
- quickapp
- development
(and 1 more)
Tedee Plugin stopped working
Working, thanks!!
- 390 replies
DardK joined the community
tomad joined the community
- 390 replies
- 390 replies
- 390 replies
rr1960 joined the community
- 390 replies
HCHviper joined the community
Tom4711 joined the community
- 136 replies
- quickapp
- development
(and 1 more)
- 136 replies
- quickapp
- development
(and 1 more)
