Netatmo Weather Station suite standalone v3.5.2
INTRODUCTION
Netatmo Weather station suite brings complete integration of Netatmo weather station to HC2 users including rain and wind gauges and support for more than one station.
PREREQUISITES
  • Fibaro Home Center 2 with firmware 4.160 or greater
  • Sankotronic Lab. Emoji VD standalone (not required since v3.4)
  • Netatmo Weather station
FEATURES
  • Complete integration of Netatmo weather station with HC2 including rain gauge and anemometer
  • Support for multiple Netatmo weather stations
  • Support for maximum 3 additional indoor modules
  • Since version 3.5 support for Indoor main module that is missing outdoor module
  • Smart update system that follows Netatmo weather station cloud updates
  • Completely independent installation does not require any more Weather State VD or Main scene FTBE
  • Netatmo weather station measurements can be shown on Weather State VD and HC2 web GUI and mobile applications by means of Weather State VD and Weather
    provider plugin
  • VD has built in multi-language support with 27 languages included (see APPENDIX 1 for the list). VD can use HC selected language or user can select any other available
    language.
  • Easy setup for VD icons (on UHASTM compatible version is this even easier)
  • Global variables are automatically added, monitored and repaired and does not require user intervention
INSTALLATION
Please check provided User Manual and video from @MarcoTorino71:
PACKAGE CONTENT
  • Netatmo Main module VD
  • Netatmo Outdoor module VD
  • Netatmo Additional indoor module VD
  • Netatmo Wind sensor VD
  • Netatmo Rain sensor VD
  • Netatmo Weather station scene
  • Set of icons for all VD's and scene
UPRADE PACKAGE CONTENT v3.5.2
  • Updated user manual
TERMS AND CONDITIONS
DISCLAIMER
VERSION HISTORY
  • 3.5.2 - Scene code changed to support Netatmo servers domain api.netatmo.com, since the other one will be removed
  • 3.5 - Suite now support Netatmo weather station indoor main module that is missing outside module
  • 3.4 - Scene code changed to use new Netatmo API grant access by replacing username and password with tokens. All VD's since v3.4 do not need Emoji VD to be installed to work properly.
  • 3.3.1 - Scene code changed to get rain amount for past 3 adn 6 hours to better support Irrigation Control VD. All VD's corrected some translations. Rain gauge VD changed labels content to display last 3 hours rain amount
  • 3.3 - Check below version description or consult User manual for more details
  • 3.2 - Corrected rain sensor code and cleaned some bugs in scene. Indoor modules corrected handling of CO2 measurement, improved updating code.
  • 3.0 – This new version is completely redesigned and made independent. Does not require Main scene FTBE and Weather State VD anymore. Updating is now synced with Netatmo cloud so readings are always up to date.
  • 2.0.2 – Code optimized and resolved some bugs
Here is look of the Netatmo Weather set:
Enjoy coding and your new Netatmo weather station suite! :-)
Sankotronic
Edited by Sankotronic
Uploaded new version 3.4
What's New in Version 3.5.2   See changelog
Changes in version 3.5.2
  • Scene changed to use Netatmo server domain api.netatmo.com since domain api.netatmo.net is depreciated.
Upgrade instructions from any previous version to v3.5.2
  • Download upgrade package and copy/paste scene new code over the old one. Remember to move settings to new scene code.
  • Like 21
  • Thanks 11
timppa
Hi @Sankotronic
I just updated my Netatmo scene to 2.0.2 and started experiencing error;
[DEBUG] 13:30:52: FALSE START - Netatmo Weather station Integration scene version 2.0.2
[DEBUG] 13:30:52: Start type: 'autostart', selfRun set to: 'false'
[DEBUG] 13:31:00: MANUAL START - Netatmo Weather station Integration scene version 2.0.2
[DEBUG] 13:31:00: ERROR - Global Variable JSON decode failed with error: /usr/share/lua/5.2/json/decode/util.lua:35: unexpected character @ character: 1 0:1 [T] line:
[DEBUG] 13:31:00: T.
[DEBUG] 13:31:00: Scene will abort
[DEBUG] 13:31:00: ERROR - Check contents of Global Variable. wT is not a table.
[DEBUG] 13:31:00: ERROR - wT table is missing a 'netatmo' field.
Guest Sankotronic
Hi @timppa,
Have you installed Weather State VD first? According to debug lines you are missing global variable WeatherState. If you have installed Weather State VD then Save it to recreate this global variable or if there is that global variable in variable panel then delete it so that can be properly recreated. BTW DO NOT use Save button in variable panel since it destroys global variables that contain table values!
FK1968
Hi @Sankotronic
I am new to Fibaro and my HC2 is now running for llittle less than 2 weeks.
I have implemented WeatherState 2.0 and just downloaded "Netatmo Weather Station 2.0.2" ! Thanks for coding everything - really great stuff.
Actually I couldn´t get it to run, but then I changed line 66 from
local jT                = json.decode(hc:getGlobalValue("HomeTable"));
to
local jT                = json.decode(fibaro:getGlobalValue("HomeTable"));
and that did the magic.
I just thought I drop it here.
Cheers
Frank
Guest Sankotronic
Hi Frank,
thank you for letting me know about that bug. I'm busy with new Main scene FTBE and I also have plan to update weather stuff including Weather State VD, Forecast VD and Netatmo weather scene so stay tuned!
I want to bring only the best of the best code and it is time to improve it before Christmas and New year! :-)
XYZ
I'm new to this forum.
I just tested the 2.02 version of netatmo scene with the new plugins under 4.520. Getting the messages:
WeatherState is there and contains the value 0 (zero). After deleting WeatherState and starting the scene without the global variable present, the message doesn't change, the variable is not re-created automatically.
The netatmo setup is 4 mains, 4 outdoor, 7 indoor, 2 rain, 2 wind. For testing I installed only 1 module for main, outdoor, rain and wind and 2 indoor.
Old HC2 fibaro netatmo plugin is happy with the account data supplied.
Any suggestions?
Edited by XYZ
Guest Sankotronic
Hi @XYZ ,
This version of Netatmo scene will not work without Weather State VD installed and running since VD is taking care of adding and repairing of global variables that Netatmo scene needs to work properly.
BTW Weather State global variable should hold table of values and not just number as you mentioned.
Karol
Hi all!
It looks like it can be nice VD but doesn´t work. Same problems like the others...
Scene should FIRST get data from Netatmo and then save into variable... WeatherState (global variable)
setGlobal(WeatherStateName,json.encode(dataFromNetatmoJson))
Need to try that :)
Guest Sankotronic
2 hours ago, Karol said:
Hi all!
Need to try that :)
New major version is on the way. I just have to write User Manual. New version has mentioned problem solved, does not need Weather State & Forecast VD and it's completely independent. So stay tuned! :-)
Karol
That's fine! When will be released then? :)
VD Looks fine :)
danaeal2002
Hi, I just imported Weather State WD and installed Netatmo WS 2.0.2 plus associated WD. After small adjustment - correction mentioned by FK1968 - and update with my HC and Netatmo parameters, it works fine. I get full data from Netatmo station. Thanks guys
MartinRone
Can someone put here working scene script?
I have tried everything you mentioned here but nothing works.
I have also tried create global properties via panel properties but that also didn't work.
Guest Sankotronic
Hi @MartinRone ,
Can you provide some details on problem you encountered, maybe a screenshot of the error so I can help you? Comments like "nothing works" and "didn't work" does not tell much and definitely can't help anyone.
to
Hi @FK1968 Frank and thank you for pointing this one out.
Any suggestions?
Hi @XYZ , current version of Netatmo Weather Station scene depends on Weather State VD which adds necessary global variables. If you have deleted Weather State VD and global variables then Netatmo scene will stop working.
I do have finished new version that has many improvements. Will publish it as soon as I finish writing user manual. Just to mention that new version of Netatmo Weather Station scene does not require Weather State VD to be installed and also does not require any other scene or VD to be updated. It is completely independent and it updates only when Netatno cloud is updated so readings on Hc2 are always up to date same as on Netatmo original app.
MartinRone
I will wait for a new version, when do you think it will be published?
Guest Sankotronic
I hope to publish it until end of this week. At the moment I'm moving all my work from Fibaro marketplace back to Fibaro forum download section. Market place has too many problems and I like more forum's download section because it has built in versioning and much better counters for viewing and downloads.
Stay tuned!
Meinewenigkeit
8-)  I replaced the old versions with your new ones.  Excellent work...as always.
One Question. I did something wrong. For outdoor module the icons change. Indor i get only main icon, no green, yellow etc.
Any ideas?
 image.png.f842b6b1edbc619434739c2a72169985.pngimage.png.143e433f94ca755d1cf7508e04e83f0e.pngimage.png.9d74ba9547e65750f31a8db017cba04f.png
Edited by Meinewenigkeit
ales13
Sanko congrats!!! I updated to v3 and everthing 100% working!! Excellent work!
Karol
Netatmo Weather station scene ID is missing. Please install scene
Even look like evrything is ok and Main Scene is runnig and geting a right data :)
For me Scene shall create the global variables if doesn't exist and scene shall write to global variables... VD shall only read from variables... This is just mine sugestion... :)
How to solve it? Any ideas
Edited by Karol
Guest Sankotronic
Hi @Karol ,
Just run Netatmo scene manually and it will store it's ID to global variable added by Netatmo indoor base station VD which BTW should be installed first as it is explained in user manual.
danaeal2002
I installed 3.0 without any pb. It works since two weeks and I managed to recover CO2 data and drive house VMC
accordingly. Thank you sankotronik and team
christos
hello
i just installed base module VD
what does this error mean ?
[DEBUG] 11:29:46: ERROR - Indoor base module not updated recently
Christos
Sorry RTFM
everything is working AFTER setting up the scene ...... Dohhh
Thank you very much for this wonderful VD :)
Edited by christos
Stiven
This is an awesome vd-scene. Good job! Is there any way to change the individual icons that appear on each station with words such as seen, temp, or other things? Thanks!
Andrei Marin
Hi @Sankotronic
I have a problem, after putting the VD for indoor base module and outdoor module I've inserted the code for netatmo scene, run it manualy , but the VD don't update and give the error "Netatmo Weather station scene ID is missing. Please install scene" but the scene already exist. Please find attached some printscreens.  Please give me a solution for make it work.Thank you!
middelweerd
Thank you @Sankotronicfor this! You are AWESOME!
I am new to this and have no experience in coding but you made it so crystal clear with your manual!
Thanks!
dirtyfish
hello,
the values of rainhour and rainday are ident....can anybody help me?
thanks forward
Guest Sankotronic
Hi @dirtyfish ,
Netatmo changed time format for fetching rain data. To make it work again open Netatmo Weather station scene and change code line 451:
local request_body_rain='access_token='..token..'&device_id='..int_id..'&module_id='..rain_id..'&scale=1hour&type=sum_rain&real_time=true&date_begin='..os.date('!%c',(now-duration))
to look like this:
  local request_body_rain='access_token='..token..'&device_id='..int_id..'&module_id='..rain_id..'&scale=1hour&type=sum_rain&real_time=true&date_begin='..now-duration
NOTE that os.date() formatting is removed form request_body_rain
Kind regards
Zoran
