Yes, when saved it is again correct now.... But it happens randomly after few days... Would be good to handle it somehow :)
    I'm away at the moment but will take a look when I get back and see if I can make a few recommendations...
    Glad it fixed it for now
    @Bezan
    • 4 weeks later...
    Hello everybody,
    it is possible to play an MP3 file from a NAS (Synology). There is indeed the clip command, but this refers only to the folder
    Thanks for your help Beijonig
    @Beijonig
    Unfortunately not, for now the mp3 needs to be in the clips folder
    I added to the previous VD code code to track more states of the Sonos including if the player is offline / online
    The code below is for one player - repeater as many times as you have zones
    It uses a statetable global to track changing states and smart message hub to send messages (one message when it goes offline an done message when it comes back online) - adjust as you need
    and the result is
    /monthly_2017_09/Capture.PNG.5c3010424fb966a2798283cd0e6590ef.PNG" />
    The previous code didn't handle if a player went offline
    This one should work better with messages at appropriate times
    Edited by AutoFrank
    • 1 month later...
    In case of installing on PI3 with other Linux platform (OSMC, Raspbian etc.), please following:
    1) update Node.js to the last version (if you have below 4.0 - you can check it by command: node -v)
    2) install git repo
    3) clone the git from
    4) go to repo catalogue
    5) install npm
    6) run npn
    That's all. Now you will be able to use node-sonos-http-api
    • 1 month later...
    Is it possible to send "Night audio" On/Off command from Fibaro?
    I would like to set Night audio after 20:00 and turn it Off 8:00.
    Anyone tried this?
    • 3 weeks later...
    Anyone tried this?
    @BezanI created a toggle button for my VD to switch Night Mode. Here is my code:
    To switch on or off at certain times, you can either create separate VD buttons for ON and OFF and call these from a scene, or you could call the HTTP command directly from a scene.
    Edited by Barlow
    • 10 months later...
    Hi @AutoFrank, is this tutorial still up2date, because I'm going to implement it?
    Cheers.
    @Sjekke, I installed this a long time ago and still up and running.
    Jim
    Hi @jimicr I pressume the files are automatically updated to the new version of the api?
    Edited by Sjekke
    This doesn't happen for me
    Hi @sjekke, You'll have to manually update.
    Just check the github once in a while ;)
    Jim
    ok guys ... i’ll go for it!
    Jim
    In github you can put a “watch” on a repository. You will then get update notifications should anything change.
    • 2 months later...
    On the Raspberry it works wonderfully. Now I want to install it on the Synology. Does anyone have a guide?
