Hi im pretty new to this. Im using HC2 and have sonos play1 and play5. I want to get started implementing sonos in my system. First i tried the plugin from fibaro but didnt work. Then i tried to download Sonos Remote 1.0.0.1 from krikoff
but had to wait to get autorized by that forum to download. So while waiting i keept reading and now im here. What do you guys say is this the best way of doing it (Buy Rpi, download this VD in the start of the thread and start struggeling)
or just try to add the command fibaro:sleep(for ever) in my head.
/Daniel
    /Daniel
    hi @yabadaniel
    Hi, welcome to this topic :-)
    I'm biased but I'd say get the PI and follow this part of post 1
    Added Feb 5th
    The fastest way I found to get up and running on a PI if you're unsure and just want to try it (takes about 15 minutes)
    Use the sonos-api precompiled rpi image at
     (apply to blank sd card)
    when you login over SSH (with something like putty) the password is root
    Map a network drive or Start Run to \\<IP of Pi>\flash
    click apps folder and you'll see the sonos-http-api folder
    Get an API from VoiceRSS and create a settings.json file (details in the post) and drop it into the sonos-http-api folder
    reboot and that's it - test through browser with something like http://<ip-of-Pi:5005/<playername>/Say/Hello
    If you want to upgrade to the latest api release
    Download the latest zip from
     (green button on right)
    In the flash folder rename the sonos-http-api to -old
    Rename what you downloaded to to sonos-http-api
    Drop in your settings.json file
    SSH into the Pi - login = root
    cd /flash/apps
    cd sonos-http-api
    npm install --production
    when finished reboot
    ...after that download one of the many vd's shared and you should be up and running pretty fast
    if you get into trouble.. just yell and somebody will help
    -f
    Thx Frank ill go bye a Rpi and try it out
    Out of all the different ways to control Sonos...this is hands down the best I've come across. It's extremely versatile, has many features available and controllable and once you get your head around the commands, is actually very easy to set up and use.
    I got it working yeahaaaaaaaa. Took me from morning to evening (not 15 min ha ha) but i have never done coding noor linux. This proof the guide works fine thx alot
    Frank and everybode else on this topic for the help. When i got it working it fellt better then when my first Kid was born has this gone to far ? ha ha
    Best regards Daniel
    Best regards Daniel
    Glad you got it working
    @yabadaniel
    It's a great guide.....you're a credit to the forum @AutoFrank :-)
    @Desmo
    :oops:
    Hi users of the sonos-api
    an approach I use for morning music
    I use a preset to group some of the bedrooms together but at zero volume
    preset code here
    and I then use this code (its a vd button) to slowly raise the volume to a predefined lavel
    handy so you don't need to wake to full volume
    Hi sonos-api users
    Sonos will play a chime if a radio station is not available
    I use the following code (vd button) to check if a radio station has come on a chime and if so it changes to a different station.
    This would be modified to check through a number of stations if the radio station were unreliable
    -f
    26 minutes ago, gobbli said:
    @AutoFrank thanks for sharing!
    @gobbli
    glad to help - do you have it up and running ?
    @AutoFrank not at this time. I am not at home. Will try it at the weekend or so.
    2 minutes ago, Beijonig said:
    Response = sonos: GET ("/Bad/clip/192.168.2.115/music/TTS/showers.mp3/30");
    Hi @Beijonig
    The url you posted looks incorrect
    I've never used the clip but the advice from api developer is as follows...
    Try putting the full/absolute url of the mp3 (not a share mapped url that depends on you pc) in the filename position
    You could also try copying a clip to the static/clips folder on your pi and see if it works form there
    Just now, Beijonig said:
    @AutoFrank
    @Beijonig
    over network still might be possible
    Do you try and put the full url into the string
    something like
    I'll be home later and can try myself....
    @AutoFrank
    Yes
    Beijonig
    @Beijonig
    will do
    Short script (VD Main Loop) that turns off Sonos music in playroom if TV is turned on.
    It actually ungroups' the playroom from the kitchen pauses it  because normally the kitchen and playroom are grouped to play the same music
    It utilises the LAN Monitor to know when the TV is on or off
    The reason it's in the main loop of a VD is because I had a VD already set up as a remote for the playroom to enable control of TV and Music and it was easy to add this in.
    VD Main Loop code
    and the remote for the playroom looks like
