I've taken a slightly different approach to this now....having one VD to control all speakers.
In general use I'd use the proper Sonos app to control speakers around the house, I only want it in HC2 so I can automate a few things when I want to. By using just the one VD I can still control each speaker individually by using a selectable global variable for the speaker name to switch to each speaker. I can do the same for grouping/ungrouping speakers also. This way I still have full automated control for scenes and other VD's as well and just one VD to keep up to date as new ideas and features become available.
It may also help me track down my issue.
    Hi @Desmo
    Sounds like a good approach and will hopefully help expose the issue
    I don't really use a VD, apart from the one for all zones to see what is runnning periodically.
    my control is mostly for background automation, I find the presets very useful
    And my new VD is......stopping after 17 minutes :/
    To the second.
    I think I'll go for the HC2 upgrade this weekend and see if that sorts it out.
    To the second.
    Hi @Desmo
    The exact to 17 minutes is very strange indeed...
    I've been racking my brain on this one and have come up with two more possibilities
    - the api has logs, not sure which folder but I'm sure you'll find it if you poke around.
    - When it stops after 17 mins, if you reboot the Pi without touching the VD, does it start working again.
    -frank
    Good shout... I'll try both of those.
    Can't find anything of note in the logs and the VD doesn't work again after rebooting the Pi....surely it has to be an HC2 problem.
    Looks like an update is on the cars for the weekend.
    @AutoFrank, The Google TTS wasn't included in the original Rpi image, it became available after updating the api. :)
    Just remove/ rename settings.json to get it to work
    HI @jimicr
    Good catch .. how does it sound ?
    For the dutch TTS it sounds like a female instead of  robotic.
    So it's an improvement for us :)
    Now I need to figure out how to make a play/pause button and change your weather scene from page 3 to get it work again.
    And the hardest job of them all: we have 1 Sonos device now, I need to convince the misses we absolutely need more ;)
    Of course you need more :-D
    So I restarted the VD today (still not updated HC2 yet) and it's been running for 45 minutes so far but get a feeling it will stop again soon.
    Anyhow, thought I'd pop up a pic of where my VD is at right now...
    Top area for information, L K B N are to select Lounge, Kitchen, Bedroom or Nursery for controlling them.
    Control and volume buttons are there, followed by some favourites scrolled with the "Next" button and chosen with "Select".
    Finally I have a section to Group/Ungroup players. Again, I can select the speaker using L K B N and then group or ungroup it.
    @jimicr
    Yes, yes.. you definitely need more :-)
    I bought our first one (ZP100) in the US in 2006 and it is still working...
    Since then our sonos family has grown to 14 (mix or play1,3,5, zp80, zp90 ) and my original ZP100 is still working well. Not sure I can say that for many other 'devices' i have bought down through the years..
    The play/pause should be okay as there is a playpause command in the api - /room/playpause
    There is also separate play and pause commands
    Is this what you were looking for
    @Desmo
    That's looking very well :-)
    This is one of the things I really like about the api, lots of options and you can really customise a VD to suit your needs and system
    .. no stopping you now... assuming that that upgrade solves the 'stopping issue'
    if you happy to do at some time, it might be worth exporting the VD to this or another post with a brief explanation....
    I'll do that maybe once I've got this problem sorted :->
    So my VD ran for 52 minutes this morning before stopping so I've put a sleep command in the main loop to slow down the updates and so far it's been going for over 2 hours. I was just wondering if the amount of information was creating some kind of overload. If it keeps on running I'll slowly reduce the main loop delay until it remains stable.
    @Desmo
    How is the HC2 memory and CPU during all of this ?
    I've had several of these running concurrently with no issue
    I don't think they're particularly stressed to be honest....RAM is at a constant 46% and CPU is between 0-30% with the odd spike to 50-60% and very occasional spike to 80%.
    @Desmo
    That's ruled that out ....
    You could easily do a sleep up to 2 seconds.
    How is your network activity  ?
    .. running out of ideas here :-) hopefully the 4.11 upgrade will work
    BTW - I had a bit of a HC2 crash this morning (first in nearly 2 years) ..
    .. lucky I had good backups and a copy of all my source code in Zerobraine
    might worth making sure you're covered before the upgrade..
    It's a shame there's not an easy way to export code for all scenes and VD's.
    edit.....VD stopped after 2.5 hours. Going to increase the sleep time and see if it runs longer.
    Edited by Desmo
    hi @Desmo
    I believe you can with Krikroff's HC2 Tookit application but I have never tried the export.
    Details can be found here
    I've seen the toolkit about but never used it before. Just installed it and it's pretty good, got all my stuff backed up now so should anything catastrophic happen I've got some form of external backup :->
