I reset the Nursery player last night and the debug stopped updating after just 17 minutes. I've just reset all players at the same time so I'll see how long they carry on for this time and see if they stop individually or all at the same time.
I'll check out your VD that monitors all the players and give that a go as well to see if it throws anything up.
Also, I recently had to reinstall everything from scratch on the Pi but had this same issue before so I'm guessing it's an HC2 problem rather than the Pi.
Edited by Desmo
    Hi @Desmo
    There is code in the first post but I use a StateTable to monitor lots of things and it's kinds messy, I need to rewrite it so it uses an array and iteration
    Here is a simpler approach and shouldn't take but a couple of minutes to put together
    Let me know how you get on
    -f
    Edited by AutoFrank
    That's great @AutoFrank....thanks. I'll give it a whirl and see what happens.
    How strange is this.....all players stopped responding with updates at 17 minutes. They do still respond to any commands I send though, so control is still there, I just don't get any label updates.
    The all in one status VD is still running...will be interesting to see how long it runs for.
    Hi @Desmo
    Looks like you have a ghost in the machine :-(
    Could you check and post the following
    • Version of sonos
    • Sonos player models
    • Version of the api
    • Fw version of the hc2
    Any other anomalies on the hc2 you can see
    EDIT - One other thing you could try is to delete the sonos VD and re-create (If not already tried)
    Could be a glitch when it as originally created and saving/updating is not clearing it...
    Thx
    -frank
    Edited by AutoFrank
    I'll check all that info when I get home tonight. The multi-sonos VD stopped debugging after an hour.
    @Desmo, did you try sending commands thru Chrome?
    I was playing around and no control was possible. Then I restarted Chrome and all worked again.
    Jim
    Sending commands works just fine...it's getting the state updates that stop working. Things like current volume, playback state, track playing, etc.
    Hey @AutoFrank, I got most working :)
    I edited the VD to have a volume slider and maybe when everything works I'm going to test this with @jompa68 ACWUT.
    The one thing I couldn't get to work is that the lblState is always empty.
    I changed it it playbackState and now it works!
    Just one question: how do I set the TTS to google??? voicerss works nice but I want to try google :)
    Thanks for this great VD.
    Hi @jimicr
    Glad you got it working :-)
    I found the slider very awkward even on the native sonos tablet app and that's why I used the volume buttons
    playbackState is correct. I pretified the state json and this shows you what you can display
    This is for a radio station
    I used to use VoiceRSS and recently switched to AWS Polly which is more natural sounding
    I've never used google but there is some info here that will probably help
     (search for google about 2/3 way down the page)
    It looks like it doesn't need an api key
    Good luck with the google TTS - let me know how you get on...
    -f
    8 hours ago, AutoFrank said:
    Hi @Desmo
    Quote
    • Version of sonos - 7.1 (build 341637101)
    • Sonos player models - 2 x Play 1 as stereo pair, play 1, play 1, play 5
    • Version of the api - Not sure where to find version number but was only installed fresh last week so very recent
    • Fw version of the hc2 - v4.080
    Info in quote above :)
    hi @Desmo
    Sonos is the same
    I'm running 4.110 on the HC2
    The api version is in the package.json file and is probably 1.2.6
    It sounds like the api is running okay and the only major difference is the HC2 fw
    I'll take a quick look in the HC2 changelog and see if there is any reference to a vd update issue
    Do you have any any plans to upgrade to 4.11 ?
    EDIT
    Did you try and delete the VD and recreate from scratch
    You could copy the code to your editor and then copy back...
    Edited by AutoFrank
    Hey @AutoFrank,
    thanks for your reply, I can't find info about Google except that it might change from time to time. tried to remove te settings,json, make it an empty file ect...
    But that had the same outcome: I-need-to-reed-the-readme-about-an-API.mp3. So I'm sticking to voice rss for a while.
    Because by the looks of things Polly isnt available in the Netherlands.
    I looked in the debug but it doesn't hold all the same info as your prettified json. I'm missing the "stationName".
    Maybe that's a version issue, I installed the files yesterday as a prebuild Rpi image. maybe that's a bit behind :)
    Thanks for your help this far!
    1 minute ago, jimicr said:
    Hey @AutoFrank,
    Hu @jimicr
    Crap .. yes polly is only available in the few places and its a surprise to get it in Ireland before others. These things are normally available on the Moon before they come to ireland.. :-)
    The precompiled prob contains and older version and I recall some changes around station name and artist
    If you feel up to it you could upgrade .. its reasonably fast if you follow my few steps.
    either way it good to get it working .. now comes the fun to see what else you can do
    I compile a morning greeting in our bedroom and the kids room that's a mixture of weather conditions, temp inside and date and time. I plan on expanding this to calendar events. I also have a coming home greeting (time, house temp and some other stuff and then resume all on the music) and leaving message (and actions - pause all) and a night greeting. .. lots of possibilities now that you have the control :-)
    Turned out tht the prebuild Rpi is version 1.0.1,
    Just updated tot the latest git version 1.2.7 and had to change the syntax to get rid of the "+" -es :)
    @jimicr
    All good so  ??
    4 minutes ago, AutoFrank said:
    @jimicr
    All good so  ??
    So far so good. Going to play further tomorrow. Have get out off bed at 4am and test a lot earhtleak switches in a hospital.
    I know things are available late in Ireland most of the time, my dad was a corks man.
    Goodnight
    Goodnight
    @jimicr
    Cool... :-)
    @AutoFrank...the api I'm using is 1.2.7. I will be upgrading the HC2 soon, possibly this coming weekend so will see if it makes a difference.
    I've deleted all but one of the VD's and once I get one running fault free I'll copy it across to more VD's one at a time.
    @Desmo
    Let me know how it goes... this one is a real puzzler...
