16.5 hours run time with a 60 second main loop....there's definitely something strange, almost like a memory leak or something where it's basically getting clogged up and quitting.
Upgraded to 4.11 this morning and VD has been running for 1.5hrs main loop delay.....much better than the 17 minutes from before :-)
Fingers crossed that's the problem solved.
    @Desmo
    that's a good start...
    Let me know how the long term testing goes :-)
    Playing with this API is fun.
    As a surprise for my wife the Imperial March will blast at her when she gets home from work tomorrow... Wonder how mad she'll be at me :)
    @jimicr
    glad it's working out.....
    Here's hoping your wife sees the funny side or it could all end in tears :-)
    6 minutes ago, AutoFrank said:
    @jimicr
    Nah she's used to it.... And she always pulling my leg aswell :D
    @jimicr
    I think that the case for most of out better half's.. otherwise we wouldn't be allow to play :-)
    my wife gets greeted with - "Welcome Home, The house temperature is  XX"
    .. might try a marching band for fun some day :-)
    I did similar once but with all of my RGBW strip lights around the house. Wife walks in and LAPD mode goes off :mrgreen:
    On another note...this has been running fine now since the update on Saturday so must have been some bug with HC2 on V4.080.
    Just one thing I'd like to fix now and that is 3 of my players all show "Stopped" when off but one shows "Paused_Playback". Odd.
    @Desmo
    Greta to hear that the upgrade solved the issues
    I think the PAUSED_PLAYBACK v STOPPED is radio v music track being stopped/paused
    If you are just looking to have the display on the VD the same you could code an approach like "if state == paused_playback or state == stopped then display stopped in label "
    Yeah, that would make sense. Most are streaming radio from the internet whilst the odd one out is via spotify. I did think of changing as you said but wondered if there was an obvious reason I was missing.
    Still up and running without a hitch :-D Also changed my Play and Stop messages to the traditional "Triangle" and "Square" icons as they take up less space and look nicer.
    Now this is running properly I've set up a scene to let me know when the baby is asleep. We play white noise in her room when sleeping and so I can now set a variable along with a door sensor so I know when she's sleeping....I can now automatically limit volume on the other speakers should somebody else turn them on.
    Running the same engine since a while. The API is great and TTS functions works perfectly.
    I'm using a slightly modified VD as I wanted to have a compact tile on HC2 web interface.
    /monthly_2017_02/small.jpg.37c8f1887cd7db2c7ab3bbfcb6dd2e21.jpg" style="width:80px;height:auto;" alt="small.jpg" />
    Hi @jcichon01
    Glad to hear its working out well :-)
    that compact VD looks v slick.
    . if you have a chance would you mind sharing the code from your 'main' button as I think it would be a nice addition to this post
    -f
    25 minut temu, AutoFrank napisał:
    Hi @jcichon01
    -f
    sure, no problem :)
    Zone name is hardcoded as it contains "space" (and thus the need for %20) which does not look good being in VD name ;)
    and forgot the "main button"... here it is
    Edited by jcichon01
    1 minute ago, jcichon01 said:
    sure, no problem :)
    Thanks @jcichon01
    Nice VD @jcichon01
    Here's something you might like to add for a little neatness....
    It changes the states to icons instead which I think looks far nicer :)
    1 godzinę temu, Desmo napisał:
    Nice VD @jcichon01
    COOL, will do that right away :)
    Any of you guys go the code so I can use a slider to report/set the volume?
    Never used sliders in a VD before and my baby sleep deprived brain can't work it out right now :cry:
    Edited by Desmo
    sure :)
    ui.sldVol.value is your slider element's ID.
